[cgma-dev] .stp translator - Cubit license?
Paul Wilson
wilsonp at engr.wisc.edu
Fri Sep 24 19:46:31 CDT 2010
Yes, since v11.x, the 64 bit linux Cubit does not support STEP translation. I have it on good authority that v12.2 will restore this capability.
It's only the combination of 64 bit & Linux.
Paul
Associate Professor, Nuclear Engineering
Chair, Energy Analysis & Policy
UW-Madison
wilsonp at engr.wisc.edu, 608.263.0807
Sent from my iPhone
On Sep 24, 2010, at 17:22, Rajeev Jain <jain at mcs.anl.gov> wrote:
> I don't recall talking any special license for Cubit 10.2 build 24 (32 bit version). Maybe it is something internal to Cubit's versions.
> Rajeev
> From: Hong-Jun Kim <hongjun at mcs.anl.gov>
> To: Rajeev Jain <jain at mcs.anl.gov>
> Cc: cgma-dev at mcs.anl.gov
> Sent: Friday, September 24, 2010 17:19:56
> Subject: Re: [cgma-dev] .stp translator - Cubit license?
> It looks just license problem.
> Hong-Jun
> ----- "Rajeev Jain" <jain at mcs.anl.gov> wrote:
> > When I try to import a .stp file (attached) I see different behavior
> > with different versions of Cubit. Is it something to do with 32bit /
> > 64bit version? The messages that I get while importing are as follows:
> > 10.2 build 28 (64 bit version) - Doesn't work
> > CUBIT> import "/nfs/mcs-homes139/jain/Desktop/fuel.stp"
> > Extension is .stp, guessing import type
> > Geometry engine set to: ACIS Version 16.0.1.0
> > ERROR: The STEP translator is not licensed for this installation
> > ERROR: Errors importing STEP file
> > 10.2 build 24 (32 bit version) - works & runs the meshing script
> > CUBIT> import 'control.stp'
> > Reading STEP file 'control.stp'...
> > Read 2 ACIS Entities from the input file
> > WARNING: Entity name 'Open CASCADE STEP translator 6.3 1.1' is
> > invalid. Changed to 'Open_CASCADE_STEP_translator_6.3_1.1'
> > WARNING: Entity name 'Open CASCADE STEP translator 6.3 1.2' is
> > invalid. Changed to 'Open_CASCADE_STEP_translator_6.3_1.2'
> > Rajeev
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20100924/99491a5b/attachment.htm>
More information about the cgma-dev
