[cgma-dev] r5170 - cgm/trunk/test
jiangtao_ma at yahoo.com
Mon Sep 19 12:32:59 CDT 2011
Author: janehu
Date: 2011-09-19 12:32:59 -0500 (Mon, 19 Sep 2011)
New Revision: 5170
Modified:
cgm/trunk/test/attribute_to_buffer.cpp
cgm/trunk/test/attribute_to_file.cpp
cgm/trunk/test/makept.cpp
cgm/trunk/test/subtract.cpp
Log:
Get rid of build warnings for both occ6.5 and occ6.3, passed make check for both versions.
Modified: cgm/trunk/test/attribute_to_buffer.cpp
--- cgm/trunk/test/attribute_to_buffer.cpp 2011-09-19 16:49:08 UTC (rev 5169)
+++ cgm/trunk/test/attribute_to_buffer.cpp 2011-09-19 17:32:59 UTC (rev 5170)
@@ -70,7 +70,6 @@
GeometryQueryTool::instance()->delete_geometry();
//check that the two single volume bodys' attributes are exported as SINGLELUMP%
- printf (p_buffer);
std::string search ("SINGLELUMP%") ;
std::string buffer (p_buffer, n_bsize);
Modified: cgm/trunk/test/attribute_to_file.cpp
--- cgm/trunk/test/attribute_to_file.cpp 2011-09-19 16:49:08 UTC (rev 5169)
+++ cgm/trunk/test/attribute_to_file.cpp 2011-09-19 17:32:59 UTC (rev 5170)
@@ -27,8 +27,8 @@
#endif
#define ASSERT(A) if (!(A)) failed(#A,__FILE__,__LINE__)
-CubitBoolean is_files_same(char* filename1,
- char* filename2);
+CubitBoolean is_files_same(std::string filename1,
+ std::string filename2);
void failed( const char* A, const char* FILE, int LINE )
@@ -69,9 +69,10 @@
std::ifstream Myfile;
std::string line;
- char* search = "SINGLELUMP%";
+ std::string search = "SINGLELUMP%";
Myfile.open ("bricks2.occ");
- int found = 0, offset;
+ int found = 0;
+ size_t offset;
if(Myfile.is_open())
while(!Myfile.eof())
@@ -136,20 +137,22 @@
return 0;
- char* filename2)
FILE *fp1, *fp2;
More information about the cgma-dev
