[cgma-dev] r4668 - cgm/branches/merge-cubit12/geom
    jiangtao_ma at yahoo.com
    Mon Mar 28 13:33:59 CDT 2011
Author: janehu
Date: 2011-03-28 13:33:59 -0500 (Mon, 28 Mar 2011)
New Revision: 4668
Modified:
   cgm/branches/merge-cubit12/geom/GeometryModifyTool.cpp
Log:
in subtract function, subtract and finish_sm_op can independently return success or failure, so set them differently.
Modified: cgm/branches/merge-cubit12/geom/GeometryModifyTool.cpp
--- cgm/branches/merge-cubit12/geom/GeometryModifyTool.cpp	2011-03-28 18:31:31 UTC (rev 4667)
+++ cgm/branches/merge-cubit12/geom/GeometryModifyTool.cpp	2011-03-28 18:33:59 UTC (rev 4668)
@@ -6370,7 +6370,7 @@
    if( CubitUndo::get_undo_enabled() && result == CUBIT_FAILURE )
      CubitUndo::remove_last_undo();
-   result = finish_sm_op(tem_bodies, new_sms, new_bodies);
+   CubitStatus result2 = finish_sm_op(tem_bodies, new_sms, new_bodies);
    if( CubitUndo::get_undo_enabled() )
@@ -6380,7 +6380,7 @@
-   if ( result == CUBIT_FAILURE )
+   if ( result == CUBIT_FAILURE || result2 == CUBIT_FAILURE)
      PRINT_ERROR("Subtract FAILED\n" );
      return CUBIT_FAILURE;
More information about the cgma-dev
