[cgma-dev] r4440 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Fri Jan 14 12:37:50 CST 2011
Author: janehu
Date: 2011-01-14 12:37:50 -0600 (Fri, 14 Jan 2011)
New Revision: 4440
Modified:
cgm/trunk/geom/OCC/occ_patches
Log:
Changed the diff method to -u instead of -rcs for BRepBuilderAPI_Collect.cxx file.
Modified: cgm/trunk/geom/OCC/occ_patches
--- cgm/trunk/geom/OCC/occ_patches 2011-01-14 15:20:50 UTC (rev 4439)
+++ cgm/trunk/geom/OCC/occ_patches 2011-01-14 18:37:50 UTC (rev 4440)
@@ -66,35 +66,27 @@
// write end of pipe is unbuffered also
-*** BRepBuilderAPI_Collect.cxx 2011-01-14 08:49:48.000000000 -0600
---- /mnt/disk2b/jhu/OpenCASCADE6.3.0/ros/src/BRepBuilderAPI/BRepBuilderAPI_Collect.cxx 2011-01-14 08:51:02.000000000 -0600
-*** 201,218 ****
- BuildBack (myGen, GenBack); // Vraiment pas optimum a Revoir
- BuildBack (myMod, ModBack);
-! TopAbs_ShapeEnum type = SI.ShapeType();
-! Update (myMod,myGen,ModBack,GenBack,SI,MKS,type);
-! if(type < TopAbs_SHELL)
-! Update (myMod,myGen,ModBack,GenBack,SI,MKS,TopAbs_SHELL);
-! if(type < TopAbs_FACE)
-! Update (myMod,myGen,ModBack,GenBack,SI,MKS,TopAbs_FACE);
-! if(type < TopAbs_WIRE)
-! Update (myMod,myGen,ModBack,GenBack,SI,MKS,TopAbs_WIRE);
-! if(type < TopAbs_EDGE)
-! Update (myMod,myGen,ModBack,GenBack,SI,MKS,TopAbs_EDGE);
-! if(type < TopAbs_VERTEX)
-! Update (myMod,myGen,ModBack,GenBack,SI,MKS,TopAbs_VERTEX);
- #ifdef DEB
- if (Affich) {
---- 201,209 ----
- #ifdef DEB
- if (Affich) {
+--- ./BRepBuilderAPI/BRepBuilderAPI_Collect.cxx 2011-01-14 08:51:02.000000000 -0600
++++ ./BRepBuilderAPI_Collect.cxx 2011-01-14 12:30:11.000000000 -0600
+@@ -201,9 +201,18 @@
+ BuildBack (myGen, GenBack); // Vraiment pas optimum a Revoir
+ BuildBack (myMod, ModBack);
+- Update (myMod,myGen,ModBack,GenBack,SI,MKS,TopAbs_FACE);
+- Update (myMod,myGen,ModBack,GenBack,SI,MKS,TopAbs_EDGE);
+- Update (myMod,myGen,ModBack,GenBack,SI,MKS,TopAbs_VERTEX);
++ TopAbs_ShapeEnum type = SI.ShapeType();
++ Update (myMod,myGen,ModBack,GenBack,SI,MKS,type);
More information about the cgma-dev
