[cgma-dev] buildbot failure in Fathom on cgm-distcheck
cgma-dev at lists.mcs.anl.gov
Thu Jan 21 00:23:54 CST 2010
The Fathomatic has detected a failed build of cgm-distcheck on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/cgm-distcheck/builds/0
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
make check-TESTS
make[6]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-distcheck/build/cgma-10.2.3/_build/itaps'
All 0 tests passed
Making check in test
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-distcheck/build/cgma-10.2.3/_build/test'
make init sheet brick
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/cgm-distcheck/build/cgma-10.2.3/_build/test'
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../test -I.. -I../geom/parallel -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -DSRCDIR=../../test -Wall -pipe -pedantic -O2 -DNDEBUG -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o ../../test/init.cpp
mv -f .deps/init.Tpo .deps/init.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o init init.o ../libcgm.la -lm
mkdir .libs
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o init init.o ../.libs/libcgm.a -ldl -lm
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../test -I.. -I../geom/parallel -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -DSRCDIR=../../test -Wall -pipe -pedantic -O2 -DNDEBUG -MT sheet.o -MD -MP -MF .deps/sheet.Tpo -c -o sheet.o ../../test/sheet.cpp
mv -f .deps/sheet.Tpo .deps/sheet.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o sheet sheet.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o sheet sheet.o ../.libs/libcgm.a -ldl -lm
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../test -I.. -I../geom/parallel -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -DSRCDIR=../../test -Wall -pipe -pedantic -O2 -DNDEBUG -MT brick.o -MD -MP -MF .deps/brick.Tpo -c -o brick.o ../../test/brick.cpp
../../test/brick.cpp: In function 'void check_valid_face(RefFace*)':
../../test/brick.cpp:226: warning: unused variable 's'
../../test/brick.cpp: In function 'void check_valid_loop(Loop*)':
../../test/brick.cpp:253: warning: unused variable 'common_1'
../../test/brick.cpp:256: warning: unused variable 'common_2'
../../test/brick.cpp: In function 'int main(int, char**)':
../../test/brick.cpp:93: warning: 'idx' may be used uninitialized in this function
mv -f .deps/brick.Tpo .deps/brick.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o brick brick.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o brick brick.o ../.libs/libcgm.a -ldl -lm
make check-TESTS
ERROR: initialize_cgma() called again, but default engines differ.
PASS: init
Facet-based geometry modification is a beta capability.
ERROR: This capability is currently disabled.
To enable this capability, issue the command 'set facet_modify on'.
ERROR: In GeometryModifyTool::sphere
Problems building a volume from the sphere.
Sphere creation failed for engine (17FacetModifyEngine)
FAIL: sheet
ERROR: In GeometryModifyTool::brick
Problem creating a brick.
/bin/sh: line 4: 18862 Segmentation fault ${dir}$tst
FAIL: brick
2 of 3 tests failed
sincerely,
-The Fathomatic
More information about the cgma-dev
