[cgma-dev] [Fathom] cgm make check with occ
    Jiangtao Hu
    jiangtao_ma at yahoo.com
    Thu Sep 15 11:45:21 CDT 2011
Hi, Iulian,
Those missing files are only for 10.2 cgm, 12.2 cgm has already have them. Can you let me know where the modify failed? Thanks.
Is the nightly  build and check for cgm still on? Can James confirm it? Thanks.
Jane
--- On Thu, 9/15/11, Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
Subject: Re: [Fathom] cgm make check with occ
To: "Jiangtao Hu" <jiangtao_ma at yahoo.com>
Cc: "CGMA Development" <cgma-dev at mcs.anl.gov>
Date: Thursday, September 15, 2011, 12:20 PM
Hi Jane,
modify fails.
You said that some files were missing, but you checked them only on cubit 10.2 branch.
My configure command is
 ./configure --prefix=/homes/iulian/lib/CGM --with-mpi=/homes/fathom/3rdparty/mp
ich2/mpich2-1.2.1/gcc/bin --with-occ=/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0
/gcc --enable-debug CC=/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicc
CXX=/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx FC=/homes/fathom/3
rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpif90  F90=/homes/fathom/3rdparty/mpich2/mp
ich2-1.2.1/gcc/bin/mpif90 F77=/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin
/mpif77
Iulian
----- Original Message -----
> Hi, Iulian,
> Trunk cgm with occ6.5 passed make check for me, is it the case for
> you?
> Thanks.
> jane
> --- On Wed, 9/14/11, Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
> From: Iulian Grindeanu <iulian at mcs.anl.gov>
> Cc: fathom at lists.mcs.anl.gov
> Date: Wednesday, September 14, 2011, 12:29 PM
> > Hi Jane,
> > Why should I check out version cubit 10.2 for testing occ?
> > I thought that tag/branch is created for maintaining cubit 10.2
> > based
> > cgm, not occ 6.3 based cgm.
> > If we are going to not support occ 6.3 on the main trunk, it should
> > be
> > clearly stated.
> > I will check out the branch though, and let you know if I still have
> > problems.
> > Iulian
> Hi Jane,
> So I still have one test failing on occ 6.3 based cgm, when I checked
> out cgm with tag cubit10.2
> (makept)
> I am pretty sure I patched my occ 6.3, but I will double check.
> So, should we not use anymore occ 6.3 on the main trunk? Should I
> build occ 6.5 on my laptop too?
> Are we discontinuing support on occ 6.3?
> Thanks,
> Iulian
> > > Did you check out code from
> > > https://svn.mcs.anl.gov/repos/ITAPS/cgm/tags/cubit10.2 ? This is
> > > code
> > > for cubit10.2 that Hong-Jun created yesterday. What I did was
> > > check
> > > out this directory, and build with opencascase6.3, and make check
> > > now
> > > passed.
> > > If you check out it now, you should get the version 5160, which
> > > has
> > > included two more testcases.
> > > Thanks.
> > > Jane
> > > --- On Wed, 9/14/11, Iulian Grindeanu < iulian at mcs.anl.gov >
> > > wrote:
> > > From: Iulian Grindeanu < iulian at mcs.anl.gov >
> > > To: "Jiangtao Hu" < jiangtao_ma at yahoo.com >
> > > Date: Wednesday, September 14, 2011, 11:43 AM
> > > On occ 6.3, I have a total of 5 tests failing, on the main trunk:
> > > /bin/bash: line 1: 23677 Segmentation fault "$tst" >
> > > testgeom_occ.log-t 2>&1
> > > FAIL: testgeom_occ
> > > /bin/bash: line 1: 23911 Segmentation fault "$tst" > modify.log-t
> > > 2>&1
> > > FAIL: modify
> > > PASS: subtract
> > > /bin/bash: line 1: 23965 Segmentation fault "$tst" > makept.log-t
> > > 2>&1
> > > FAIL: makept
> > > /bin/bash: line 1: 23992 Segmentation fault "$tst" > r_w.log-t
> > > 2>&1
> > > FAIL: r_w
> > > PASS: test_occ
> > > /bin/bash: line 1: 24046 Segmentation fault "$tst" >
> > > operation.log-t
> > > 2>&1
> > > FAIL: operation
> > > Iulian
> > > > Sorry, it was Opencascade6.3 that I checked, now checking 6.5,
> > > > it
> > > > failed build. I am looking to into it.
> > > > Jane
> > > > --- On Tue, 9/13/11, Iulian Grindeanu < iulian at mcs.anl.gov >
> > > > Subject: [Fathom] cgm make check with occ
> > > > To: fathom at lists.mcs.anl.gov
> > > > Date: Tuesday, September 13, 2011, 3:05 PM
> > > > Hello,
> > > > I have some errors in make check in occ-based cgm:
> > > > If I use occ 6.3, there are 5 tests totally failing
> > > > occ 6.5: 1 test failing (test_modify)
> > > > ./modify
> > > > Geometry engine set to: OpenCascade 6.5
> > > > Created volume(s): 2
> > > > Destroyed volume(s): 1
> > > > Updated volume(s): 2
> > > > terminate called after throwing an instance of
> > > > 'Standard_NoSuchObject'
> > > > Aborted
> > > > Does anyone have these problems?
> > > > cubit 12.2 based cgm is fine for me.
> > > > Thanks,
> > > > Iulian
> > > > _______________________________________________
> > > > Fathom mailing list
> > > > Fathom at lists.mcs.anl.gov
> > > > https://lists.mcs.anl.gov/mailman/listinfo/fathom
> > Fathom mailing list
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110915/bfa34849/attachment.htm>
More information about the cgma-dev
