[cgma-dev] CGM iGeom bugs
Tim Tautges
tautges at mcs.anl.gov
Fri Mar 5 11:14:44 CST 2010
For the crashes and non-frees, please make sure there are tickets entered for them (along with tests that show the
problem, ideally). For the longer term ones, we need tickets too, just with different urgency.
- tim
James Porter wrote:
> On Thu, 2010-03-04 at 08:48 -0600, Jason Kraftcheck wrote:
>> I've noticed a few issues with the iGeom interface recently:
>> o many functions do not free allocated output arrays when they fail
>> o sweepEntAboutAxis always returns a body. If sweeping a curve,
>> shouldn't this return a surface?
>> o we still need to change to returning volumes rather than bodies
>> for iBase_REGION type.
> On this subject, there are also two problems I've noticed from the
> Python stuff:
> o second derivative isn't supported
> o iGeom_getPntRayIntsct always crashes; part of it is because some iGeom
> code assumes divide-by-zero errors don't throw a floating point
> exception, but there's also some problem in the Cubit code (on 10.2,
> at least).
> - Jim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the cgma-dev
