[cgma-dev] CGM iGeom bugs
James Porter
jvporter at wisc.edu
Thu Mar 4 14:42:59 CST 2010
On Thu, 2010-03-04 at 08:48 -0600, Jason Kraftcheck wrote:
> I've noticed a few issues with the iGeom interface recently:
> o many functions do not free allocated output arrays when they fail
> o sweepEntAboutAxis always returns a body. If sweeping a curve,
> shouldn't this return a surface?
> o we still need to change to returning volumes rather than bodies
> for iBase_REGION type.
On this subject, there are also two problems I've noticed from the
Python stuff:
o second derivative isn't supported
o iGeom_getPntRayIntsct always crashes; part of it is because some iGeom
code assumes divide-by-zero errors don't throw a floating point
exception, but there's also some problem in the Cubit code (on 10.2,
at least).
- Jim
More information about the cgma-dev
