[cgma-dev] buildbot failure in Fathom on cgm-distcheck
cgma-dev at lists.mcs.anl.gov cgma-dev at lists.mcs.anl.gov
Fri Oct 15 00:25:47 CDT 2010
The Fathomatic has detected a failed build of cgm-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/cgm-distcheck/builds/255
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
Making all in virtual
make[5]: Entering directory `/disk/itaps-buildslave/cgm-distcheck/build/cgma-10.2.3/_build/geom/virtual'
make[5]: Nothing to be done for `all'.
Making all in init
make[4]: Entering directory `/disk/itaps-buildslave/cgm-distcheck/build/cgma-10.2.3/_build/init'
/bin/sh ../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../init -I.. -I../geom/parallel -I../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DCUBIT_CGM -I../../geom -I../../util -I../../geom/ACIS -I../../geom/OCC -I../../geom/virtual -I../../geom/facet -I../../geom/cholla -I../../init    -Wall -pipe -pedantic -O2 -DNDEBUG -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c -o InitCGMA.lo ../../init/InitCGMA.cpp
 g++ -DHAVE_CONFIG_H -I. -I../../init -I.. -I../geom/parallel -I../itaps -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DCUBIT_CGM -I../../geom -I../../util -I../../geom/ACIS -I../../geom/OCC -I../../geom/virtual -I../../geom/facet -I../../geom/cholla -I../../init -Wall -pipe -pedantic -O2 -DNDEBUG -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c ../../init/InitCGMA.cpp -o InitCGMA.o
mv -f .deps/InitCGMA.Tpo .deps/InitCGMA.Plo
/bin/sh ../libtool --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG   -o libcgma_init.la  InitCGMA.lo  -lm
mkdir .libs
ar cru .libs/libcgma_init.a  InitCGMA.o
ranlib .libs/libcgma_init.a
creating libcgma_init.la
(cd .libs && rm -f libcgma_init.la && ln -s ../libcgma_init.la libcgma_init.la)
Making all in .
make[4]: Entering directory `/disk/itaps-buildslave/cgm-distcheck/build/cgma-10.2.3/_build'
/bin/sh ./libtool --tag=CC   --mode=link gcc  -Wall -pipe -pedantic -O2 -DNDEBUG   -o libcgm.la -rpath /disk/itaps-buildslave/cgm-distcheck/build/cgma-10.2.3/_inst/lib  init/libcgma_init.la  -L/home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin -lcubiti19 /home/sharp/3rdparty/Cubit/Cubit64/cubit-10.2-amd64/bin/libcubiti19.so -lm
mkdir .libs
rm -fr .libs/libcgm.lax
mkdir .libs/libcgm.lax
rm -fr .libs/libcgm.lax/libcgma_init.a
mkdir .libs/libcgm.lax/libcgma_init.a
(cd .libs/libcgm.lax/libcgma_init.a && ar x /disk/itaps-buildslave/cgm-distcheck/build/cgma-10.2.3/_build/init/.libs/libcgma_init.a)
ar cru .libs/libcgm.a   .libs/libcgm.lax/libcgma_init.a/InitCGMA.o
ranlib .libs/libcgm.a
creating libcgm.la
(cd .libs && rm -f libcgm.la && ln -s ../libcgm.la libcgm.la)
Making all in itaps
make[4]: Entering directory `/disk/itaps-buildslave/cgm-distcheck/build/cgma-10.2.3/_build/itaps'
make  all-recursive
make[5]: Entering directory `/disk/itaps-buildslave/cgm-distcheck/build/cgma-10.2.3/_build/itaps'
Making all in .
make[6]: Entering directory `/disk/itaps-buildslave/cgm-distcheck/build/cgma-10.2.3/_build/itaps'
/bin/sh ../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../itaps -I.. -I../geom/parallel  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DSRCDIR=../../itaps -I../../util -I../../geom -I../../init    -Wall -pipe -pedantic -O2 -DNDEBUG -MT CATag.lo -MD -MP -MF .deps/CATag.Tpo -c -o CATag.lo ../../itaps/CATag.cpp
 g++ -DHAVE_CONFIG_H -I. -I../../itaps -I.. -I../geom/parallel -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DSRCDIR=../../itaps -I../../util -I../../geom -I../../init -Wall -pipe -pedantic -O2 -DNDEBUG -MT CATag.lo -MD -MP -MF .deps/CATag.Tpo -c ../../itaps/CATag.cpp -o CATag.o
../../itaps/CATag.cpp: In member function 'iBase_ErrorType CGMTagManager::set_csa_tag(RefEntity*, long int, CubitSimpleAttrib*)':
../../itaps/CATag.cpp:211: warning: dereferencing type-punned pointer will break strict-aliasing rules
mv -f .deps/CATag.Tpo .deps/CATag.Plo
/bin/sh ../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../itaps -I.. -I../geom/parallel  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -DSRCDIR=../../itaps -I../../util -I../../geom -I../../init    -Wall -pipe -pedantic -O2 -DNDEBUG -MT iGeom_CGMA.lo -MD -MP -MF .deps/iGeom_CGMA.Tpo -c -o iGeom_CGMA.lo ../../itaps/iGeom_CGMA.cc
 g++ -DHAVE_CONFIG_H -I. -I../../itaps -I.. -I../geom/parallel -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DSRCDIR=../../itaps -I../../util -I../../geom -I../../init -Wall -pipe -pedantic -O2 -DNDEBUG -MT iGeom_CGMA.lo -MD -MP -MF .deps/iGeom_CGMA.Tpo -c ../../itaps/iGeom_CGMA.cc -o iGeom_CGMA.o
{standard input}: Assembler messages:
{standard input}:26927: Warning: end of file not at end of a line; newline inserted
{standard input}:28074: Error: unknown pseudo-op: `.se'
g++: Internal error: Killed (program cc1plus)
Please submit a full bug report.
See <URL:http://gcc.gnu.org/bugs.html> for instructions.
For Debian GNU/Linux specific bug reporting instructions, see
<URL:file:///usr/share/doc/gcc-4.2/README.Bugs>.
sincerely,
 -The Fathomatic
More information about the cgma-dev mailing list
