[cgma-dev] r4225 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Tue Oct 19 12:20:14 CDT 2010
Author: janehu
Date: 2010-10-19 12:20:14 -0500 (Tue, 19 Oct 2010)
New Revision: 4225
Modified:
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
Add for buffer read in or wirte out for occ shapes.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2010-10-18 22:10:22 UTC (rev 4224)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2010-10-19 17:20:14 UTC (rev 4225)
@@ -1203,189 +1203,8 @@
   return CUBIT_SUCCESS;
-CubitStatus
-OCCQueryEngine::write_topology( //const unsigned char* p_buffer,
-			       //char* p_buffer,
-			       ofstream& os,
-				DLIList<OCCBody*> &OCC_bodies,
-				DLIList<OCCSurface*> &OCC_surfaces,
-				DLIList<OCCCurve*> &OCC_curves,
-				DLIList<OCCPoint*> &OCC_points)
-  int i;
-  //Create a compound shape to export
-  BRep_Builder B;
-  TopoDS_Compound Co;
-  B.MakeCompound(Co);
-  //Add every shape to the compound
-  for (i = 0; i < OCC_bodies.size(); i++)
-      OCCBody* body = OCC_bodies.get_and_step();
-      TopoDS_CompSolid *shape = body->get_TopoDS_Shape();
-      if (shape == NULL || shape->IsNull()) //singel lump or sheet or shell body
-         OCCSurface* surface = body->my_sheet_surface();
-         OCCShell* shell = body->shell();
-         DLIList<Lump*> lumps = occ_body->lumps();
-         if(surface)
-           B.Add(Co,*(surface->get_TopoDS_Face()));
-         else if (shell)
-    	   B.Add(Co,*(shell->get_TopoDS_Shell()));
-         else
-           B.Add(Co,*(CAST_TO(lumps.get(),OCCLump)->get_TopoDS_Solid()));
-         continue;
-      //check if this body is build backwards from lump. if so,
-      //the body and its CompSolid doesn't have bounded relationship
-      //established. In this case, each individual lump of the body
-      // will be exported as TopoDS_Solid without a CompSolid
-      if(OCCMap->IsBound(*shape))
-	B.Add(Co, *shape);
More information about the cgma-dev mailing list
