[cgma-dev] r5037 - in cgm/trunk: . geom/parallel itaps
Jane Hu janejhu at gmail.com
Mon Jun 27 09:10:10 CDT 2011
Hi, Hong-Jun
I am still doing code change for the attribute read/write stuff. it seems
not a small change.  The past week, I tried different things and made work
for this case, then fail on the other case. But I am going to continue to
work on it, trying new thoughts based on my understanding of details on OCC
topology/geometry structure.
 I am glad that you found ACIS works for your parallel work.
Jane
On Fri, Jun 24, 2011 at 5:36 PM, <hongjun at mcs.anl.gov> wrote:
> Author: hongjun
> Date: 2011-06-24 17:36:43 -0500 (Fri, 24 Jun 2011)
> New Revision: 5037
> Modified:
>   cgm/trunk/Makefile.am
>   cgm/trunk/configure.ac
>   cgm/trunk/geom/parallel/CGMParallelComm.cpp
>   cgm/trunk/geom/parallel/CGMReadParallel.cpp
>   cgm/trunk/geom/parallel/Makefile.am
>   cgm/trunk/itaps/iGeom_CGMA.cc
> Log:
> o Parallel CGM is also supported for ACIS geometry kernel only with
> "READ_PARALLEL" option
> o Parallel codes are built when "parallel_build" is defined (also cubit
> library is used)
> o GeometryQueryTool::import(export)_solid_model" functions are changed to
> CubitCompat functions
> o Passes make check
> Modified: cgm/trunk/Makefile.am
> --- cgm/trunk/Makefile.am       2011-06-24 19:11:43 UTC (rev 5036)
> +++ cgm/trunk/Makefile.am       2011-06-24 22:36:43 UTC (rev 5037)
> @@ -45,7 +45,7 @@
>                   geom/libcubit_geom.la \
>                   util/libcubit_util.la
>  else
> -  CORE_CGM_LIBS = geom/libcubit_geom.la
> +  CORE_CGM_LIBS = geom/libcubit_geom.la $(CGM_ll_LIB)
>  endif
>  SUBDIRS = compat util geom init . $(igeom_DIR) test cgm_apps geom/testing
> Modified: cgm/trunk/configure.ac
> --- cgm/trunk/configure.ac      2011-06-24 19:11:43 UTC (rev 5036)
> +++ cgm/trunk/configure.ac      2011-06-24 22:36:43 UTC (rev 5037)
> @@ -104,12 +104,6 @@
>              [CUBIT_DIR="$withval"
>               DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS
> --with-cubit=\"${withval}\""])
> -if test "x$CUBIT_DIR" != "xno"; then
> -  if test "x$WITH_MPI" != "xno"; then
> -    AC_MSG_ERROR("CGM from CUBIT shared library dosn't support parallel
> build. Use serial build.")
> -  fi
> -fi
>  if test "x$CUBIT_DIR" == "xyes"; then
>   AC_MSG_ERROR([Option --with-CUBIT without specifying Cubit directory.])
>  elif test "x$CUBIT_DIR" != "xno"; then
> Modified: cgm/trunk/geom/parallel/CGMParallelComm.cpp
> --- cgm/trunk/geom/parallel/CGMParallelComm.cpp 2011-06-24 19:11:43 UTC
> (rev 5036)
> +++ cgm/trunk/geom/parallel/CGMParallelComm.cpp 2011-06-24 22:36:43 UTC
> (rev 5037)
> @@ -267,9 +267,11 @@
>     return CUBIT_SUCCESS;
> +#ifdef HAVE_OCC
>   CubitStatus result =
> GeometryQueryTool::instance()->export_solid_model(ref_entity_list, pBuffer,
> n_buffer_size, b_write_buffer);
>   RRA("Failed to write ref entities to buffer.");
> +#endif
>   if (b_write_buffer) m_currentPosition += n_buffer_size;
> @@ -285,9 +287,11 @@
>  #else
>   if (n_buffer_size == 0) return CUBIT_SUCCESS;
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110627/839dedb9/attachment.htm>
More information about the cgma-dev mailing list
