[cgma-dev] r3563 - cgm/trunk/itaps
kraftche at cae.wisc.edu
Wed Mar 3 17:31:19 CST 2010
Author: kraftche
Date: 2010-03-03 17:31:19 -0600 (Wed, 03 Mar 2010)
New Revision: 3563
Modified:
cgm/trunk/itaps/iGeom_CGMA.cc
Log:
fix broken iGeom_getPntClsf and iGeom_getPntArrClsf
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2010-03-03 19:19:23 UTC (rev 3562)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2010-03-03 23:31:19 UTC (rev 3563)
@@ -190,8 +190,8 @@
DLIList<RefEntity*>& entities,
DLIList<double>& ray_params );
-static CubitStatus
-iGeom_get_point_containment( const CubitVector& pt, RefEntity*& entity );
+static RefEntity*
+iGeom_get_point_containment( const CubitVector& pt );
static int iGeom_get_nonmanifold_sense( const BasicTopologyEntity* child,
const BasicTopologyEntity* parent,
@@ -3162,8 +3162,8 @@
RefEntity** ptr = (RefEntity**)entity_handle;
const CubitVector pt(x,y,z);
- CubitStatus s = iGeom_get_point_containment( pt, *ptr );
- RETURN( (s == CUBIT_SUCCESS ? iBase_SUCCESS : iBase_FAILURE) );
+ *ptr = iGeom_get_point_containment( pt );
+ RETURN( iBase_SUCCESS );
void
@@ -3198,9 +3198,7 @@
for (int i = 0; i < count; ++i)
const CubitVector pt( *x, *y, *z );
- CubitStatus s = iGeom_get_point_containment( pt, array[i] );
- if (s != CUBIT_SUCCESS)
- result = iBase_FAILURE;
+ array[i] = iGeom_get_point_containment( pt );
x += step;
y += step;
z += step;
@@ -6447,72 +6445,100 @@
return CUBIT_SUCCESS;
-static CubitStatus
+static RefEntity* point_classification( const CubitVector& pt, RefVertex* vtx )
- int i;
+ return (pt - vtx->coordinates()).length_squared() > GEOMETRY_RESABS*GEOMETRY_RESABS ? 0 : vtx;
+static RefEntity* point_classification( const CubitVector& pt, RefEdge* edge )
+ CubitVector closest;
+ edge->closest_point_trimmed( pt, closest );
+ if ((pt - closest).length_squared() > GEOMETRY_RESABS*GEOMETRY_RESABS)
+ return 0;
- DLIList<RefVertex*> vertices;
- RefEntityFactory::instance()->ref_vertices( vertices );
- for (i = vertices.size(); i > 0; i--)
- RefVertex* vtx = vertices.get_and_step();
- if ((pt - vtx->coordinates()).length_squared() < GEOMETRY_RESABS*GEOMETRY_RESABS) {
- entity = vtx;
- return CUBIT_SUCCESS;
+ if (RefEntity* vtx = point_classification( pt, edge->start_vertex() ))
+ return vtx;
+ else if (RefEntity* vtx = point_classification( pt, edge->end_vertex() ))
+ return vtx;
+ else
+ return edge;
+static RefEntity* point_classification( const CubitVector& pt, RefFace* face )
+ CubitBox extents = face->bounding_box();
+ if (extents.distance_squared(pt) > GEOMETRY_RESABS*GEOMETRY_RESABS)
+ return 0;
+ face->find_closest_point_trimmed( pt, closest );
+ return 0;
DLIList<RefEdge*> edges;
- RefEntityFactory::instance()->ref_edges( edges );
+ face->ref_edges( edges );
edges.last();
- for (i = edges.size(); i > 0; --i)
- switch( edges.step_and_get()->point_containment( pt ) ) {
- case CUBIT_PNT_INSIDE:
- //case CUBIT_PNT_ON:
- case CUBIT_PNT_BOUNDARY:
- entity = edges.get();
- default:
+ for (int i = 0; i < edges.size(); ++i)
+ if (RefEntity* ent = point_classification( pt, edges.step_and_get() ))
+ return ent;
+ return face;
+static RefEntity* point_classification( const CubitVector& pt, Body* body )
+ CubitVector nonconst_pt(pt);
+ CubitPointContainment pc = body->point_containment( nonconst_pt );
+ if (CUBIT_PNT_INSIDE == pc)
+ return body;
+ else if (CUBIT_PNT_BOUNDARY != pc)
+ return 0;
+ // If we're here, then we're on the boundary.
+ // Find which boundary entity we're on.
DLIList<RefFace*> faces;
- RefEntityFactory::instance()->ref_faces( faces );
+ body->ref_faces( faces );
faces.last();
- for (i = faces.size(); i > 0; --i)
- switch( faces.step_and_get()->point_containment( pt ) ) {
- entity = faces.get();
- default:
+ for (int i = 0; i < faces.size(); ++i)
+ if (RefEntity* ent = point_classification( pt, faces.step_and_get() ))
+ return ent;
+ // We don't appear to be on any face. Is the tolerance for
+ // Body::point_classification something other than GEOMETRY_RESABS??
+ return body;
+static RefEntity*
+ DLIList<RefEntity*> ents;
+ gqt->get_free_ref_entities( ents );
+ ents.reset();
+ for (int i = 0; i < ents.size(); ++i)
+ if (RefVertex* vtx = dynamic_cast<RefVertex*>(ents.get_and_step()))
+ if (RefEntity* ent = point_classification( pt, vtx ))
+ return ent;
+ if (RefEdge* edge = dynamic_cast<RefEdge*>(ents.get_and_step()))
+ if (RefEntity* ent = point_classification( pt, edge ))
+ return ent;
+ if (RefFace* face = dynamic_cast<RefFace*>(ents.get_and_step()))
+ if (RefEntity* ent = point_classification( pt, face ))
+ return ent;
DLIList<Body*> bodies;
- RefEntityFactory::instance()->bodies( bodies );
- bodies.last();
- for (i = bodies.size(); i > 0; --i)
- CubitVector nonconst_pt(pt);
- switch( bodies.step_and_get()->point_containment( nonconst_pt ) ) {
- entity = dynamic_cast<RefVolume*>(bodies.get()->get_first_sense_entity_ptr()->get_basic_topology_entity_ptr());
- default:
+ gqt->bodies( bodies );
+ bodies.reset();
+ for (int i = 0; i < bodies.size(); ++i)
+ if (RefEntity* ent = point_classification( pt, bodies.get_and_step() ))
+ return ent;
- return CUBIT_FAILURE;
+ return 0;
More information about the cgma-dev
