[cgma-dev] r4074 - cgm/trunk/test
jiangtao_ma at yahoo.com
Fri Aug 6 12:59:48 CDT 2010
Author: janehu
Date: 2010-08-06 12:59:48 -0500 (Fri, 06 Aug 2010)
New Revision: 4074
Modified:
cgm/trunk/test/Makefile.am
cgm/trunk/test/makept.cpp
Log:
Changes according to fix for merge_occ. Curve order has changed, makept has some change with change of curves.
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am 2010-08-06 17:57:40 UTC (rev 4073)
+++ cgm/trunk/test/Makefile.am 2010-08-06 17:59:48 UTC (rev 4074)
@@ -23,7 +23,7 @@
endif
endif
if build_OCC
- TESTS += modify makept r_w test_occ operation brick_occ #merge_occ
+ TESTS += modify makept r_w test_occ operation brick_occ merge_occ
endif
AM_CPPFLAGS =
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp 2010-08-06 17:57:40 UTC (rev 4073)
+++ cgm/trunk/test/makept.cpp 2010-08-06 17:59:48 UTC (rev 4074)
@@ -523,10 +523,10 @@
int num_loops = ref_face->ref_edge_loops(ref_edge_loops);
DLIList<RefEdge*> *ref_edges1;
ref_edges1 = ref_edge_loops.get();
- RefEdge* edge1 = ref_edges1->get();
- RefEdge* edge2 = ref_edges1->step_and_get();
- double angle = edge1->angle_between(edge2, ref_face);
- assert(fabs(angle - 1.57) < 0.001);
+ RefEdge* edge1 = ref_edges1->pop();
+ RefEdge* edge2 = ref_edges1->pop();
+ double angle = edge2->angle_between(edge1, ref_face);
+ assert(fabs(angle - 4.712) < 0.001);
//test for curve
CubitVector c_point, tangent, center;
@@ -643,17 +643,17 @@
// bounding box
d = ref_edge->measure();
- assert(fabs(d - 13.9987) < 0.001);
+ assert(fabs(d - 11.042) < 0.001);
ref_edge->get_param_range(lower,upper);
- assert(lower - 19988 <= 0 && fabs(upper-20001.998) < 0.001);
+ assert(lower - 2.6024 <= 0.0001 && fabs(upper-6.2832) < 0.001);
// paremeter range.
d = ref_edge->length_from_u(lower,upper);
d = ref_edge->length_from_u(lower/2+upper/2, upper);
- assert(fabs(d-6.99939) < 0.0001);
More information about the cgma-dev
