[cgma-dev] r3402 - cgm/trunk/itaps
    James Porter
    jvporter at wisc.edu
    Mon Dec  7 01:55:05 CST 2009
> If you must clean up white space and line wrapping and such, it would
> be helpful if you would keep such checkins separate from changes to
> documentation content or code functionality.  For example, all of your
> changes in this checkin will likely be lost unless we push these
> changes to the upstream RPI repository.  If someone were inclined to
> review the changes you made before doing so, they will be hindered by
> the 4000 lines of whitespace changes in this checkin.
Er, sorry about that. If you prefer, I could extract the actual content changes and package that up into a diff for application elsewhere.
- Jim
More information about the cgma-dev
