[cgma-dev] r4190 - in cgm/trunk: geom/OCC test
hongjun at mcs.anl.gov
Fri Oct 15 10:59:14 CDT 2010
Hello, Jane
I am developing parallel meshing and I need to distribute OCC geometry to multiple processors.
Since I am using Body as a unit of geometry distribution, I want to store distribution information as attributes to Body entities.
So, I made several import/export functions from/to memory buffer in "OCCQueryTool".
However, they are changed for "export_solid_model" function not to export parent Body entity of single Volume lump geometry
and I lose the attribute information assigned to Body entity.
So, can you change for single volume geometry to be exported with its parent Body attribute information?
Otherwise, do I have to use Volume and Surface as a distribution unit and assign the distribution information to Volume entity?
Hong-Jun Kim
Post-doc researcher
9700 S. Cass Ave. B240/R2147
Argonne, IL 60439
630-252-4791
----- "jiangtao ma" <jiangtao_ma at yahoo.com> wrote:
> Author: janehu
> Date: 2010-10-04 09:47:41 -0500 (Mon, 04 Oct 2010)
> New Revision: 4190
> Modified:
> cgm/trunk/geom/OCC/OCCBody.cpp
> cgm/trunk/geom/OCC/OCCBody.hpp
> cgm/trunk/geom/OCC/OCCCurve.cpp
> cgm/trunk/geom/OCC/OCCCurve.hpp
> cgm/trunk/geom/OCC/OCCDrawTool.cpp
> cgm/trunk/geom/OCC/OCCLump.cpp
> cgm/trunk/geom/OCC/OCCLump.hpp
> cgm/trunk/geom/OCC/OCCModifyEngine.cpp
> cgm/trunk/geom/OCC/OCCPoint.hpp
> cgm/trunk/geom/OCC/OCCQueryEngine.cpp
> cgm/trunk/geom/OCC/OCCQueryEngine.hpp
> cgm/trunk/geom/OCC/OCCShell.cpp
> cgm/trunk/geom/OCC/OCCShell.hpp
> cgm/trunk/geom/OCC/OCCSurface.cpp
> cgm/trunk/geom/OCC/OCCSurface.hpp
> cgm/trunk/test/Makefile.am
> cgm/trunk/test/makept.cpp
> cgm/trunk/test/modify.cpp
> cgm/trunk/test/r_w.cpp
> Log:
> Body now has compound structure: can hold multiple surfaces, shells
> and lumps. Single surface or shell or lump body will not have
> TopoDS_Coumpound pointer in Body, and boolean operation is working
> only on these kinds of bodies. The result of the boolean can be
> compound.
> So far, it passes all 12 tests under CGM/test, and it passed two more
> tests in mcnp2cad: cone and fill1. Other tests are under investigation
> now.
> Modified: cgm/trunk/geom/OCC/OCCBody.cpp
> --- cgm/trunk/geom/OCC/OCCBody.cpp 2010-10-04 13:09:41 UTC (rev 4189)
> +++ cgm/trunk/geom/OCC/OCCBody.cpp 2010-10-04 14:47:41 UTC (rev 4190)
> @@ -43,6 +43,7 @@
> #include "TopTools_ListIteratorOfListOfShape.hxx"
> #include "gp_Ax1.hxx"
> #include "gp_Ax2.hxx"
> +#include "gp_GTrsf.hxx"
> #include "Bnd_Box.hxx"
> #include "BRepBndLib.hxx"
> #include "TopExp_Explorer.hxx"
> @@ -52,75 +53,133 @@
> #include "BRepGProp.hxx"
> #include "Standard_Boolean.hxx"
> #include "LocOpe_SplitShape.hxx"
> +#include "TopoDS_Compound.hxx"
> // Purpose : A constructor with a list of lumps that are
> attached.
> // Special Notes :
> -OCCBody::OCCBody(TopoDS_CompSolid *theShape, CubitBoolean
> isSheetBody,
> - OCCSurface* surface, OCCShell* shell)
> +OCCBody::OCCBody(TopoDS_Compound *theShape,
> + OCCSurface* surface, OCCShell* shell, Lump* lump)
> myTopoDSShape = theShape;
> - IsSheetBody = isSheetBody;
> - mySheetSurface = surface;
> - myShell = shell;
> + if (surface != NULL)
> + mySheetSurfaces.append(surface);
> + if( shell != NULL)
> + myShells.append(shell);
> + if (lump != NULL)
> + myLumps.append(lump);
> update_bounding_box();
> + if (myTopoDSShape && !myTopoDSShape->IsNull())
> + assert(myTopoDSShape->ShapeType() == TopAbs_COMPOUND);
> -void OCCBody::set_sheet_surface(OCCSurface* surface)
> +TopoDS_Compound* OCCBody::get_TopoDS_Shape()
> - IsSheetBody = CUBIT_TRUE;
> - if(surface == NULL)
> - IsSheetBody = CUBIT_FALSE;
More information about the cgma-dev
