[cgma-dev] r5037 - in cgm/trunk: . geom/parallel itaps
    hongjun at mcs.anl.gov
    Fri Jun 24 17:36:44 CDT 2011
Author: hongjun
Date: 2011-06-24 17:36:43 -0500 (Fri, 24 Jun 2011)
New Revision: 5037
Modified:
   cgm/trunk/Makefile.am
   cgm/trunk/configure.ac
   cgm/trunk/geom/parallel/CGMParallelComm.cpp
   cgm/trunk/geom/parallel/CGMReadParallel.cpp
   cgm/trunk/geom/parallel/Makefile.am
   cgm/trunk/itaps/iGeom_CGMA.cc
Log:
o Parallel CGM is also supported for ACIS geometry kernel only with "READ_PARALLEL" option
o Parallel codes are built when "parallel_build" is defined (also cubit library is used)
o GeometryQueryTool::import(export)_solid_model" functions are changed to CubitCompat functions
o Passes make check
Modified: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am	2011-06-24 19:11:43 UTC (rev 5036)
+++ cgm/trunk/Makefile.am	2011-06-24 22:36:43 UTC (rev 5037)
@@ -45,7 +45,7 @@
                   geom/libcubit_geom.la \
                   util/libcubit_util.la
 else
-  CORE_CGM_LIBS = geom/libcubit_geom.la
+  CORE_CGM_LIBS = geom/libcubit_geom.la $(CGM_ll_LIB)
 endif
 SUBDIRS = compat util geom init . $(igeom_DIR) test cgm_apps geom/testing
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac	2011-06-24 19:11:43 UTC (rev 5036)
+++ cgm/trunk/configure.ac	2011-06-24 22:36:43 UTC (rev 5037)
@@ -104,12 +104,6 @@
              [CUBIT_DIR="$withval"
               DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-cubit=\"${withval}\""])
-if test "x$CUBIT_DIR" != "xno"; then
-  if test "x$WITH_MPI" != "xno"; then
-    AC_MSG_ERROR("CGM from CUBIT shared library dosn't support parallel build. Use serial build.")
-  fi
-fi
 if test "x$CUBIT_DIR" == "xyes"; then
   AC_MSG_ERROR([Option --with-CUBIT without specifying Cubit directory.])
 elif test "x$CUBIT_DIR" != "xno"; then
Modified: cgm/trunk/geom/parallel/CGMParallelComm.cpp
--- cgm/trunk/geom/parallel/CGMParallelComm.cpp	2011-06-24 19:11:43 UTC (rev 5036)
+++ cgm/trunk/geom/parallel/CGMParallelComm.cpp	2011-06-24 22:36:43 UTC (rev 5037)
@@ -267,9 +267,11 @@
     return CUBIT_SUCCESS;
+#ifdef HAVE_OCC
   CubitStatus result = GeometryQueryTool::instance()->export_solid_model(ref_entity_list, pBuffer,
 									 n_buffer_size, b_write_buffer);
   RRA("Failed to write ref entities to buffer.");
+#endif
   if (b_write_buffer) m_currentPosition += n_buffer_size;
@@ -285,9 +287,11 @@
 #else
   if (n_buffer_size == 0) return CUBIT_SUCCESS;
More information about the cgma-dev
