[cgma-dev] buildbot failure in cgm-shared: failed test
    James Porter
    jvporter at wisc.edu
    Wed Apr 27 15:26:03 CDT 2011
On Wed, 2011-04-27 at 12:39 -0500, Jason Kraftcheck wrote:
> I cannot reproduce the problem below locally.  I've tried CGM builds with
> and without CUBIT, static and shared for each.  My first guess is that
> perhaps 'make clean' needs to be run in gnep.  If that doesn't fix the
> problem, then does the output of these commands differ on gnep?
The builds usually run "make clean" when they start, but this time it
required a "make distclean". Everything looks good now.
- Jim
More information about the cgma-dev
