[cgma-dev] testgeom failure with Cubit-12.2
    Rajeev Jain
    jain at mcs.anl.gov
    Wed Apr 13 14:28:28 CDT 2011
Adding some more info: this is on a 32bit OS and Cubit-12.2 used is for a 32bit system.
The two failures are:
1.
> Error code: 23
> Error desc: Problem adding entity to another set.
> At : testgeom.cc:825
> Failure
2.
> Error code: 15
> Error desc: Tag does not exist
> At : testgeom.cc:1309
> Failure
Rajeev
>________________________________
>From: Tim Tautges <tautges at mcs.anl.gov>
>To: cgma-dev at mcs.anl.gov
>Sent: Wednesday, April 13, 2011 2:11 PM
>Subject: Re: [cgma-dev] testgeom failure with Cubit-12.2
>The failure of getting intervals is due to attribute changes, so for that one the test needs to be changed.  For the
>other one, I'm not sure what the problem is.  Jane/Jason, have you seen this failure?
>- tim
>On 04/13/2011 01:39 PM, Rajeev Jain wrote:
>> Hi,
>> make check fails at testgeom when I use CGM merge-12 branch and
>> cubit-12.2, my config line is: ./configure --enable-shared
>> --prefix=/home/rajeev/lib/cgm12 --with-cubit=/home/rajeev/Cubit-12.2
>> --enable-debug
>> There are two failures (see below, test results from running testgeom):
>> 1. Topology adjacency
>> 2. Save EntSet
>> Let me know if you need more info.
>> rajeev at jain:~/cgm12/itaps$ gdb .libs/testgeom
>> GNU gdb (GDB) 7.1-ubuntu
>> Copyright (C) 2010 Free Software Foundation, Inc.
>> License GPLv3+: GNU GPL version 3 or later
>> <http://gnu.org/licenses/gpl.html>
>> This is free software: you are free to change and redistribute it.
>> There is NO WARRANTY, to the extent permitted by law. Type "show copying"
>> and "show warranty" for details.
>> This GDB was configured as "i486-linux-gnu".
>> For bug reporting instructions, please see:
>> <http://www.gnu.org/software/gdb/bugs/>...
>> Reading symbols from /home/rajeev/cgm12/itaps/.libs/testgeom...done.
>> (gdb) r
>> Starting program: /home/rajeev/cgm12/itaps/.libs/testgeom
>> [Thread debugging using libthread_db enabled]
>> Using default input file: ./testgeom.sat
>> ITAPS GEOMETRY INTERFACE TEST PROGRAM:
>> gLoad: Read 1 ACIS Entities from the input file
>> Constructed 1 Volume: 1
>> Model contents:
>> vertices: 36
>> edges: 60
>> faces: 33
>> regions: 1
>> Success
>> tags: Tags defined on model: GLOBAL_ID, NAME
>> Success
>> gentity sets: ERROR: Problem to add entity set.
>> Error code: 23
>> Failure
>> topology adjacencies: Success
>> construct: Created swept volume 3
>> Success
>> primitives: Success
>> transforms: Success
>> booleans: Updated volume(s): 10
>> Destroyed volume(s): 11
>> Updated volume(s): 12
>> Destroyed volume(s): 13
>> Success
>> mesh size: Read 1 ACIS Entities from the input file
>> ERROR: Attribute type -1 not recognized.
>> ERROR: Failed to get intervals for curves
>> Error code: 15
>> Failure
>> save entset:
>> Exported: 2 Volumes
>> Read 2 ACIS Entities from the input file
>> WARNING: Entity name 'Group 1' can't be used in commands.
>> Additional name 'Group_1' assigned.
>> Constructed 2 Volumes: 2, 3
>> Success
>> shutdown: Success
>> TSTT TEST SUMMARY:
>> Number Tests: 11
>> Number Successful: 9
>> Number Not Implemented: 0
>> Number Failed: 2
>> Program exited with code 02.
>> Rajeev
>"You will keep in perfect peace him whose mind is
>   steadfast, because he trusts in you."               Isaiah 26:3
>              Tim Tautges            Argonne National Laboratory
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>          phone: (608) 263-8485      1500 Engineering Dr.
>            fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110413/ec6cd7c2/attachment.htm>
More information about the cgma-dev
