[cgma-dev] r5132 - cgm/trunk/geom/OCC
    jiangtao_ma at yahoo.com
    Tue Aug 30 10:27:29 CDT 2011
Author: janehu
Date: 2011-08-30 10:27:28 -0500 (Tue, 30 Aug 2011)
New Revision: 5132
Modified:
   cgm/trunk/geom/OCC/OCCCurve.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Fixed mcnp2cad/INP-box4 test, which after I added curveList for points, failed to update the curveLists in certain situations. And some minor changes. Passed make check under cgm.
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp	2011-08-29 15:51:42 UTC (rev 5131)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp	2011-08-30 15:27:28 UTC (rev 5132)
@@ -1001,17 +1001,26 @@
   if(!shape.IsNull())
     curve = TopoDS::Edge(shape);
-  //set the vertices
-  DLIList<TopologyBridge*> vertices;
-  get_children_virt(vertices);
-  for (int i = 1; i <= vertices.size(); i++)
+  //make sure the shape (edge) length is greater than 0.
+  GProp_GProps myProps;
+  BRepGProp::LinearProperties(curve, myProps);
+  double d = myProps.Mass();
+  if(d > OCCQueryEngine::instance()->get_sme_resabs_tolerance())
-     TopologyBridge* tb = vertices.get_and_step();
-     OCCPoint *point = CAST_TO(tb, OCCPoint);
-     if (point)
-       point->update_OCC_entity(aBRepTrsf, op);
+    //set the vertices
+    DLIList<TopologyBridge*> vertices;
+    get_children_virt(vertices);
+    for (int i = 1; i <= vertices.size(); i++)
+       TopologyBridge* tb = vertices.get_and_step();
+       OCCPoint *point = CAST_TO(tb, OCCPoint);
+       if (point)
+         point->update_OCC_entity(aBRepTrsf, op);
+    myMarked = 1;
-  myMarked = 1;
+  else
+    curve.Nullify();
   OCCQueryEngine::instance()->update_OCC_map(*myTopoDSEdge, curve);
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2011-08-29 15:51:42 UTC (rev 5131)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2011-08-30 15:27:28 UTC (rev 5132)
@@ -2456,7 +2456,12 @@
 	      for(int j = 0; j < edge_list->size(); j++)
 		  TopoDS_Edge e = *(edge_list->get_and_step());
-		  myWire.Add(e);
+                  //Don't include zero length edge.
More information about the cgma-dev
