[cgma-dev] r4439 - cgm/trunk
jiangtao_ma at yahoo.com
Fri Jan 14 09:20:50 CST 2011
Author: janehu
Date: 2011-01-14 09:20:50 -0600 (Fri, 14 Jan 2011)
New Revision: 4439
Modified:
cgm/trunk/KNOWN_ISSUES
Log:
closed issue 177 for scaling with different factors in x-y-z directions; Opened a new one for imprinting on Spline surfaces crash issue.
Modified: cgm/trunk/KNOWN_ISSUES
--- cgm/trunk/KNOWN_ISSUES 2011-01-14 15:12:08 UTC (rev 4438)
+++ cgm/trunk/KNOWN_ISSUES 2011-01-14 15:20:50 UTC (rev 4439)
@@ -10,8 +10,6 @@
176 minor CGM memory leak
-177 minor 3-D scale with different scale factors doesn't work.
178 major Unite function doesn't unite smoothly connected surfaces.
179 major mcnp2cad test suite lat1-7 not working, needs debugging.
@@ -25,3 +23,5 @@
183 minor Don't have proper tool to visualize the TopoDS_Shapes, debugging
process is long preparing for graphics to understand the issue
+185 major mcnp2cad/tests/INP-torus test case fails on imprinting 2 spline
+ surfaces.
More information about the cgma-dev
