[cgma-dev] r3456 - cgm/trunk/test
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Jan 21 17:16:01 CST 2010
Author: kraftche
Date: 2010-01-21 17:16:01 -0600 (Thu, 21 Jan 2010)
New Revision: 3456
Modified:
   cgm/trunk/test/webcut.cpp
Log:
Fixes to test/webcut:
o Fix one of the issues when linked with cubit (don't assume order of bodies)
o Improve output so that it is easier to figure out which test failed
o Remove some unnecessary code: abort if file read fails
o Consolidate some duplicate code
Modified: cgm/trunk/test/webcut.cpp
--- cgm/trunk/test/webcut.cpp	2010-01-21 17:04:25 UTC (rev 3455)
+++ cgm/trunk/test/webcut.cpp	2010-01-21 23:16:01 UTC (rev 3456)
@@ -34,7 +34,8 @@
 #define XSTRINGIFY(S) #S
 // forward declare some functions used and defined later
-CubitStatus read_geometry(int, char **);
+void read_geometry(int, char **);
+void read_model6( Body*& brick, Body*& sheet );
 CubitStatus evaluate_overlaps();
 CubitStatus imprint_bodies();
 CubitStatus print_unmerged_surfaces();
@@ -51,7 +52,7 @@
 CubitStatus webcut_with_sweep_surfaces_along_curve();
 CubitStatus webcut_with_sweep_surfaces_perp();
 // macro for printing a separator line
-#define PRINT_SEPARATOR   PRINT_INFO("=======================================\n");
+#define PRINT_SEPARATOR   PRINT_INFO("===================%s:%d===================\n",__FILE__,__LINE__);
 // main program - initialize, then send to proper function
@@ -91,7 +92,7 @@
 /// Arguments: file name(s) of geometry files in which to look
-CubitStatus read_geometry(int num_files, const char **argv)
+void read_geometry(int num_files, const char **argv)
   CubitStatus status = CUBIT_SUCCESS;
   GeometryQueryTool *gti = GeometryQueryTool::instance();
@@ -99,19 +100,52 @@
   int i;
     // For each file, open and read the geometry
-  PRINT_SEPARATOR;
   for (i = 0; i < num_files; i++) {
     status = gti->import_solid_model(argv[i], "ACIS_SAT");
     if (status != CUBIT_SUCCESS) {
       PRINT_ERROR("Problems reading geometry file %s.\n", argv[i]);
+      abort();
-  PRINT_SEPARATOR;
-  return CUBIT_SUCCESS;
+  if (gti->num_bodies() == 0) {
+    PRINT_ERROR("No bodies read; aborting.\n");
+    abort();
+void read_model6( Body*& volume, Body*& sheet )
+  const char *filename = STRINGIFY(SRCDIR) "/model6.sat";
+  read_geometry( 1, &filename );
+  DLIList<Body*> bodies;
+  GeometryQueryTool::instance()->bodies(bodies);
+  volume = sheet = 0;
+  for (int i = 0; i < bodies.size(); ++i, bodies.step()) {
+    DLIList<RefVolume*> vols;
+    bodies.get()->ref_volumes( vols );
+    if (vols.size() != 1) {
+      PRINT_ERROR("Unexpected number of volumes in body read from file: %s\n", filename);
+      abort();
+    if (vols.get()->is_sheet()) {
+      if (sheet) {
+        PRINT_ERROR("Unexpected number of sheet bodies read from file: %s\n",filename);
+        abort();
+      sheet = bodies.get();
+    else {
+      if (volume) {
+        PRINT_ERROR("Unexpected number of non-sheet bodies read from file: %s\n",filename);
+        abort();
+      volume = bodies.get();
 CubitStatus webcut_with_brick()
@@ -119,14 +153,8 @@
   // Read in the geometry from files specified on the command line
   const char *argv = STRINGIFY(SRCDIR) "/model2.sat";
-  CubitStatus status = read_geometry(1, &argv);
-  if (status == CUBIT_FAILURE) exit(1);
-  else if (gti->num_bodies() == 0) {
-    PRINT_WARNING("No bodies read; exiting.\n");
-    int ret_val = ( CubitMessage::instance()->error_count() );
-    exit(ret_val);
+  PRINT_SEPARATOR;
+  read_geometry(1, &argv);
   //int num_bodies = gti->num_bodies();
   DLIList<Body*> old_bodies, new_bodies;
@@ -151,18 +179,7 @@
   rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
                                  num_ents_exported, cubit_version);
-  //delete all entities
-  DLIList<Body*> bodies;
-  gti->bodies(bodies);
-  DLIList<RefEntity*> free_entities;
-  gti->get_free_ref_entities(free_entities);
-  gti->delete_Body(bodies);
-  for (int j = free_entities.size(); j--;)
-      gti->delete_RefEntity( free_entities.get_and_step());
+  gti->delete_geometry();
   return rsl;
@@ -174,14 +191,8 @@
-    exit(ret_val);
+  PRINT_SEPARATOR;
   gti->bodies(old_bodies);
@@ -202,18 +213,7 @@
   return rsl;
@@ -225,15 +225,9 @@
+  PRINT_SEPARATOR;
-    exit(ret_val);
   old_bodies.reset();
@@ -255,18 +249,7 @@
   return rsl;
@@ -279,14 +262,8 @@
   const char *argv = STRINGIFY(SRCDIR) "/huge.sat";
-    exit(ret_val);
+  PRINT_SEPARATOR;
@@ -323,18 +300,7 @@
-  free_entities.clean_out();
   return rsl;
@@ -345,15 +311,9 @@
   const char *argv = STRINGIFY(SRCDIR) "/model3.sat";
+  PRINT_SEPARATOR;
-    exit(ret_val);
@@ -383,18 +343,7 @@
   return rsl;
@@ -405,14 +354,8 @@
-    exit(ret_val);
+  PRINT_SEPARATOR;
@@ -454,18 +397,7 @@
   return rsl;
@@ -476,14 +408,8 @@
   const char *argv = STRINGIFY(SRCDIR) "/model4.sat";
-    exit(ret_val);
+  PRINT_SEPARATOR;
@@ -511,18 +437,7 @@
   return rsl;
@@ -533,15 +448,9 @@
   const char *argv = STRINGIFY(SRCDIR) "/model5.sat";
+  PRINT_SEPARATOR;
-    exit(ret_val);
@@ -564,12 +473,7 @@
   return rsl;
@@ -580,14 +484,8 @@
   const char *argv = STRINGIFY(SRCDIR) "/model7.sat";
-    exit(ret_val);
+  PRINT_SEPARATOR;
@@ -599,8 +497,7 @@
   old_bodies.remove()->ref_faces(faces);
   CubitVector center(4.0,14.0,14.0);
-  CubitVector axis;
-  axis.set(0.,-1.,0.);
+  CubitVector axis(0.,-1.,0.);
   // set 7th parameter to be false to indicate of to_next_surf = false
   CubitStatus rsl= gmti->webcut_with_sweep_surfaces_rotated(old_bodies,faces,center,axis,1.6,NULL,true,new_bodies);
@@ -615,12 +512,7 @@
   return rsl;
@@ -629,29 +521,17 @@
   GeometryModifyTool *gmti = GeometryModifyTool::instance();
-  // Read in the geometry from files specified on the command line
-  const char *argv = STRINGIFY(SRCDIR) "/model6.sat";
-    exit(ret_val);
+  // Read file containing one block and one sheet body
+  PRINT_SEPARATOR;
+  Body *vol, *sheet;
+  read_model6( vol, sheet );
-  gti->bodies(old_bodies);
-  old_bodies.reset();
-  old_bodies.step();
+  old_bodies.append( vol );
   DLIList<RefFace*> faces;
-  old_bodies.remove()->ref_faces(faces);
+  sheet->ref_faces( faces );
-  CubitVector axis;
-  axis.set(1.,0.,0.);
+  CubitVector axis(1.,0.,0.);
   CubitStatus rsl= gmti->webcut_with_sweep_surfaces(old_bodies,faces,axis,false,true,false, false,NULL,NULL,new_bodies);
   if (rsl== CUBIT_FAILURE)
@@ -665,12 +545,7 @@
   return rsl;
@@ -679,25 +554,15 @@
-    exit(ret_val);
+  PRINT_SEPARATOR;
   //use curve 2 as the sweep along curve
   DLIList<RefEdge*> temp_curves;
@@ -709,8 +574,7 @@
      edge_to_sweep_along = temp_curves.get_and_step();
-  CubitVector axis;
   CubitStatus rsl= gmti->webcut_with_sweep_surfaces(old_bodies,faces,axis,false, true,false,false,NULL,
                                                   edge_to_sweep_along,new_bodies);
@@ -725,12 +589,7 @@
   return rsl;
@@ -739,29 +598,17 @@
-    exit(ret_val);
+  PRINT_SEPARATOR;
-  CubitVector axis;
   CubitStatus rsl= gmti->webcut_with_sweep_surfaces(old_bodies,faces,axis,true,true,true, false,NULL,NULL,new_bodies);
@@ -775,12 +622,7 @@
   return rsl;
More information about the cgma-dev mailing list
