[cgma-dev] questions on num_models in iGeom_load_cub_geometry
    Jane Hu
    janejhu at gmail.com
    Fri May  6 12:49:06 CDT 2011
Hello,
I am looking at a failure in reading cub file through iGeom interface. The
error happened on line 6327 where it required num_models (which was read in
from cubfile header[2],) to be less than 6, otherwise it errors out for "Too
many models in .cub file."
This particular .cub file returned a 7 for num_models. I commented out line
6327-6329 (not checking for num_models), and it went through and created the
correct model with one volume. My questions are: What does the num_models
refer to? And whether it has an upper limit? what should it be?
I'd appreciate someone who's familiar with cub file to give me some hint on
a correct fix for this issue.
Thank you!
Jane
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110506/1dfc6bd4/attachment.htm>
More information about the cgma-dev
