[cgma-dev] [Fathom] cgm make check with occ
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Thu Sep 15 11:20:39 CDT 2011
Hi Jane,
modify fails.
You said that some files were missing, but you checked them only on cubit 10.2 branch.
My configure command is
 ./configure --prefix=/homes/iulian/lib/CGM --with-mpi=/homes/fathom/3rdparty/mp
ich2/mpich2-1.2.1/gcc/bin --with-occ=/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0
/gcc --enable-debug CC=/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicc
CXX=/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx FC=/homes/fathom/3
rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpif90  F90=/homes/fathom/3rdparty/mpich2/mp
ich2-1.2.1/gcc/bin/mpif90 F77=/homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin
/mpif77
Iulian
----- Original Message -----
> Hi, Iulian,
> Trunk cgm with occ6.5 passed make check for me, is it the case for
> you?
> Thanks.
> jane
> --- On Wed, 9/14/11, Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
> From: Iulian Grindeanu <iulian at mcs.anl.gov>
> Subject: Re: [Fathom] cgm make check with occ
> To: "Jiangtao Hu" <jiangtao_ma at yahoo.com>
> Cc: fathom at lists.mcs.anl.gov
> Date: Wednesday, September 14, 2011, 12:29 PM
> > Hi Jane,
> > Why should I check out version cubit 10.2 for testing occ?
> > I thought that tag/branch is created for maintaining cubit 10.2
> > based
> > cgm, not occ 6.3 based cgm.
> > If we are going to not support occ 6.3 on the main trunk, it should
> > be
> > clearly stated.
> > I will check out the branch though, and let you know if I still have
> > problems.
> > Iulian
> Hi Jane,
> So I still have one test failing on occ 6.3 based cgm, when I checked
> out cgm with tag cubit10.2
> (makept)
> I am pretty sure I patched my occ 6.3, but I will double check.
> So, should we not use anymore occ 6.3 on the main trunk? Should I
> build occ 6.5 on my laptop too?
> Are we discontinuing support on occ 6.3?
> Thanks,
> Iulian
> > > Did you check out code from
> > > https://svn.mcs.anl.gov/repos/ITAPS/cgm/tags/cubit10.2 ? This is
> > > code
> > > for cubit10.2 that Hong-Jun created yesterday. What I did was
> > > check
> > > out this directory, and build with opencascase6.3, and make check
> > > now
> > > passed.
> > > If you check out it now, you should get the version 5160, which
> > > has
> > > included two more testcases.
> > > Thanks.
> > > Jane
> > > --- On Wed, 9/14/11, Iulian Grindeanu < iulian at mcs.anl.gov >
> > > wrote:
> > > From: Iulian Grindeanu < iulian at mcs.anl.gov >
> > > To: "Jiangtao Hu" < jiangtao_ma at yahoo.com >
> > > Date: Wednesday, September 14, 2011, 11:43 AM
> > > On occ 6.3, I have a total of 5 tests failing, on the main trunk:
> > > /bin/bash: line 1: 23677 Segmentation fault "$tst" >
> > > testgeom_occ.log-t 2>&1
> > > FAIL: testgeom_occ
> > > /bin/bash: line 1: 23911 Segmentation fault "$tst" > modify.log-t
> > > 2>&1
> > > FAIL: modify
> > > PASS: subtract
> > > /bin/bash: line 1: 23965 Segmentation fault "$tst" > makept.log-t
> > > 2>&1
> > > FAIL: makept
> > > /bin/bash: line 1: 23992 Segmentation fault "$tst" > r_w.log-t
> > > 2>&1
> > > FAIL: r_w
> > > PASS: test_occ
> > > /bin/bash: line 1: 24046 Segmentation fault "$tst" >
> > > operation.log-t
> > > 2>&1
> > > FAIL: operation
> > > Iulian
> > > > Sorry, it was Opencascade6.3 that I checked, now checking 6.5,
> > > > it
> > > > failed build. I am looking to into it.
> > > > Jane
> > > > --- On Tue, 9/13/11, Iulian Grindeanu < iulian at mcs.anl.gov >
> > > > Subject: [Fathom] cgm make check with occ
> > > > To: fathom at lists.mcs.anl.gov
> > > > Date: Tuesday, September 13, 2011, 3:05 PM
> > > > Hello,
> > > > I have some errors in make check in occ-based cgm:
> > > > If I use occ 6.3, there are 5 tests totally failing
> > > > occ 6.5: 1 test failing (test_modify)
> > > > ./modify
> > > > Geometry engine set to: OpenCascade 6.5
> > > > Created volume(s): 2
> > > > Destroyed volume(s): 1
> > > > Updated volume(s): 2
> > > > terminate called after throwing an instance of
> > > > 'Standard_NoSuchObject'
> > > > Aborted
> > > > Does anyone have these problems?
> > > > cubit 12.2 based cgm is fine for me.
> > > > Thanks,
> > > > Iulian
> > > > _______________________________________________
> > > > Fathom mailing list
> > > > Fathom at lists.mcs.anl.gov
> > > > https://lists.mcs.anl.gov/mailman/listinfo/fathom
> > Fathom mailing list
More information about the cgma-dev
