[cgma-dev] 2D geometry
Rajeev Jain jain at mcs.anl.gov
Thu Feb 18 16:21:10 CST 2010
Can there be multiple iGeom instances in one program? On creating two instances, both instances get the same address, so I guess it is a bug?
Also, Is there a way to save some particular entities in a file.
From a 3D geometry I need to get all the faces with a particular Z-Coordinate. When I copy the face entity and delete the actual entity the faces are lost. I was trying to use iGeom_rmvPrntChld and then delete the actual entities, but that didn't work either.
 Rajeev
To: Rajeev Jain <jain at mcs.anl.gov>
Cc: cgma-dev at mcs.anl.gov
Sent: Thursday, February 18, 2010 14:31:35
Subject: Re: [cgma-dev] 2D geometry
Create the 3d thingy that has that 2d shape as a side, then copy the face entity you want.
- tim
Rajeev Jain wrote:
> Is there a way to create 2D geometries using iGeom?
> createBrick or createPrism function don't take zero for height.
> Thanks.
>  Rajeev
> New Email addresses available on Yahoo! <http://sg.rd.yahoo.com/aa/mail/domainchoice/mail/signature/*http://mail.promotions.yahoo.com/newdomains/aa/>
> Get the Email name you've always wanted on the new @ymail and @rocketmail.
> Hurry before someone else does!
  steadfast, because he trusts in you."               Isaiah 26:3
             Tim Tautges            Argonne National Laboratory
         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
         phone: (608) 263-8485      1500 Engineering Dr.
           fax: (608) 263-4499      Madison, WI 53706
      Get your new Email address!
Grab the Email name you&#39;ve always wanted before someone else does!
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20100218/1fa47cbc/attachment.htm>
More information about the cgma-dev mailing list
