[cgma-dev] buildbot failure in cgm-shared: failed test
Jason Kraftcheck
kraftche at cae.wisc.edu
Wed Apr 27 12:39:34 CDT 2011
I cannot reproduce the problem below locally. I've tried CGM builds with
and without CUBIT, static and shared for each. My first guess is that
perhaps 'make clean' needs to be run in gnep. If that doesn't fix the
problem, then does the output of these commands differ on gnep?
$ ldd itaps/.libs/libiGeom.so | grep cgm
libcgm.so.0 => /home/jason/cgm/bld-cubit12/.libs/libcgm.so.0
(0x00007fe460d66000)
$ nm -C .libs/libcgm.so | grep CubitCompat
00000000000022be t global constructors keyed to CubitCompat.cpp
00000000000022d3 W CubitCompat_file_type(char const*)
0000000000002205 T CubitCompat_export_solid_model(DLIList<RefEntity*>&, char
const*, char const*, int&, CubitString const&, char const*)
0000000000002064 T CubitCompat_import_solid_model(char const*, char const*,
char const*, bool, bool, bool, bool, bool, bool, DLIList<RefEntity*>*)
- jason
On 04/27/2011 12:01 AM, cgma-dev at mcs.anl.gov wrote:
> Fathom <http://gnep.mcs.anl.gov:8010/>: cgm-shared
> <http://gnep.mcs.anl.gov:8010/builders/cgm-shared> build #449
> <http://gnep.mcs.anl.gov:8010/builders/cgm-shared/builds/449>
> *Results:* failed test
> *Buildslave:* gnep
> *Revision:* None
> *Reason:* The Nightly scheduler named 'cgm-shared-nightly' triggered
> this build
> Log Excerpt
> make[1]: Entering directory `/disks/itaps-buildslave/cgm-shared/build'
> Making check in compat
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/compat'
> make[2]: Nothing to be done for `check'.
> ...Making check in util
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/util'
> ...Making check in geom
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/geom'
> Making check in .
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/geom'
> ...Making check in Cholla
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/geom/Cholla'
> make[3]: Nothing to be done for `check'.
> ...Making check in facetbool
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/geom/facetbool'
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/geom/facet'
> ...Making check in virtual
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/geom/virtual'
> ...Making check in init
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/init'
> ...Making check in .
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-shared/build'
> make[2]: Nothing to be done for `check-am'.
> ...Making check in itaps
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/itaps'
> make check-recursive
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/itaps'
> Making check in .
> make[4]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/itaps'
> make chaman testgeom
> make[5]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/itaps'
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DSRCDIR=. -I../util -I../geom -I../init -Wall -pipe -pedantic -O2 -DNDEBUG -MT chaman.o -MD -MP -MF .deps/chaman.Tpo -c -o chaman.o chaman.cc
> mv -f .deps/chaman.Tpo .deps/chaman.Po
> /bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -O2 -DNDEBUG -R/home/fathom/3rdparty/cubit/Cubit64/Cubit-12.2/bin -L/home/fathom/3rdparty/cubit/Cubit64/Cubit-12.2/bin -o chaman chaman.o libiGeom.la -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/chaman chaman.o -L/home/fathom/3rdparty/cubit/Cubit64/Cubit-12.2/bin ./.libs/libiGeom.so -lm -Wl,-rpath -Wl,/disks/itaps-buildslave/packages/cgm-shared/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/cubit/Cubit64/Cubit-12.2/bin
> ./.libs/libiGeom.so: undefined reference to `CubitCompat_import_solid_model(char const*, char const*, char const*, bool, bool, bool, bool, bool, bool, DLIList*)'
> ./.libs/libiGeom.so: undefined reference to `CubitCompat_export_solid_model(DLIList&, char const*, char const*, int&, CubitString const&, char const*)'
> collect2: ld returned 1 exit status
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
More information about the cgma-dev
