[cgma-dev] [PATCH] API and linking changes for OpenCascade-6.5.0
Jed Brown jed at 59A2.org
Sat Mar 26 02:15:26 CDT 2011
Perhaps these should not be applied directly, but I don't know how you
want to handle checking versions and backward compatibility.
 configure.ac                      |    2 +-
 geom/OCC/OCCAttribSet.cpp         |   11 +++++------
 geom/OCC/OCCQueryEngine.cpp       |    1 -
 geom/OCC/OCCShapeAttributeSet.cpp |    7 +++----
 4 files changed, 9 insertions(+), 12 deletions(-)
diff --git a/configure.ac b/configure.ac
index 8994977..1e8a6a4 100644
--- a/configure.ac
+++ b/configure.ac
@@ -354,7 +354,7 @@ HAVE_OCC_DEF=
 if test "x$occ_DIR" != "xno"; then
   OCC_CORE_LIBS="-lTKMesh -lTKTopAlgo -lTKGeomAlgo -lTKBRep -lTKGeomBase -lTKG3d -lTKG2d -lTKMath -lTKernel"
   OCC_GEOM_LIBS="-lTKHLR -lTKOffset -lTKShHealing -lTKFillet -lTKFeat -lTKBool -lTKBO -lTKPrim"
-  OCC_LCAF_LIBS="-lTKBinL -lTKLCAF -lTKCDF"
+  OCC_LCAF_LIBS="-lTKBinL -lTKLCAF -lTKCDF -lTKCAF"
   OCC_LIBS="$OCC_LCAF_LIBS $OCC_GEOM_LIBS $OCC_CORE_LIBS"
   CUBIT_OCC_LIB="-lcubit_OCC"
   OCC_STEP_LIBS="-lTKSTEP -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKXSBase"
diff --git a/geom/OCC/OCCAttribSet.cpp b/geom/OCC/OCCAttribSet.cpp
index 36c5c84..b39b8cd 100644
--- a/geom/OCC/OCCAttribSet.cpp
+++ b/geom/OCC/OCCAttribSet.cpp
@@ -15,17 +15,16 @@
 #include "OCCQueryEngine.hpp"
 #include "CubitSimpleAttrib.hpp"
 #include "CubitFileIOWrapper.hpp"
-#include "Handle_TDataStd_Shape.hxx"
 #include "TCollection_ExtendedString.hxx"
 #include "Handle_TDataStd_Name.hxx"
 #include "Handle_TDataStd_ExtStringArray.hxx"
 #include "Handle_TDataStd_RealArray.hxx"
 #include "Handle_TDataStd_IntegerArray.hxx"
+#include "TDataXtd_Shape.hxx"
 #include "TDataStd_Name.hxx"
 #include "TDataStd_ExtStringArray.hxx"
 #include "TDataStd_RealArray.hxx"
 #include "TDataStd_IntegerArray.hxx"
-#include "TDataStd_Shape.hxx"
 #include "TopoDS_Shape.hxx"
 #include "TDF_ChildIterator.hxx"
 #include <vector>
@@ -40,9 +39,9 @@ void OCCAttribSet::FindShape(TopoDS_Shape& shape,
     //find the same shape attribute first
     aLabel = it1.Value();
-    Handle_TDataStd_Shape attr_shape;
+    Handle_TDataXtd_Shape attr_shape;
     TopoDS_Shape old_shape;
-    if(aLabel.FindAttribute(TDataStd_Shape::GetID(), attr_shape))
+    if(aLabel.FindAttribute(TDataXtd_Shape::GetID(), attr_shape))
       old_shape = attr_shape->Get(aLabel);
     if(old_shape.IsPartner(shape))
@@ -64,10 +63,10 @@ void OCCAttribSet::append_attribute( CubitSimpleAttrib* csa, TopoDS_Shape& shape
   if(!found)
     aLabel = OCCQueryEngine::instance()->mainLabel.NewChild();
-    Handle_TDataStd_Shape attr_shape = TDataStd_Shape::Set(aLabel, shape);
+    Handle_TDataXtd_Shape attr_shape = TDataXtd_Shape::Set(aLabel, shape);
     //myLabel.AddAttribute(attr_shape);
     //test if the attribute has been attached
-    assert(aLabel.IsAttribute(TDataStd_Shape::GetID()));
+    assert(aLabel.IsAttribute(TDataXtd_Shape::GetID()));
   //2. add type attribute , below attributes are added on child lable of myLabel
diff --git a/geom/OCC/OCCQueryEngine.cpp b/geom/OCC/OCCQueryEngine.cpp
index 6be36a3..ed5c6fc 100644
--- a/geom/OCC/OCCQueryEngine.cpp
+++ b/geom/OCC/OCCQueryEngine.cpp
@@ -107,7 +107,6 @@
 #include <BndLib_AddSurface.hxx>
 #include <Precision.hxx>
 #include <BRepAdaptor_Surface.hxx>
-#include <TDataStd_Shape.hxx>
 #include <TDF_ChildIterator.hxx>
 #include <BinTools_ShapeSet.hxx>
 #include "Standard_Boolean.hxx"
diff --git a/geom/OCC/OCCShapeAttributeSet.cpp b/geom/OCC/OCCShapeAttributeSet.cpp
index ee87c61..95e3e05 100644
--- a/geom/OCC/OCCShapeAttributeSet.cpp
+++ b/geom/OCC/OCCShapeAttributeSet.cpp
@@ -22,7 +22,6 @@
 #include <Handle_BRep_GCurve.hxx>
 #include <BRep_Tool.hxx>
-#include <Handle_TDataStd_Shape.hxx>
 #include <TopTools_LocationSet.hxx>
 #include <TopTools_IndexedMapOfShape.hxx>
 #include <TopoDS_Iterator.hxx>
@@ -42,7 +41,7 @@
 #include <BRep_PointOnSurface.hxx>
 //#include <BRep_ListIteratorOfListOfPointRepresentation.hxx>
 #include <TDF_Label.hxx>
+#include <TDataXtd_Shape.hxx>
 #include <Handle_TDataStd_Name.hxx>
 #include <TDataStd_Name.hxx>
 #include <Handle_TDataStd_ExtStringArray.hxx>
@@ -507,9 +506,9 @@ void  OCCShapeAttributeSet::WriteAttribute(const TopoDS_Shape& S,
     myLabel = it1.Value();
     TopoDS_Shape exsiting_shape;
-    if(TDataStd_Shape::Find(myLabel, attr_shape))
+    if(TDataXtd_Shape::Find(myLabel, attr_shape))
       exsiting_shape = attr_shape->Get(myLabel);
     if(!exsiting_shape.IsNull())
1.7.4.1
More information about the cgma-dev mailing list
