[cgma-dev] .stp translator - Cubit license?
hongjun at mcs.anl.gov hongjun at mcs.anl.gov
Fri Sep 24 17:33:19 CDT 2010
Yes. Among Cubits in ANL, only 32 bit version have the step license internally.
You may connect to several 32 bit machine (triumph ...) to run it in ANL nfs file system.
Hong-Jun
----- Original Message -----
To: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
Cc: cgma-dev at mcs.anl.gov
Sent: Friday, September 24, 2010 5:22:17 PM GMT -06:00 US/Canada Central
Subject: Re: [cgma-dev] .stp translator - Cubit license?
I don't recall talking any special license for Cubit 10.2 build 24 (32 bit version). Maybe it is something internal to Cubit's versions.
Rajeev
To: Rajeev Jain <jain at mcs.anl.gov>
Sent: Friday, September 24, 2010 17:19:56
It looks just license problem.
Hong-Jun
----- "Rajeev Jain" < jain at mcs.anl.gov > wrote:
> When I try to import a .stp file (attached) I see different behavior
> with different versions of Cubit. Is it something to do with 32bit /
> 64bit version? The messages that I get while importing are as follows:
> 10.2 build 28 (64 bit version) - Doesn't work
> CUBIT> import "/nfs/mcs-homes139/jain/Desktop/fuel.stp"
> Extension is .stp, guessing import type
> Geometry engine set to: ACIS Version 16.0.1.0
> ERROR: The STEP translator is not licensed for this installation
> ERROR: Errors importing STEP file
> 10.2 build 24 (32 bit version) - works & runs the meshing script
> CUBIT> import 'control.stp'
> Reading STEP file 'control.stp'...
> Read 2 ACIS Entities from the input file
> WARNING: Entity name 'Open CASCADE STEP translator 6.3 1.1' is
> invalid. Changed to 'Open_CASCADE_STEP_translator_6.3_1.1'
> WARNING: Entity name 'Open CASCADE STEP translator 6.3 1.2' is
> invalid. Changed to 'Open_CASCADE_STEP_translator_6.3_1.2'
> Rajeev
More information about the cgma-dev mailing list
