[cgma-dev] r4073 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Fri Aug 6 12:57:40 CDT 2010
Author: janehu
Date: 2010-08-06 12:57:40 -0500 (Fri, 06 Aug 2010)
New Revision: 4073
Modified:
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Fixed test case merge_occ
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2010-08-04 21:05:28 UTC (rev 4072)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2010-08-06 17:57:40 UTC (rev 4073)
@@ -2099,6 +2099,30 @@
       sense = (topo_face.Orientation() == TopAbs_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD);
     else
       sense = (topo_face.Orientation() == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED);
+    if(sense == CUBIT_REVERSED )
+      //When the loop has only one curve, the wire and face sense usually
+      //are the same, so don't need to reverse again.
+      //have to reverse wire direction and coedge sense for multi-curve situ.
+      DLIList<OCCLoop*> loops;
+      DLIList<OCCCoEdge*> coedges;
+      occ_surface->get_loops(loops);
+      for (int i = 0; i < loops.size(); i++)
+        OCCLoop* loop = loops.get_and_step();
+        coedges = loop->coedges();
+        if(coedges.size() == 1)
+          continue;
+        coedges.reverse();
+        for (int j = 0; j < coedges.size(); j++)
+          OCCCoEdge* coedge = coedges.get_and_step();
+          coedge->set_sense(coedge->sense() == CUBIT_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD);
+        loop->coedges(coedges);
     for(int i = 0; i < size; i++)
       coface = cofaces_old.get_and_step();
More information about the cgma-dev mailing list
