[cgma-dev] r4222 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Mon Oct 18 11:20:50 CDT 2010
Author: janehu
Date: 2010-10-18 11:20:49 -0500 (Mon, 18 Oct 2010)
New Revision: 4222
Modified:
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Changes to correspond with body holding multiple volumes or shells or surfaces when treating Attributes.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2010-10-16 01:35:04 UTC (rev 4221)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2010-10-18 16:20:49 UTC (rev 4222)
@@ -189,6 +189,11 @@
void OCCBody::append_simple_attribute_virt(CubitSimpleAttrib *csa)
+ if (myTopoDSShape != NULL)
+ OCCAttribSet::append_attribute(csa, *myTopoDSShape);
+ return;
int i = 0;
for (i; i < mySheetSurfaces.size();i++)
@@ -206,12 +211,15 @@
TopoDS_Solid* solid = lump->get_TopoDS_Solid();
OCCAttribSet::append_attribute(csa, *solid);
- if (myTopoDSShape != NULL)
- OCCAttribSet::append_attribute(csa, *myTopoDSShape);
void OCCBody::remove_simple_attribute_virt(CubitSimpleAttrib *csa)
+ OCCAttribSet::remove_attribute(csa, *myTopoDSShape);
+ return;
for(int i = 0; i < myShells.size(); i++)
TopoDS_Shell* shell = myShells.get_and_step()->get_TopoDS_Shell();
@@ -228,8 +236,6 @@
OCCAttribSet::remove_attribute(csa, *solid);
- OCCAttribSet::remove_attribute(csa, *myTopoDSShape);
@@ -238,6 +244,9 @@
CubitStatus OCCBody::get_simple_attribute(DLIList<CubitSimpleAttrib*>& csa_list)
+ return OCCAttribSet::get_attributes(*myTopoDSShape,csa_list);
for (int i=0; i < mySheetSurfaces.size();i++)
More information about the cgma-dev
