[cgma-dev] r3402 - cgm/trunk/itaps
jvporter at wisc.edu jvporter at wisc.edu
Sun Dec 6 00:18:11 CST 2009
Author: jvporter
Date: 2009-12-06 00:18:10 -0600 (Sun, 06 Dec 2009)
New Revision: 3402
Modified:
   cgm/trunk/itaps/iGeom.h
Log:
Update documentation in iGeom.h to be complete/correct, and consistent
with iMesh's style
Modified: cgm/trunk/itaps/iGeom.h
--- cgm/trunk/itaps/iGeom.h	2009-12-06 05:48:51 UTC (rev 3401)
+++ cgm/trunk/itaps/iGeom.h	2009-12-06 06:18:10 UTC (rev 3402)
@@ -85,7 +85,7 @@
   typedef struct iGeom_EntityArrIterator_Private* iGeom_EntityArrIterator;
-    /**\brief  Get a description of the error returned from the last iGeom function
+    /**\brief  Get a description of the error returned from the last iGeom call
      * Get a description of the error returned from the last iGeom function
      * \param instance iGeom instance handle
@@ -107,14 +107,13 @@
      * \param *error_type Error type returned from last iGeom function
      * \param *err Pointer to error type returned from function
-  void iGeom_getErrorType(iGeom_Instance instance,
-                          /*out*/ int *error_type,
-                          int *err);
+  void iGeom_getErrorType( iGeom_Instance instance,
+                           /*out*/ int *error_type,
+                           int *err );
     /**\brief  Construct a new iGeom instance
-     * Construct a new iGeom instance, using implementation-specific
-     * options
+     * Construct a new iGeom instance, using implementation-specific options
      * \param options Pointer to implementation-specific options string
      * \param instance Pointer to iGeom instance handle returned from function
@@ -131,7 +130,8 @@
      * \param instance iGeom instance to be destroyed
-  void iGeom_dtor( iGeom_Instance instance, int* err );
+  void iGeom_dtor( iGeom_Instance instance,
+                   int* err );
     /**\brief  Load a geom from a file
@@ -147,7 +147,7 @@
      * \param name_len Length of the file name character string
      * \param options_len Length of the options character string
-  void iGeom_load( iGeom_Instance,
+  void iGeom_load( iGeom_Instance instance,
                    char const* name,
                    char const* options,
                    int* err,
@@ -166,7 +166,7 @@
-  void iGeom_save( iGeom_Instance,
+  void iGeom_save( iGeom_Instance instance,
                    char const* name,
                    int* err,
@@ -181,20 +181,23 @@
      * \param root_set Pointer to set handle returned from function
-  void iGeom_getRootSet( iGeom_Instance,
+  void iGeom_getRootSet( iGeom_Instance instance,
                          iBase_EntitySetHandle* root_set,
                          int* err );
-/**\brief Get the bounding box of the entire model
- * Get the bounding box of the entire model
- * \param min_x Minimum coordinate of bounding box
- * \param min_y Minimum coordinate of bounding box
- * \param min_z Minimum coordinate of bounding box
- * \param max_x Maximum coordinate of bounding box
- * \param max_y Maximum coordinate of bounding box
- * \param max_z Maximum coordinate of bounding box
-  void iGeom_getBoundBox( iGeom_Instance,
+    /**\brief Get the bounding box of the entire model
+     * Get the bounding box of the entire model
+     * \param instance iGeom instance handle
+     * \param min_x Minimum coordinate of bounding box
+     * \param min_y Minimum coordinate of bounding box
+     * \param min_z Minimum coordinate of bounding box
+     * \param max_x Maximum coordinate of bounding box
+     * \param max_y Maximum coordinate of bounding box
+     * \param max_z Maximum coordinate of bounding box
+     * \param *err Pointer to error type returned from function
+  void iGeom_getBoundBox( iGeom_Instance instance,
                           double* min_x,
                           double* min_y,
                           double* min_z,
@@ -203,13 +206,11 @@
                           double* max_z,
                           int* err );
-    /**\brief  Get entities of specific type and/or topology in set or instance
+    /**\brief  Get entities of specific type in set or instance
-     * Get entities of specific type and/or topology in set or instance.  All
-     * entities of a given type or topology are requested by specifying
-     * iBase_ALL_TOPOLOGIES or iBase_ALL_TYPES, respectively.  Specified type
-     * or topology must be a value in the iBase_EntityType or iBase_EntityTopology
-     * enumeration, respectively.
+     * Get entities of specific type in set or instance.  All entities are
+     * requested by specifying iBase_ALL_TYPES.  Specified type must be a value
+     * in the iBase_EntityType enumeration.
      * \param entity_set_handle Entity set being queried
      * \param entity_type Type of entities being requested
@@ -218,7 +219,8 @@
      *        from function
      * \param *entity_handles_allocated Pointer to allocated size of
      *        entity_handles array
-     * \param *entity_handles_size Pointer to occupied size of entity_handles array
+     * \param *entity_handles_size Pointer to occupied size of entity_handles
+     *        array
   void iGeom_getEntities( iGeom_Instance instance,
@@ -229,13 +231,14 @@
                           int* entity_handles_size,
                           int* err );
-    /**\brief  Get the number of entities with the specified type in the instance or set
+    /**\brief  Get the number of entities with the specified type in the
+     *         instance or set
      * Get the number of entities with the specified type in the instance
      * or set.  If entity set handle is zero, return information for instance,
      * otherwise for set.  Value of entity type must be from the
-     * iBase_EntityType enumeration.  If iBase_ALL_TYPES is specified,
-     * total number of entities (excluding entity sets) is returned.
+     * iBase_EntityType enumeration.  If iBase_ALL_TYPES is specified, total
+     * number of entities (excluding entity sets) is returned.
      * \param entity_type Type of entity requested
@@ -250,8 +253,8 @@
     /**\brief  Get the entity type for the specified entity
-     * Get the entity type for the specified entity.  Types
-     * returned are values in the iBase_EntityType enumeration.
+     * Get the entity type for the specified entity.  Type returned is a value
      * \param entity_handle entity handle being queried
      * \param *type Pointer to location at which to store the returned type
@@ -264,8 +267,8 @@
     /**\brief  Get the entity type for the specified entities
-     * Get the entity type for the specified entities.  Types
+     * Get the entity type for the specified entities.  Types returned are
+     * values in the iBase_EntityType enumeration.
      * \param entity_handles Array of entity handles being queried
      * \param entity_handles_size Number of entities in entity_handles array
@@ -338,18 +341,20 @@
                         int* offset_size,
                         int* err );
-/**\brief Get "2nd order" adjacencies to an entity
- * Get "2nd order" adjacencies to an entity, that is, from an entity, through
- * other entities of a specified "bridge" dimension, to other entities of another
- * specified "to" dimension.
- * \param entity_handle Entity from which adjacencies are requested
- * \param bridge_dimension Bridge dimension for 2nd order adjacencies
- * \param to_dimension Dimension of adjacent entities returned
- * \param adjacent_entities Adjacent entities
- * \param adjacent_entities_allocated Allocated size of returned array
- * \param adjacent_entities_size Occupied size of returned array
- * \param err
+    /**\brief  Get "2nd order" adjacencies to an entity
+     * Get "2nd order" adjacencies to an entity, that is, from an entity,
+     * through other entities of a specified "bridge" dimension, to other
+     * entities of another specified "to" dimension.
+     * \param entity_handle Entity from which adjacencies are requested
+     * \param bridge_dimension Bridge dimension for 2nd order adjacencies
+     * \param to_dimension Dimension of adjacent entities returned
+     * \param adjacent_entities Adjacent entities
+     * \param adjacent_entities_allocated Allocated size of returned array
+     * \param adjacent_entities_size Occupied size of returned array
   void iGeom_getEnt2ndAdj( iGeom_Instance instance,
                            iBase_EntityHandle entity_handle,
                            int bridge_dimension,
@@ -359,24 +364,26 @@
                            int* adjacent_entities_size,
                            int* err );
-/**\brief Get "2nd order" adjacencies to an array of entities
- * Get "2nd order" adjacencies to an array of entities, that is, from each entity, through
- * \param entity_handles Entities from which adjacencies are requested
- * \param entity_handles_size Number of entities whose adjacencies are requested
- * \param adj_entity_handles Adjacent entities
- * \param adj_entity_handles_allocated Allocated size of returned array
- * \param adj_entity_handles_size Occupied size of returned array
- * \param offset Offset[i] is offset into adj_entity_handles of 2nd order
- *        adjacencies of ith entity in entity_handles
- * \param offset_allocated Allocated size of offset array
- * \param offset_size Occupied size of offset array
- * \param err
+    /**\brief  Get "2nd order" adjacencies to an array of entities
+     * Get "2nd order" adjacencies to an array of entities, that is, from each
+     * entity, through other entities of a specified "bridge" dimension, to
+     * other entities of another specified "to" dimension.
+     * \param entity_handles Entities from which adjacencies are requested
+     * \param entity_handles_size Number of entities whose adjacencies are
+     *        requested
+     * \param adj_entity_handles Adjacent entities
+     * \param adj_entity_handles_allocated Allocated size of returned array
+     * \param adj_entity_handles_size Occupied size of returned array
+     * \param offset Offset[i] is offset into adj_entity_handles of 2nd order
+     *        adjacencies of ith entity in entity_handles
+     * \param offset_allocated Allocated size of offset array
+     * \param offset_size Occupied size of offset array
   void iGeom_getArr2ndAdj( iGeom_Instance instance,
                            iBase_EntityHandle const* entity_handles,
                            int entity_handles_size,
@@ -390,32 +397,37 @@
                            int* offset_size,
                            int* err );
-/**\brief Return whether two entities are adjacent
- * Return whether two entities are adjacent.
- * \param entity_handle1 First entity queried
- * \param entity_handle2 Second entity queried
- * \param are_adjacent If returned non-zero, entities are adjacent, otherwise
- *        they are not
- * \param err
+    /**\brief  Return whether two entities are adjacent
+     * Return whether two entities are adjacent.
+     * \param entity_handle1 First entity queried
+     * \param entity_handle2 Second entity queried
+     * \param are_adjacent If returned non-zero, entities are adjacent,
+     *        otherwise they are not
   void iGeom_isEntAdj( iGeom_Instance instance,
                        iBase_EntityHandle entity_handle1,
                        iBase_EntityHandle entity_handle2,
                        int* are_adjacent,
                        int* err );
-/**\brief Return whether entity pairs are adjacent
- * Return whether entity pairs are adjacent, i.e. if entity_handles_1[i] is
- * adjacent to entity_handles_2[i].  This function requires entity_handles_1_size
- * and entity_handles_2_size to be equal.
- * \param entity_handles_1 First array of entities
- * \param entity_handles_1_size Number of entities in first array
- * \param entity_handles_2 Second array of entities
- * \param entity_handles_2_size Number of entities in second array
- * \param is_adjacent_info Array of flags returned from function
- * \param is_adjacent_info_allocated Allocated size of flags array
- * \param is_adjacent_info_size Occupied size of flags array
+    /**\brief  Return whether entity pairs are adjacent
+     * Return whether entity pairs are adjacent, i.e. if entity_handles_1[i] is
+     * adjacent to entity_handles_2[i].  This function requires
+     * entity_handles_1_size and entity_handles_2_size to be equal.
+     * \param entity_handles_1 First array of entities
+     * \param entity_handles_1_size Number of entities in first array
+     * \param entity_handles_2 Second array of entities
+     * \param entity_handles_2_size Number of entities in second array
+     * \param is_adjacent_info Array of flags returned from function
+     * \param is_adjacent_info_allocated Allocated size of flags array
+     * \param is_adjacent_info_size Occupied size of flags array
   void iGeom_isArrAdj( iGeom_Instance instance,
                        iBase_EntityHandle const* entity_handles_1,
                        int entity_handles_1_size,
@@ -426,24 +438,31 @@
                        int* is_adjacent_info_size,
                        int* err );
-/**\brief DON'T KNOW WHAT THIS FUNCTION IS
- * \param topo_level_out
+    /**\brief  Return the topology level of the geometry
+     * Return the topology level of the geometry as an integer, where 0 = basic
+     * entities only, 1 = manifold entities, 2 = non-manifold entities.
+     * \param topo_level_out The topology level
   void iGeom_getTopoLevel( iGeom_Instance instance,
                            int* topo_level_out,
                            int* err );
-/**\brief Get closest point to an entity
- * Get closest point to a specified position on an entity
- * \param entity_handle Entity being queried
- * \param near_x Coordinates of starting point
- * \param near_y Coordinates of starting point
- * \param near_z Coordinates of starting point
- * \param on_x Closest point on entity
- * \param on_y Closest point on entity
- * \param on_z Closest point on entity
+    /**\brief  Get closest point to an entity
+     * Get closest point to a specified position on an entity
+     * \param entity_handle Entity being queried
+     * \param near_x Coordinates of starting point
+     * \param near_y Coordinates of starting point
+     * \param near_z Coordinates of starting point
+     * \param on_x Closest point on entity
+     * \param on_y Closest point on entity
+     * \param on_z Closest point on entity
   void iGeom_getEntClosestPt( iGeom_Instance instance,
                               double near_x,
@@ -454,22 +473,24 @@
                               double* on_z,
                               int* err );
-/**\brief Get closest point for an array of entities and points
- * Get closest point for an array of entities and points.  If either the number
- * of entities or number of coordinate triples is unity, then all points or
- * entities are queried for that entity or point, respectively, otherwise each
- * point corresponds to each entity.  storage_order should be a value in
- * the iBase_StorageOrder enum; if input as iBase_UNKNOWN, order is in native order
- * with respect to implementation.
- * \param entity_handles Entity(ies) being queried
- * \param entity_handles_size Number of entities being queried
- * \param storage_order Storage order of input points
- * \param near_coordinates Coordinates of starting point(s)
- * \param near_coordinates_size Number of values in near_coordinates array
- * \param on_coordinates Coordinates of closest points
- * \param on_coordinates_allocated Allocated size of closest point array
- * \param on_coordinates_size Occupied size of closest point array
+    /**\brief  Get closest point for an array of entities and points
+     * Get closest point for an array of entities and points.  If either the
+     * number of entities or number of coordinate triples is unity, then all
+     * points or entities are queried for that entity or point, respectively,
+     * otherwise each point corresponds to each entity.  storage_order should be
+     * a value in the iBase_StorageOrder enum.
+     * \param entity_handles Entity(ies) being queried
+     * \param entity_handles_size Number of entities being queried
+     * \param storage_order Storage order of input points
+     * \param near_coordinates Coordinates of starting point(s)
+     * \param near_coordinates_size Number of values in near_coordinates array
+     * \param on_coordinates Coordinates of closest points
+     * \param on_coordinates_allocated Allocated size of closest point array
+     * \param on_coordinates_size Occupied size of closest point array
   void iGeom_getArrClosestPt( iGeom_Instance instance,
@@ -481,17 +502,19 @@
                               int* on_coordinates_size,
                               int* err );
-/**\brief Get the normal vector on an entity at the given position
- * Get the normal vector on an entity at the given position.
- * \param x Coordinates of starting point
- * \param y Coordinates of starting point
- * \param z Coordinates of starting point
- * \param nrml_i Normal vector at starting point
- * \param nrml_j Normal vector at starting point
- * \param nrml_k Normal vector at starting point
-  void iGeom_getEntNrmlXYZ( iGeom_Instance,
+    /**\brief  Get the normal vector on an entity at the given position
+     * Get the normal vector on an entity at the given position.
+     * \param x Coordinates of starting point
+     * \param y Coordinates of starting point
+     * \param z Coordinates of starting point
+     * \param nrml_i Normal vector at starting point
+     * \param nrml_j Normal vector at starting point
+     * \param nrml_k Normal vector at starting point
+  void iGeom_getEntNrmlXYZ( iGeom_Instance instance,
                             double x,
                             double y,
@@ -501,23 +524,25 @@
                             double* nrml_k,
                             int* err );
-/**\brief Get the normal vector on an entity(ies) at given position(s)
- * Get the normal vector on an entity(ies) at given position(s).  If either the
- * number of entities or number of coordinate triples is unity, then all points or
- * \param storage_order Storage order of coordinates
- * \param coordinates Starting coordinates
- * \param coordinates_size Number of values in coordinates array
- * \param normals Normal coordinates
- * \param normals_allocated Allocated size of normals array
- * \param normals_size Occupied size of normals array
-  void iGeom_getArrNrmlXYZ( iGeom_Instance,
+    /**\brief  Get the normal vector on an entity(ies) at given position(s)
+     * Get the normal vector on an entity(ies) at given position(s).  If either
+     * the number of entities or number of coordinate triples is unity, then all
+     * \param storage_order Storage order of coordinates
+     * \param coordinates Starting coordinates
+     * \param coordinates_size Number of values in coordinates array
+     * \param normals Normal coordinates
+     * \param normals_allocated Allocated size of normals array
+     * \param normals_size Occupied size of normals array
+  void iGeom_getArrNrmlXYZ( iGeom_Instance instance,
                             int storage_order,
@@ -528,20 +553,24 @@
                             int* normals_size,
                             int* err );
-/**\brief Get the normal vector AND closest point on an entity at given position
- * Get the normal vector AND closest point on an entity at a given position.
- * \param x Starting coordinates
- * \param y Starting coordinates
- * \param z Starting coordinates
- * \param pt_x Closest point
- * \param pt_y Closest point
- * \param pt_z Closest point
- * \param nrml_i Normal at closest point
- * \param nrml_j Normal at closest point
- * \param nrml_k Normal at closest point
-  void iGeom_getEntNrmlPlXYZ( iGeom_Instance,
+    /**\brief  Get the normal vector AND closest point on an entity at given
+     *         position
+     * Get the normal vector AND closest point on an entity at a given position.
+     * \param x Starting coordinates
+     * \param y Starting coordinates
+     * \param z Starting coordinates
+     * \param pt_x Closest point
+     * \param pt_y Closest point
+     * \param pt_z Closest point
+     * \param nrml_i Normal at closest point
+     * \param nrml_j Normal at closest point
+     * \param nrml_k Normal at closest point
+  void iGeom_getEntNrmlPlXYZ( iGeom_Instance instance,
                               double x,
                               double y,
@@ -554,26 +583,29 @@
                               double* nrml_k,
                               int* err );
-/**\brief Get the normal vector AND closest point on an entity(ies) at given position(s)
- * Get the normal vector AND closest point on an entity(ies) at given position(s).  If either the
- * \param entity_handles_size Number of entity(ies) being queried
- * \param storage_order Storage order in near_coordinates array
- * \param near_coordinates Starting coordinates
- * \param on_coordinates Closest point array
- * \param normals Normal array
- * \param normals_allocated Allocated size of normal array
- * \param normals_size Occupied size of normal array
-  void iGeom_getArrNrmlPlXYZ( iGeom_Instance,
+    /**\brief Get the normal vector AND closest point on an entity(ies) at
+     *        given position(s)
+     * Get the normal vector AND closest point on an entity(ies) at given
+     * position(s).  If either the number of entities or number of coordinate
+     * triples is unity, then all points or entities are queried for that entity
+     * or point, respectively, otherwise each point corresponds to each entity.
+     * storage_order should be a value in the iBase_StorageOrder enum.
+     * \param entity_handles_size Number of entity(ies) being queried
+     * \param storage_order Storage order in near_coordinates array
+     * \param near_coordinates Starting coordinates
+     * \param on_coordinates Closest point array
+     * \param normals Normal array
+     * \param normals_allocated Allocated size of normal array
+     * \param normals_size Occupied size of normal array
+  void iGeom_getArrNrmlPlXYZ( iGeom_Instance instance,
                               int storage_order,
@@ -587,17 +619,20 @@
                               int* normals_size,
                               int* err );
-/**\brief Get the tangent vector on an entity at given position
- * Get the tangent vector on an entity at a given position.
- * \param tgnt_i Tangent at closest point
- * \param tgnt_j Tangent at closest point
- * \param tgnt_k Tangent at closest point
-  void iGeom_getEntTgntXYZ( iGeom_Instance,
+    /**\brief  Get the tangent vector on an entity at given position
+     * Get the tangent vector on an entity at a given position.
+     * \param tgnt_i Tangent at closest point
+     * \param tgnt_j Tangent at closest point
+     * \param tgnt_k Tangent at closest point
+  void iGeom_getEntTgntXYZ( iGeom_Instance instance,
                             double x,
                             double y,
@@ -607,23 +642,25 @@
                             double* tgnt_k,
                             int* err );
-/**\brief Get the tangent vector on an entity(ies) at given position(s)
- * Get the tangent vector on an entity(ies) at given position(s).  If either the
- * \param tangents Tangent coordinates
- * \param tangents_allocated Allocated size of tangents array
- * \param tangents_size Occupied size of tangents array
-  void iGeom_getArrTgntXYZ( iGeom_Instance,
+    /**\brief  Get the tangent vector on an entity(ies) at given position(s)
+     * Get the tangent vector on an entity(ies) at given position(s).  If either
+     * \param tangents Tangent coordinates
+     * \param tangents_allocated Allocated size of tangents array
+     * \param tangents_size Occupied size of tangents array
+  void iGeom_getArrTgntXYZ( iGeom_Instance instance,
                             int storage_order,
@@ -634,21 +671,25 @@
                             int* tangents_size,
                             int* err );
-/**\brief Get the two principle curvature vectors for a face at a point
- * Get the two principle curvature vectors for a face at a point.  Magnitudes of
- * vectors are curvature, directions are directions of principal curvatures.
- * \param face_handle Face being queried
- * \param x Position being queried
- * \param y Position being queried
- * \param z Position being queried
- * \param cvtr1_i Maximum curvature vector
- * \param cvtr1_j Maximum curvature vector
- * \param cvtr1_k Maximum curvature vector
- * \param cvtr2_i Minimum curvature vector
- * \param cvtr2_j Minimum curvature vector
- * \param cvtr2_k Minimum curvature vector
-  void iGeom_getFcCvtrXYZ( iGeom_Instance,
+    /**\brief  Get the two principle curvature vectors for a face at a point
+     * Get the two principle curvature vectors for a face at a point.
+     * Magnitudes of vectors are curvature, directions are directions of
+     * principal curvatures.
+     * \param face_handle Face being queried
+     * \param x Position being queried
+     * \param y Position being queried
+     * \param z Position being queried
+     * \param cvtr1_i Maximum curvature vector
+     * \param cvtr1_j Maximum curvature vector
+     * \param cvtr1_k Maximum curvature vector
+     * \param cvtr2_i Minimum curvature vector
+     * \param cvtr2_j Minimum curvature vector
+     * \param cvtr2_k Minimum curvature vector
+  void iGeom_getFcCvtrXYZ( iGeom_Instance instance,
                            iBase_EntityHandle face_handle,
                            double x,
                            double y,
@@ -661,18 +702,21 @@
                            double* cvtr2_k,
                            int* err );
-/**\brief Get the principle curvature vector for an edge at a point
- * Get the principle curvature vector for an edge at a point.  Magnitude of
- * vector is the curvature, direction is direction of principal curvature.
- * \param edge_handle Edge being queried
- * \param cvtr_i Maximum curvature vector
- * \param cvtr_j Maximum curvature vector
- * \param cvtr_k Maximum curvature vector
-  void iGeom_getEgCvtrXYZ( iGeom_Instance,
+    /**\brief  Get the principle curvature vector for an edge at a point
+     * Get the principle curvature vector for an edge at a point.  Magnitude of
+     * vector is the curvature, direction is direction of principal curvature.
+     * \param edge_handle Edge being queried
+     * \param cvtr_i Maximum curvature vector
+     * \param cvtr_j Maximum curvature vector
+     * \param cvtr_k Maximum curvature vector
+  void iGeom_getEgCvtrXYZ( iGeom_Instance instance,
                            iBase_EntityHandle edge_handle,
                            double x,
                            double y,
@@ -682,26 +726,28 @@
                            double* cvtr_k,
                            int* err );
-/**\brief Get the curvature(s) on an entity(ies) at given position(s)
- * Get the curvature(s) on an entity(ies) at given position(s).  If either the
- * \param coords Starting coordinates
- * \param coords_size Number of values in coordinates array
- * \param cvtr_1 First principal curvatures
- * \param cvtr_1_allocated Allocated size of first curvature array
- * \param cvtr_1_size Occupied size of first curvature array
- * \param cvtr_2 Second principal curvatures
- * \param cvtr_2_allocated Allocated size of second curvature array
- * \param cvtr_2_size Occupied size of second curvature array
-  void iGeom_getEntArrCvtrXYZ( iGeom_Instance,
+    /**\brief  Get the curvature(s) on an entity(ies) at given position(s)
+     * Get the curvature(s) on an entity(ies) at given position(s).  If either
+     * \param coords Starting coordinates
+     * \param coords_size Number of values in coordinates array
+     * \param cvtr_1 First principal curvatures
+     * \param cvtr_1_allocated Allocated size of first curvature array
+     * \param cvtr_1_size Occupied size of first curvature array
+     * \param cvtr_2 Second principal curvatures
+     * \param cvtr_2_allocated Allocated size of second curvature array
+     * \param cvtr_2_size Occupied size of second curvature array
+  void iGeom_getEntArrCvtrXYZ( iGeom_Instance instance,
                                int storage_order,
@@ -715,23 +761,26 @@
                                int* cvtr_2_size,
                                int* err );
-/**\brief Get closest point, tangent, and curvature of edge
- * Get closest point, tangent, and curvature of edge.
- * \param x Point at which entity is being queried
- * \param y Point at which entity is being queried
- * \param z Point at which entity is being queried
- * \param on_x Closest point at point being queried
- * \param on_y Closest point at point being queried
- * \param on_z Closest point at point being queried
- * \param tgnt_i Tangent at point being queried
- * \param tgnt_j Tangent at point being queried
- * \param tgnt_k Tangent at point being queried
- * \param cvtr_i Curvature at point being queried
- * \param cvtr_j Curvature at point being queried
- * \param cvtr_k Curvature at point being queried
-  void iGeom_getEgEvalXYZ( iGeom_Instance,
+    /**\brief  Get closest point, tangent, and curvature of edge
+     * Get closest point, tangent, and curvature of edge.
+     * \param x Point at which entity is being queried
+     * \param y Point at which entity is being queried
+     * \param z Point at which entity is being queried
+     * \param on_x Closest point at point being queried
+     * \param on_y Closest point at point being queried
+     * \param on_z Closest point at point being queried
+     * \param tgnt_i Tangent at point being queried
+     * \param tgnt_j Tangent at point being queried
+     * \param tgnt_k Tangent at point being queried
+     * \param cvtr_i Curvature at point being queried
+     * \param cvtr_j Curvature at point being queried
+     * \param cvtr_k Curvature at point being queried
+  void iGeom_getEgEvalXYZ( iGeom_Instance instance,
                            double x,
                            double y,
@@ -747,27 +796,30 @@
                            double* cvtr_k,
                            int* err );
-/**\brief Get closest point, tangent, and curvature of face
- * Get closest point, tangent, and curvature of face.  If any of input
- * coordinate pointers are NULL, that value is not returned.
- * \param nrml_i Normal at point being queried
- * \param nrml_j Normal at point being queried
- * \param nrml_k Normal at point being queried
- * \param cvtr1_i First principal curvature at point being queried
- * \param cvtr1_j First principal curvature at point being queried
- * \param cvtr1_k First principal curvature at point being queried
- * \param cvtr2_i Second principal curvature at point being queried
- * \param cvtr2_j Second principal curvature at point being queried
- * \param cvtr2_k Second principal curvature at point being queried
-  void iGeom_getFcEvalXYZ( iGeom_Instance,
+    /**\brief  Get closest point, tangent, and curvature of face
+     * Get closest point, tangent, and curvature of face.  If any of input
+     * coordinate pointers are NULL, that value is not returned.
+     * \param nrml_i Normal at point being queried
+     * \param nrml_j Normal at point being queried
+     * \param nrml_k Normal at point being queried
+     * \param cvtr1_i First principal curvature at point being queried
+     * \param cvtr1_j First principal curvature at point being queried
+     * \param cvtr1_k First principal curvature at point being queried
+     * \param cvtr2_i Second principal curvature at point being queried
+     * \param cvtr2_j Second principal curvature at point being queried
+     * \param cvtr2_k Second principal curvature at point being queried
+  void iGeom_getFcEvalXYZ( iGeom_Instance instance,
                            double x,
                            double y,
@@ -786,29 +838,33 @@
                            double* cvtr2_k,
                            int* err );
-/**\brief Get the closest point(s), tangent(s), and curvature(s) on an entity(ies) at given position(s)
- * Get the closest point(s), tangent(s), and curvature(s) on an entity(ies) at given position(s).
- * If either the number of entities or number of coordinate triples is unity, then all points or
- * \param edge_handles Edge(s) being queried
- * \param edge_handles_size Number of edges being queried
- * \param on_coords Closest point array
- * \param on_coords_allocated Allocated size of closest point array
- * \param on_coords_size Occupied size of closest point array
- * \param tangent Tangent array
- * \param tangent_allocated Allocated size of tangent array
- * \param tangent_size Occupied size of tangent array
- * \param cvtr First principal curvatures
- * \param cvtr_allocated Allocated size of first curvature array
- * \param cvtr_size Occupied size of first curvature array
-  void iGeom_getArrEgEvalXYZ( iGeom_Instance,
+    /**\brief  Get the closest point(s), tangent(s), and curvature(s) on an
+     *         entity(ies) at given position(s)
+     * Get the closest point(s), tangent(s), and curvature(s) on an entity(ies)
+     * at given position(s).  If either the number of entities or number of
+     * coordinate triples is unity, then all points or entities are queried for
+     * that entity or point, respectively, otherwise each point corresponds to
+     * each entity.  storage_order should be a value in the iBase_StorageOrder
+     * enum.
+     * \param edge_handles Edge(s) being queried
+     * \param edge_handles_size Number of edges being queried
+     * \param on_coords Closest point array
+     * \param on_coords_allocated Allocated size of closest point array
+     * \param on_coords_size Occupied size of closest point array
+     * \param tangent Tangent array
+     * \param tangent_allocated Allocated size of tangent array
+     * \param tangent_size Occupied size of tangent array
+     * \param cvtr First principal curvatures
+     * \param cvtr_allocated Allocated size of first curvature array
+     * \param cvtr_size Occupied size of first curvature array
+  void iGeom_getArrEgEvalXYZ( iGeom_Instance instance,
                               iBase_EntityHandle const* edge_handles,
                               int edge_handles_size,
                               int storage_order,
@@ -825,32 +881,36 @@
                               int* cvtr_size,
                               int* err );
- * \param normal Normal array
- * \param normal_allocated Allocated size of normal array
- * \param normal_size Occupied size of normal array
-  void iGeom_getArrFcEvalXYZ( iGeom_Instance,
+     * enum.
+     * \param normal Normal array
+     * \param normal_allocated Allocated size of normal array
+     * \param normal_size Occupied size of normal array
+  void iGeom_getArrFcEvalXYZ( iGeom_Instance instance,
                               iBase_EntityHandle const* face_handles,
                               int face_handles_size,
                               int storage_order,
@@ -870,17 +930,20 @@
                               int* cvtr2_size,
                               int* err );
-/**\brief Get the bounding box of the specified entity
- * Get the bounding box of the specified entity
-  void iGeom_getEntBoundBox( iGeom_Instance,
+    /**\brief  Get the bounding box of the specified entity
+     * Get the bounding box of the specified entity
+  void iGeom_getEntBoundBox( iGeom_Instance instance,
                              double* min_x,
                              double* min_y,
@@ -890,20 +953,23 @@
                              double* max_z,
                              int* err );
-/**\brief Get the bounding box of the specified entities
- * Get the bounding box of the specified entities.  Storage order passed back
- * will be member of iBase_StorageOrder enum.
- * \param entity_handles Entity handles being queried
- * \param enttiy_handles_size Number of entities being queried
- * \param storage_order Storage order of coordinates passed back
- * \param min_corner Minimum coordinates of bounding boxes
- * \param min_corner_allocated Allocated size of minimum coordinates array
- * \param min_corner_size Occupied size of minimum coordinates array
- * \param max_corner Maximum coordinates of bounding boxes
- * \param max_corner_allocated Allocated size of maximum coordinates array
- * \param max_corner_size Occupied size of maximum coordinates array
-  void iGeom_getArrBoundBox( iGeom_Instance,
+    /**\brief  Get the bounding box of the specified entities
+     * Get the bounding box of the specified entities.  Storage order passed in
+     * should be a member of iBase_StorageOrder enum.
+     * \param entity_handles Entity handles being queried
+     * \param enttiy_handles_size Number of entities being queried
+     * \param storage_order Storage order of coordinates passed back
+     * \param min_corner Minimum coordinates of bounding boxes
+     * \param min_corner_allocated Allocated size of minimum coordinates array
+     * \param min_corner_size Occupied size of minimum coordinates array
+     * \param max_corner Maximum coordinates of bounding boxes
+     * \param max_corner_allocated Allocated size of maximum coordinates array
+     * \param max_corner_size Occupied size of maximum coordinates array
+  void iGeom_getArrBoundBox( iGeom_Instance instance,
                              int storage_order,
@@ -925,7 +991,7 @@
      * \param *z Pointer to z coordinate returned from function
-  void iGeom_getVtxCoord( iGeom_Instance,
+  void iGeom_getVtxCoord( iGeom_Instance instance,
                           iBase_EntityHandle vertex_handle,
                           double* x,
                           double* y,
@@ -949,7 +1015,7 @@
      * \param *coords_size Pointer to occupied size of coords array
-  void iGeom_getVtxArrCoords( iGeom_Instance,
+  void iGeom_getVtxArrCoords( iGeom_Instance instance,
                               int storage_order,
@@ -958,28 +1024,31 @@
                               int* coordinates_size,
                               int* err );
-/**\brief Intersect a ray with the model
- * Intersect a ray with the model.  Storage orders passed back are members of the
- * iBase_StorageOrder enumeration; if output is iBase_UNKNOWN, order is in native order
- * \param x Point from which ray is fired
- * \param y Point from which ray is fired
- * \param z Point from which ray is fired
- * \param dir_x Direction in which ray is fired
- * \param dir_y Direction in which ray is fired
- * \param dir_z Direction in which ray is fired
- * \param intersect_entity_handles Entities intersected by ray
- * \param intersect_entity_handles_allocated Allocated size of intersections array
- * \param intersect_entity_hangles_size Occupied size of intersections array
- * \param intersect_coords Coordinates of intersections
- * \param intersect_coords_allocated Allocated size of coordinates array
- * \param intersect_coords_size Occupied size of coordinates array
- * \param param_coords Distances along ray of intersections
- * \param param_coords_allocated Allocated size of param_coords array
- * \param param_coords_size Occupied size of param_coords array
-  void iGeom_getPntRayIntsct( iGeom_Instance,
+    /**\brief  Intersect a ray with the model
+     * Intersect a ray with the model.  Storage orders passed in should be a
+     * member of the iBase_StorageOrder enumeration.
+     * \param x Point from which ray is fired
+     * \param y Point from which ray is fired
+     * \param z Point from which ray is fired
+     * \param dir_x Direction in which ray is fired
+     * \param dir_y Direction in which ray is fired
+     * \param dir_z Direction in which ray is fired
+     * \param intersect_entity_handles Entities intersected by ray
+     * \param intersect_entity_handles_allocated Allocated size of
+     *        intersections array
+     * \param intersect_entity_hangles_size Occupied size of intersections array
+     * \param intersect_coords Coordinates of intersections
+     * \param intersect_coords_allocated Allocated size of coordinates array
+     * \param intersect_coords_size Occupied size of coordinates array
+     * \param param_coords Distances along ray of intersections
+     * \param param_coords_allocated Allocated size of param_coords array
+     * \param param_coords_size Occupied size of param_coords array
+  void iGeom_getPntRayIntsct( iGeom_Instance instance,
                               double x,
                               double y,
                               double z,
@@ -998,30 +1067,34 @@
                               int* param_coords_size,
                               int* err );
-/**\brief Intersect an array of rays with the model
- * Intersect an array of rays with the model.  Storage orders passed back are members of the
- * iBase_StorageOrder enumeration; if input/output is iBase_UNKNOWN, order is in native order
- * \param storage_order Storage order of input coordinates
- * \param coords Points from which rays are fired
- * \param coords_size Number of points from which rays are fired
- * \param directions Directions in which rays are fired
- * \param directions_size Number of coordinates in directions array
- * \param offset Offset[i] is offset into intersect_entity_handles of ith ray
-  void iGeom_getPntArrRayIntsct( iGeom_Instance,
+    /**\brief  Intersect an array of rays with the model
+     * Intersect an array of rays with the model.  Storage order passed in is
+     * a member of the iBase_StorageOrder enumeration.
+     * \param storage_order Storage order of input coordinates
+     * \param coords Points from which rays are fired
+     * \param coords_size Number of points from which rays are fired
+     * \param directions Directions in which rays are fired
+     * \param directions_size Number of coordinates in directions array
+     * \param intersect_entity_handles_allocated Allocated size of intersections
+     *        array
+     * \param offset Offset[i] is offset into intersect_entity_handles of ith
+     *        ray
+  void iGeom_getPntArrRayIntsct( iGeom_Instance instance,
                                  int storage_order,
                                  const double* coords,
                                  int coords_size,
@@ -1041,32 +1114,37 @@
                                  int* err );
-/**\brief Get the entity on which a point is located
- * Get the entity on which a point is located
- * \param x Point being queried
- * \param y Point being queried
- * \param z Point being queried
- * \param entity_handle Entity on which point is located
-  void iGeom_getPntClsf( iGeom_Instance,
+    /**\brief  Get the entity on which a point is located
+     * Get the entity on which a point is located
+     * \param x Point being queried
+     * \param y Point being queried
+     * \param z Point being queried
+     * \param entity_handle Entity on which point is located
+  void iGeom_getPntClsf( iGeom_Instance instance,
                          double x,
                          double y,
                          double z,
                          iBase_EntityHandle* entity_handle,
                          int* err );
-/**\brief Get the entities on which points are located
- * Get the entities on which points are located.   Storage orders should be members of the
- * iBase_StorageOrder enumeration; if input is iBase_UNKNOWN, order is in native order
- * \param storage_order Storage order of coordinates in coords
- * \param coords Points being queried
- * \param coords_size Number of entries in coords array
- * \param entity_handles Entities on which points are located
- * \param entity_handles_allocated Allocated size of entity_handles array
- * \param entity_handles_size Occupied size of entity_handles array
-  void iGeom_getPntArrClsf( iGeom_Instance,
+    /**\brief  Get the entities on which points are located
+     * Get the entities on which points are located.  Storage orders should be
+     * members of the iBase_StorageOrder enumeration.
+     * \param storage_order Storage order of coordinates in coords
+     * \param coords Points being queried
+     * \param coords_size Number of entries in coords array
+     * \param entity_handles Entities on which points are located
+     * \param entity_handles_allocated Allocated size of entity_handles array
+     * \param entity_handles_size Occupied size of entity_handles array
+  void iGeom_getPntArrClsf( iGeom_Instance instance,
                             int storage_order,
                             double const* coords,
                             int coords_size,
@@ -1075,33 +1153,41 @@
                             int* err );
-/**\brief Get the sense of a face with respect to a region
- * Get the sense of a face with respect to a region.  Sense returned is -1, 0, or 1,
- * representing "reversed", "both", or "forward".  "both" sense indicates that face bounds
- * the region once with each sense.
- * \param face Face being queried
- * \param region Region being queried
- * \param sense_out Sense of face with respect to region
-  void iGeom_getEntNrmlSense( iGeom_Instance,
+    /**\brief  Get the sense of a face with respect to a region
+     * Get the sense of a face with respect to a region.  Sense returned is -1,
+     * 0, or 1, representing "reversed", "both", or "forward".  "both" sense
+     * indicates that face bounds the region once with each sense.
+     * \param face Face being queried
+     * \param region Region being queried
+     * \param sense_out Sense of face with respect to region
+  void iGeom_getEntNrmlSense( iGeom_Instance instance,
                               iBase_EntityHandle face,
                               iBase_EntityHandle region,
                               int* sense_out,
                               int* err );
-/**\brief Get the senses of an array of faces with respect to an array of regions
- * Get the senses of an array of faces with respect to an array of regions.  Sense returned
- * is -1, 0, or 1, representing "reversed", "both", or "forward".  "both" sense indicates
- * that face bounds the region once with each sense.
- * \param face_handles Faces being queried
- * \param face_handles_size Size of face handles array
- * \param region_handles Regions being queried
- * \param region_handles_size Size of region handles array
- * \param sense Senses of faces with respect to regions
- * \param sense_allocated Allocated size of senses array
- * \param sense_size Occupied size of senses array
-  void iGeom_getArrNrmlSense( iGeom_Instance,
+    /**\brief  Get the senses of an array of faces with respect to an array of
+     *         regions
+     * Get the senses of an array of faces with respect to an array of regions.
+     * Sense returned is -1, 0, or 1, representing "reversed", "both", or
+     * "forward".  "both" sense indicates that face bounds the region once with
+     * each sense.
+     * \param face_handles Faces being queried
+     * \param face_handles_size Size of face handles array
+     * \param region_handles Regions being queried
+     * \param region_handles_size Size of region handles array
+     * \param sense Senses of faces with respect to regions
+     * \param sense_allocated Allocated size of senses array
+     * \param sense_size Occupied size of senses array
+  void iGeom_getArrNrmlSense( iGeom_Instance instance,
                               iBase_EntityHandle const* region_handles,
@@ -1111,33 +1197,41 @@
                               int* sense_size,
                               int* err );
-/**\brief Get the sense of an edge with respect to a face
- * Get the sense of an edge with respect to a face.  Sense returned is -1, 0, or 1,
- * representing "reversed", "both", or "forward".  "both" sense indicates that edge bounds
- * the face once with each sense.
- * \param edge Edge being queried
- * \param sense_out Sense of edge with respect to face
+    /**\brief  Get the sense of an edge with respect to a face
+     * Get the sense of an edge with respect to a face.  Sense returned is -1,
+     * indicates that edge bounds the face once with each sense.
+     * \param edge Edge being queried
+     * \param sense_out Sense of edge with respect to face
   void iGeom_getEgFcSense( iGeom_Instance,
                            iBase_EntityHandle edge,
                            int* sense_out,
                            int* err );
-/**\brief Get the senses of an array of edges with respect to an array of faces
- * Get the senses of an array of edges with respect to an array of faces.  Sense returned
- * that edge bounds the face once with each sense.
- * \param edge_handles Edges being queried
- * \param edge_handles_size Size of edge handles array
-  void iGeom_getEgFcArrSense( iGeom_Instance,
+    /**\brief  Get the senses of an array of edges with respect to an array of
+     *         faces
+     * Get the senses of an array of edges with respect to an array of faces.
+     * "forward".  "both" sense indicates that edge bounds the face once with
+     * each sense.
+     * \param edge_handles Edges being queried
+     * \param edge_handles_size Size of edge handles array
+  void iGeom_getEgFcArrSense( iGeom_Instance instance,
@@ -1147,37 +1241,45 @@
                               int* sense_size,
                               int* err );
-/**\brief Get the sense of a vertex pair with respect to an edge
- * Get the sense of a vertex pair with respect to an edge.  Sense returned is -1, 0, or 1,
- * representing "reversed", "both", or "forward".  "both" sense indicates that vertices
- * are identical and that vertex bounds both sides of the edge
- * \param vertex1 First vertex being queried
- * \param vertex2 Second vertex being queried
- * \param sense_out Sense of vertex pair with respect to edge
-  void iGeom_getEgVtxSense( iGeom_Instance,
+    /**\brief  Get the sense of a vertex pair with respect to an edge
+     * Get the sense of a vertex pair with respect to an edge.  Sense returned
+     * is -1, 0, or 1, representing "reversed", "both", or "forward".  "both"
+     * sense indicates that vertices are identical and that vertex bounds both
+     * sides of the edge.
+     * \param vertex1 First vertex being queried
+     * \param vertex2 Second vertex being queried
+     * \param sense_out Sense of vertex pair with respect to edge
+  void iGeom_getEgVtxSense( iGeom_Instance instance,
                             iBase_EntityHandle vertex1,
                             iBase_EntityHandle vertex2,
                             int* sense_out,
                             int* err );
-/**\brief Get the senses of vertex pair with respect to a edges
- * Get the senses of vertex pairs with respect to edges.  Sense returned is -1, 0, or 1,
- * representing "reversed", "both", or "forward".  "both" sense indicates that both vertices
- * in pair are identical and that vertex bounds both sides of the edge
- * \param vertex_handles_1 First vertex being queried
- * \param vertex_handles_1_size Number of vertices in vertices array
- * \param vertex_handles_2 Second vertex being queried
- * \param vertex_handles_2_size Number of vertices in vertices array
- * \param sense Sense of vertex pair with respect to edge
- * \param sense_allocated Allocated size of sense array
- * \param sense_size Occupied size of sense array
-  void iGeom_getEgVtxArrSense( iGeom_Instance,
+    /**\brief  Get the senses of vertex pair with respect to a edges
+     * Get the senses of vertex pairs with respect to edges.  Sense returned is
+     * -1, 0, or 1, representing "reversed", "both", or "forward".  "both" sense
+     * indicates that both vertices in pair are identical and that vertex bounds
+     * both sides of the edge.
+     * \param vertex_handles_1 First vertex being queried
+     * \param vertex_handles_1_size Number of vertices in vertices array
+     * \param vertex_handles_2 Second vertex being queried
+     * \param vertex_handles_2_size Number of vertices in vertices array
+     * \param sense Sense of vertex pair with respect to edge
+     * \param sense_allocated Allocated size of sense array
+     * \param sense_size Occupied size of sense array
+  void iGeom_getEgVtxArrSense( iGeom_Instance instance,
                                iBase_EntityHandle const* vertex_handles_1,
@@ -1189,15 +1291,18 @@
                                int* sense_size,
                                int* err );
-/**\brief Return the measure (length, area, volume) of entities
- * Return the measure (length, area, volume) of entities
- * \param entity_handles Array of entities being queried
- * \param entity_handles_size Number of entities in entity array
- * \param measures Measures of entities being queried
- * \param measures_allocated Allocated size of measures array
- * \param measures_size Occupied size of measures array
-  void iGeom_measure( iGeom_Instance,
+    /**\brief  Return the measure (length, area, or volume) of entities
+     * Return the measure (length, area, or volume) of entities
+     * \param entity_handles Array of entities being queried
+     * \param entity_handles_size Number of entities in entity array
+     * \param measures Measures of entities being queried
+     * \param measures_allocated Allocated size of measures array
+     * \param measures_size Occupied size of measures array
+  void iGeom_measure( iGeom_Instance instance,
                       double** measures,
@@ -1205,45 +1310,60 @@
                       int* measures_size,
                       int* err );
-/**\brief Get the geometric type of an entity
- * Get the geometric type of an entity.  Specific types depend on implementation.
- * \param face_type Face type
- * \param face_type_length Length of face type string
-  void iGeom_getFaceType( iGeom_Instance,
+    /**\brief  Get the geometric type of a face
+     * Get the geometric type of a face.  Specific types depend on
+     * implementation.
+     * \param face_type Face type
+     * \param face_type_length Length of face type string
+  void iGeom_getFaceType( iGeom_Instance instance,
                           char* face_type,
                           int* err,
                           int* face_type_length);
-/**\brief Return whether interface has information about parameterization
- * Return whether an interface has information about parameterization (!=0) or not (0)
- * \param is_parametric If non-zero, interface has information about parameterization
-  void iGeom_getParametric( iGeom_Instance,
+    /**\brief  Return whether interface has information about parameterization
+     * Return whether an interface has information about parameterization (!=0)
+     * or not (0)
+     * \param is_parametric If non-zero, interface has information about
+     *        parameterization
+  void iGeom_getParametric( iGeom_Instance instance,
                             int* is_parametric,
                             int* err );
-/**\brief Return whether an entity has a parameterization
- * Return whether an entity has a parameterization (!= 0) or not (=0)
- * \param is_parametric Entity has a parameterization (!= 0) or not (=0)
-  void iGeom_isEntParametric( iGeom_Instance,
+    /**\brief  Return whether an entity has a parameterization
+     * Return whether an entity has a parameterization (=1) or not (=0)
+     * \param is_parametric Entity has a parameterization (=1) or not (=0)
+  void iGeom_isEntParametric( iGeom_Instance instance,
                               int* parametric,
                               int* err );
-/**\brief Return whether entities have parameterizations
- * Return whether entities have parameterizations (!= 0) or not (=0)
- * \param entity_handles Entities being queried
- * \param is_parametric entity_handles[i] has a parameterization (!= 0) or not (=0)
- * \param is_parametric_allocated Allocated size of is_parametric array
- * \param is_parametric_size Occupied size of is_parametric array
-  void iGeom_isArrParametric( iGeom_Instance,
+    /**\brief  Return whether entities have parameterizations
+     * Return whether entities have parameterizations (=1) or not (=0)
+     * \param entity_handles Entities being queried
+     * \param is_parametric entity_handles[i] has a parameterization (=1) or
+     *        not (=0)
+     * \param is_parametric_allocated Allocated size of is_parametric array
+     * \param is_parametric_size Occupied size of is_parametric array
+  void iGeom_isArrParametric( iGeom_Instance instance,
                               int** is_parametric,
@@ -1251,16 +1371,20 @@
                               int* is_parametric_size,
                               int* err );
-/**\brief Return coordinate position at specified parametric position on entity
- * Return coordinate position at specified parametric position on entity.
- * \param u Parametric coordinate being queried
- * \param v Parametric coordinate being queried
- * \param x Spatial coordinate at parametric position being queried
- * \param y Spatial coordinate at parametric position being queried
- * \param z Spatial coordinate at parametric position being queried
-  void iGeom_getEntUVtoXYZ( iGeom_Instance,
+    /**\brief  Return coordinate position at specified parametric position on
+     *         entity
+     * Return coordinate position at specified parametric position on entity.
+     * \param u Parametric coordinate being queried
+     * \param v Parametric coordinate being queried
+     * \param x Spatial coordinate at parametric position being queried
+     * \param y Spatial coordinate at parametric position being queried
+     * \param z Spatial coordinate at parametric position being queried
+  void iGeom_getEntUVtoXYZ( iGeom_Instance instance,
                             double u,
                             double v,
@@ -1269,23 +1393,28 @@
                             double* z,
                             int* err );
-/**\brief Return coordinate positions at specified parametric position(s) on entity(ies)
- * Return coordinate positions at specified parametric position(s) on entity(ies).
- * If either the number of entities or number of parametric coordinate pairs is unity, then
- * all points or entities are queried for that entity or point, respectively, otherwise each
- * \param storage_order Storage order of uv coordinates input and xyz coordinate output
- * \param uv Coordinates being queried
- * \param uv_size Number of coordinates in array
- * \param coordinates Coordinates of parametric positions
- * \param coordinates_allocated Allocated size of coordinates array
- * \param coordinates_size Occupied size of coordinates array
-  void iGeom_getArrUVtoXYZ( iGeom_Instance,
+    /**\brief  Return coordinate positions at specified parametric position(s)
+     *         on entity(ies)
+     * Return coordinate positions at specified parametric position(s) on
+     * entity(ies).  If either the number of entities or number of parametric
+     * coordinate pairs is unity, then all points or entities are queried for
+     * enum.
+     * \param storage_order Storage order of uv coordinates input and xyz
+     *        coordinate output
+     * \param uv Coordinates being queried
+     * \param uv_size Number of coordinates in array
+     * \param coordinates Coordinates of parametric positions
+     * \param coordinates_allocated Allocated size of coordinates array
+     * \param coordinates_size Occupied size of coordinates array
+  void iGeom_getArrUVtoXYZ( iGeom_Instance instance,
                             int storage_order,
@@ -1296,15 +1425,19 @@
                             int* err );
-  void iGeom_getEntUtoXYZ( iGeom_Instance,
+     *         entity
+  void iGeom_getEntUtoXYZ( iGeom_Instance instance,
                            double u,
                            double* x,
@@ -1312,23 +1445,27 @@
                            double* z,
                            int* err );
- * \param storage_order Storage order of resulting coordinates
-  void iGeom_getArrUtoXYZ( iGeom_Instance,
+     *         on entity(ies)
+     * enum.
+     * \param storage_order Storage order of resulting coordinates
+  void iGeom_getArrUtoXYZ( iGeom_Instance instance,
                            double const* u,
@@ -1339,16 +1476,20 @@
                            int* on_coords_size,
                            int* err );
-/**\brief Return parametric position at specified spatial position on entity
- * Return parametric position at specified spatial position on entity
- * \param x Spatial coordinate being queried
- * \param y Spatial coordinate being queried
- * \param z Spatial coordinate being queried
- * \param u Parametric coordinate at spatial position being queried
- * \param v Parametric coordinate at spatial position being queried
-  void iGeom_getEntXYZtoUV( iGeom_Instance,
+    /**\brief  Return parametric position at specified spatial position on
+     *         entity
+     * Return parametric position at specified spatial position on entity
+     * \param x Spatial coordinate being queried
+     * \param y Spatial coordinate being queried
+     * \param z Spatial coordinate being queried
+     * \param u Parametric coordinate at spatial position being queried
+     * \param v Parametric coordinate at spatial position being queried
+  void iGeom_getEntXYZtoUV( iGeom_Instance instance,
                             double x,
                             double y,
@@ -1357,15 +1498,19 @@
                             double* v,
                             int* err );
-  void iGeom_getEntXYZtoU( iGeom_Instance,
+     *         entity
+  void iGeom_getEntXYZtoU( iGeom_Instance instance,
                            double x,
                            double y,
@@ -1373,23 +1518,26 @@
                            double* u,
                            int* err );
-/**\brief Return parametric positions at specified spatial position(s) on entity(ies)
- * Return parametric positions at specified spatial position(s) on entity(ies).
- * If either the number of entities or number of spatial coordinate triples is unity, then
- * \param storage_order Storage order of spatial coordinates input
- * \param coordinates Coordinates being queried
- * \param coordinates_size Number of coordinates in array
- * \param uv Coordinates of parametric positions
- * \param uv_allocated Allocated size of coordinates array
- * \param uv_size Occupied size of coordinates array
-  void iGeom_getArrXYZtoUV( iGeom_Instance,
+    /**\brief  Return parametric positions at specified spatial position(s) on
+     *         entity(ies)
+     * Return parametric positions at specified spatial position(s) on
+     * entity(ies).  If either the number of entities or number of spatial
+     * enum.
+     * \param storage_order Storage order of spatial coordinates input
+     * \param coordinates Coordinates being queried
+     * \param coordinates_size Number of coordinates in array
+     * \param uv Coordinates of parametric positions
+     * \param uv_allocated Allocated size of coordinates array
+     * \param uv_size Occupied size of coordinates array
+  void iGeom_getArrXYZtoUV( iGeom_Instance instance,
                             int storage_order,
@@ -1400,23 +1548,27 @@
                             int* uv_size,
                             int* err );
-/**\brief Return spatial positions at specified parametric position(s) on entity(ies)
- * Return spatial positions at specified parametric position(s) on entity(ies).
- * \param u Coordinates of parametric positions
- * \param u_allocated Allocated size of coordinates array
- * \param u_size Occupied size of coordinates array
-  void iGeom_getArrXYZtoU( iGeom_Instance,
+    /**\brief  Return spatial positions at specified parametric position(s) on
+     *         entity(ies)
+     * Return spatial positions at specified parametric position(s) on
+     * enum.
+     * \param u Coordinates of parametric positions
+     * \param u_allocated Allocated size of coordinates array
+     * \param u_size Occupied size of coordinates array
+  void iGeom_getArrXYZtoU( iGeom_Instance instance,
                            int storage_order,
@@ -1427,18 +1579,23 @@
                            int* u_size,
                            int* err );
-/**\brief Return parametric position at specified spatial position on entity, based on parametric position hint
- * Return parametric position at specified spatial position on entity, based on parametric
- * position hint.  For this function, u and v are input with parameters from which to start search.
- * Typically this will reduce the search time for new parametric coordinates.
-  void iGeom_getEntXYZtoUVHint( iGeom_Instance,
+     *         entity, based on parametric position hint
+     * Return parametric position at specified spatial position on entity,
+     * based on parametric position hint.  For this function, u and v are input
+     * with parameters from which to start search. Typically this will reduce
+     * the search time for new parametric coordinates.
+  void iGeom_getEntXYZtoUVHint( iGeom_Instance instance,
                                 double x,
                                 double y,
@@ -1447,23 +1604,26 @@
                                 double* v,
                                 int* err );
-/**\brief Return parametric positions at specified spatial position(s) on entity(ies), based on parametric position hints
- * Return parametric positions at specified spatial position(s) on entity(ies), based on
- * parametric position hints.  If either the number of entities or number of spatial
- * coordinate triples is unity, then all points or entities are queried for that entity
- * or point, respectively, otherwise each point corresponds to each entity.  storage_order
- * should be a value in the iBase_StorageOrder enum; if input as iBase_UNKNOWN, order is in
- * native order with respect to implementation.
-  void iGeom_getArrXYZtoUVHint( iGeom_Instance,
+     *         entity(ies), based on parametric position hints
+     * entity(ies), based on parametric position hints.  If either the number of
+     * entities or number of spatial coordinate triples is unity, then all
+  void iGeom_getArrXYZtoUVHint( iGeom_Instance instance,
                                 int storage_order,
@@ -1474,15 +1634,18 @@
                                 int* uv_size,
                                 int* err );
-/**\brief Get parametric range of entity
- * Get parametric range of entity
- * \param u_min Minimum parametric coordinate for entity
- * \param v_min Minimum parametric coordinate for entity
- * \param u_max Maximum parametric coordinate for entity
- * \param v_max Maximum parametric coordinate for entity
-  void iGeom_getEntUVRange( iGeom_Instance,
+    /**\brief  Get parametric range of entity
+     * Get parametric range of entity
+     * \param u_min Minimum parametric coordinate for entity
+     * \param v_min Minimum parametric coordinate for entity
+     * \param u_max Maximum parametric coordinate for entity
+     * \param v_max Maximum parametric coordinate for entity
+  void iGeom_getEntUVRange( iGeom_Instance instance,
                             double* u_min,
                             double* v_min,
@@ -1490,31 +1653,40 @@
                             double* v_max,
                             int* err );
-  void iGeom_getEntURange( iGeom_Instance,
+  void iGeom_getEntURange( iGeom_Instance instance,
                            double* u_min,
                            double* u_max,
                            int* err );
-/**\brief Get parametric range of entities
- * Get parametric range of entities
- * \param storage_order Storage order of parametric coordinates being returned
- * \param uv_min Minimum parametric coordinate for entities
- * \param uv_min_allocated Allocated size of minimum parametric coordinate array
- * \param uv_min_size Occupied size of minimum parametric coordinate array
- * \param uv_max Maximum parametric coordinate for entities
- * \param uv_max_allocated Allocated size of maximum parametric coordinate array
- * \param uv_max_size Occupied size of maximum parametric coordinate array
-  void iGeom_getArrUVRange( iGeom_Instance,
+    /**\brief  Get parametric range of entities
+     * Get parametric range of entities
+     * \param storage_order Storage order of parametric coordinates being
+     *        returned
+     * \param uv_min Minimum parametric coordinate for entities
+     * \param uv_min_allocated Allocated size of minimum parametric coordinate
+     *        array
+     * \param uv_min_size Occupied size of minimum parametric coordinate array
+     * \param uv_max Maximum parametric coordinate for entities
+     * \param uv_max_allocated Allocated size of maximum parametric coordinate
+     *        array
+     * \param uv_max_size Occupied size of maximum parametric coordinate array
+  void iGeom_getArrUVRange( iGeom_Instance instance,
                             int storage_order,
@@ -1526,19 +1698,25 @@
                             int* uv_max_size,
                             int* err );
- * \param u_min Minimum parametric coordinate for entities
- * \param u_min_allocated Allocated size of minimum parametric coordinate array
- * \param u_min_size Occupied size of minimum parametric coordinate array
- * \param u_max Maximum parametric coordinate for entities
- * \param u_max_allocated Allocated size of maximum parametric coordinate array
- * \param u_max_size Occupied size of maximum parametric coordinate array
-  void iGeom_getArrURange( iGeom_Instance,
+     *        returned
+     * \param u_min Minimum parametric coordinate for entities
+     * \param u_min_allocated Allocated size of minimum parametric coordinate
+     *        array
+     * \param u_min_size Occupied size of minimum parametric coordinate array
+     * \param u_max Maximum parametric coordinate for entities
+     * \param u_max_allocated Allocated size of maximum parametric coordinate
+     *        array
+     * \param u_max_size Occupied size of maximum parametric coordinate array
+  void iGeom_getArrURange( iGeom_Instance instance,
                            double** u_min,
@@ -1549,15 +1727,20 @@
                            int* u_max_size,
                            int* err );
-/**\brief Return the face parametric coordinates for a parametric position on a bounding edge
- * Return the face parametric coordinates for a parametric position on a bounding edge
- * \param in_u Parametric position on edge
- * \param u Corresponding parametric position on face
- * \param v Corresponding parametric position on face
-  void iGeom_getEntUtoUV( iGeom_Instance,
+    /**\brief  Return the face parametric coordinates for a parametric position
+     *         on a bounding edge
+     * Return the face parametric coordinates for a parametric position on a
+     * bounding edge
+     * \param in_u Parametric position on edge
+     * \param u Corresponding parametric position on face
+     * \param v Corresponding parametric position on face
+  void iGeom_getEntUtoUV( iGeom_Instance instance,
                           double in_u,
@@ -1565,46 +1748,57 @@
                           double* v,
                           int* err );
-/**\brief Return parametric coordinates on face of vertex position
- * Return parametric coordinates on face of vertex position
- * \param vertex_handle Vertex being queried
-  void iGeom_getVtxToUV( iGeom_Instance,
+    /**\brief  Return parametric coordinates on face of vertex position
+     * Return parametric coordinates on face of vertex position
+     * \param instance iGeom instance handle
+     * \param vertex_handle Vertex being queried
+     * \param *err Pointer to error type returned from function
+  void iGeom_getVtxToUV( iGeom_Instance instance,
                          double* u,
                          double* v,
                          int* err );
-/**\brief Return parametric coordinates on edge of vertex position
- * Return parametric coordinates on edge of vertex position
-  void iGeom_getVtxToU( iGeom_Instance,
+    /**\brief  Return parametric coordinates on edge of vertex position
+     * Return parametric coordinates on edge of vertex position
+  void iGeom_getVtxToU( iGeom_Instance instance,
                         double* u,
                         int* err );
-/**\brief Return the face parametric coordinates for a parametric position on bounding edges
- * Return the face parametric coordinates for a parametric position on bounding edges
- * \param face_handles_size Number of faces being queried
- * \param u_in Parametric positions on edges
- * \param u_in_size Number of parametric positions on edges
- * \param storage_order Storage order of coordinates returned
- * \param uv Corresponding parametric positions on faces
- * \param uv_allocated Allocated size of parameter array
- * \param uv_size Occupied size of parameter array
-  void iGeom_getArrUtoUV( iGeom_Instance,
+     *         on bounding edges
+     * bounding edges
+     * \param face_handles_size Number of faces being queried
+     * \param u_in Parametric positions on edges
+     * \param u_in_size Number of parametric positions on edges
+     * \param storage_order Storage order of coordinates returned
+     * \param uv Corresponding parametric positions on faces
+     * \param uv_allocated Allocated size of parameter array
+     * \param uv_size Occupied size of parameter array
+  void iGeom_getArrUtoUV( iGeom_Instance instance,
@@ -1617,18 +1811,21 @@
                           int* uv_size,
                           int* err );
-/**\brief Return parametric coordinates on faces of vertex positions
- * Return parametric coordinates on faces of vertex positions
- * \param vertex_handles Vertices being queried
- * \param vertex_handles_size Number of vertices being queried
- * \param uv_allocated Allocated size of positions array
- * \param uv_size Occupied size of positions array
-  void iGeom_getVtxArrToUV( iGeom_Instance,
+    /**\brief  Return parametric coordinates on faces of vertex positions
+     * Return parametric coordinates on faces of vertex positions
+     * \param vertex_handles Vertices being queried
+     * \param vertex_handles_size Number of vertices being queried
+     * \param uv_allocated Allocated size of positions array
+     * \param uv_size Occupied size of positions array
+  void iGeom_getVtxArrToUV( iGeom_Instance instance,
                             iBase_EntityHandle const* vertex_handles,
                             int vertex_handles_size,
@@ -1639,17 +1836,20 @@
                             int* uv_size,
                             int* err );
-/**\brief Return parametric coordinates on edges of vertex positions
- * Return parametric coordinates on edges of vertex positions
- * \param u Corresponding parametric positions on faces
- * \param u_allocated Allocated size of positions array
- * \param u_size Occupied size of positions array
-  void iGeom_getVtxArrToU( iGeom_Instance,
+    /**\brief  Return parametric coordinates on edges of vertex positions
+     * Return parametric coordinates on edges of vertex positions
+     * \param u Corresponding parametric positions on faces
+     * \param u_allocated Allocated size of positions array
+     * \param u_size Occupied size of positions array
+  void iGeom_getVtxArrToU( iGeom_Instance instance,
@@ -1659,16 +1859,19 @@
                            int* u_size,
                            int* err );
-/**\brief Return the normal at a specified parametric position
- * Return the normal at a specified parametric position
- * \param u Parametric position being queried
- * \param v Parametric position being queried
- * \param nrml_i Normal at specified position
- * \param nrml_j Normal at specified position
- * \param nrml_k Normal at specified position
-  void iGeom_getEntNrmlUV( iGeom_Instance,
+    /**\brief  Return the normal at a specified parametric position
+     * Return the normal at a specified parametric position
+     * \param u Parametric position being queried
+     * \param v Parametric position being queried
+     * \param nrml_i Normal at specified position
+     * \param nrml_j Normal at specified position
+     * \param nrml_k Normal at specified position
+     * \param *err Pointer to error type returned from functino
+  void iGeom_getEntNrmlUV( iGeom_Instance instance,
                            iBase_EntityHandle entity_handle,
                            double u,
                            double v,
@@ -1677,18 +1880,25 @@
                            double* nrml_k,
                            int* err );
-/**\brief Return the normals at a specified parametric positions
- * Return the normals at a specified parametric positions.  If either the number of
- * entities or number of spatial
-  void iGeom_getArrNrmlUV( iGeom_Instance,
+    /**\brief  Return the normals at specified parametric positions
+     * Return the normals at specified parametric positions.  If either the
+     * number of entities or number of spatial coordinate pairs is unity, then
+     * all points or entities are queried for that entity or point,
+     * respectively, otherwise each point corresponds to each entity.
+     * \param face_handle Faces being queried
+     * \param storage_order Storage order of coordinates input and output
+     * \param parameters Parametric coordinates being queried
+     * \param parameters_size Number of coordinates in array
+     * \param normals Coordinates of normals at specified positions
+  void iGeom_getArrNrmlUV( iGeom_Instance instance,
                            int storage_order,
@@ -1699,10 +1909,18 @@
                            int* normals_size,
                            int* err );
-/**\brief
-  void iGeom_getEntTgntU( iGeom_Instance,
+    /**\brief  Return the tangent at a specified parametric position
+     * Return the tangent at a specified parametric position
+     * \param tgnt_i Tangent at specified position
+     * \param tgnt_j Tangent at specified position
+     * \param tgnt_k Tangent at specified position
+  void iGeom_getEntTgntU( iGeom_Instance instance,
                           double u,
                           double* tgnt_i,
@@ -1710,10 +1928,25 @@
                           double* tgnt_k,
                           int* err );
-/**\brief
-  void iGeom_getArrTgntU( iGeom_Instance,
+    /**\brief  Return the tangents at specified parametric positions
+     * Return the tangents at specified parametric positions.  If either the
+     * number of entities or number of spatial coordinates is unity, then all
+     * \param edge_handle Edges being queried
+     * \param edge_handles_size Number of faces being queried
+     * \param storage_order Storage order of coordinates output
+     * \param tangents Coordinates of tangents at specified positions
+  void iGeom_getArrTgntU( iGeom_Instance instance,
                           int storage_order,
@@ -1724,10 +1957,25 @@
                           int* tangents_size,
                           int* err );
-/**\brief
-  void iGeom_getEnt1stDrvt( iGeom_Instance,
+    /**\brief  Get the first derivative of a face at specified parametric
+     *         position
+     * Get the first derivative of a face at specified parametric position.
+     * \param dvrt_u Pointer to coordinates of derivative with respect to u at
+     *        specified position returned from function
+     * \param dvrt_u_allocated Allocated size of dvrt_u array
+     * \param dvrt_u_size Occupied size of dvrt_u array
+     * \param dvrt_v Pointer to coordinates of derivative with respect to v at
+     * \param dvrt_v_allocated Allocated size of dvrt_v array
+     * \param dvrt_v_size Occupied size of dvrt_v array
+  void iGeom_getEnt1stDrvt( iGeom_Instance instance,
                             double u,
                             double v,
@@ -1739,16 +1987,42 @@
                             int* dvrt_v_size,
                             int* err );
-/**\brief
-  void iGeom_getArr1stDrvt( iGeom_Instance,
+    /**\brief  Get the first derivatives of faces at specified parametric
+     *         positions
+     * Get the first derivatives of faces at specified parametric positions.
+     * \param entity_handles Array of entity handles being queried
+     * \param entity_handles_size Number of entities in entity_handles array
+     * \param uv Parametric coordinates being queried
+     * \param dvrt_u Pointer to array of coordinates of derivative with respect
+     *        to u at specified position returned from function
+     * \param u_offset Pointer to array of offsets for dvrt_u returned from
+     *        function
+     * \param u_offset_allocated Pointer to allocated size of u_offset array
+     * \param u_offset_size Pointer to occupied size of u_offset array
+     * \param dvrt_v Pointer to array of coordinates of derivative with respect
+     *        to v at specified position returned from function
+     * \param v_offset Pointer to array of offsets for dvrt_v returned from
+     *        function
+     * \param v_offset_allocated Pointer to allocated size of v_offset array
+     * \param v_offset_size Pointer to occupied size of v_offset array
+  void iGeom_getArr1stDrvt( iGeom_Instance instance,
                             iBase_EntityHandle const* entity_handles,
                             int entity_handles_size,
                             int storage_order,
                             double const* uv,
                             int uv_size,
-                            double** dvtr_u,
+                            double** dvrt_u,
                             int* dvrt_u_allocated,
                             int* dvrt_u_size,
                             int** u_offset,
@@ -1762,10 +2036,29 @@
                             int* v_offset_size,
                             int* err );
-/**\brief
-  void iGeom_getEnt2ndDrvt( iGeom_Instance,
+    /**\brief  Get the second derivative of a face at specified parametric
+     *         position
+     * Get the second derivative of a face at specified parametric position.
+     * \param dvrt_uu Pointer to coordinates of derivative with respect to u at
+     * \param dvrt_uu_allocated Allocated size of dvrt_uu array
+     * \param dvrt_uu_size Occupied size of dvrt_uu array
+     * \param dvrt_vv Pointer to coordinates of derivative with respect to v at
+     * \param dvrt_vv_allocated Allocated size of dvrt_vv array
+     * \param dvrt_vv_size Occupied size of dvrt_vv array
+     * \param dvrt_uv Pointer to coordinates of derivative with respect to u and
+     *        v at specified position returned from function
+     * \param dvrt_uv_allocated Allocated size of dvrt_uv array
+     * \param dvrt_uv_size Occupied size of dvrt_uv array
+  void iGeom_getEnt2ndDrvt( iGeom_Instance instance,
                             double u,
                             double v,
@@ -1780,10 +2073,44 @@
                             int* dvrt_uv_size,
                             int* err );
-/**\brief
-  void iGeom_getArr2ndDrvt( iGeom_Instance,
+    /**\brief  Get the second derivatives of faces at specified parametric
+     *         positions
+     * Get the second derivatives of faces at specified parametric positions.
+     * \param dvrt_uu Pointer to array of coordinates of derivative with respect
+     * \param uu_offset Pointer to array of offsets for dvrt_uu returned from
+     *        function
+     * \param uu_offset_allocated Pointer to allocated size of uu_offset array
+     * \param uu_offset_size Pointer to occupied size of uu_offset array
+     * \param dvrt_vv Pointer to array of coordinates of derivative with respect
+     * \param vv_offset Pointer to array of offsets for dvrt_vv returned from
+     *        function
+     * \param vv_offset_allocated Pointer to allocated size of vv_offset array
+     * \param vv_offset_size Pointer to occupied size of vv_offset array
+     * \param dvrt_uv Pointer to array of coordinates of derivative with respect
+     *        to u and v at specified position returned from function
+     * \param uv_offset Pointer to array of offsets for dvrt_uv returned from
+     *        function
+     * \param uv_offset_allocated Pointer to allocated size of uv_offset array
+     * \param uv_offset_size Pointer to occupied size of uv_offset array
+  void iGeom_getArr2ndDrvt( iGeom_Instance instance,
                             int storage_order,
@@ -1809,11 +2136,26 @@
                             int* uv_offset_size,
                             int* err );
-/**\brief
-  void iGeom_getFcCvtrUV( iGeom_Instance,
-                          iBase_EntityHandle entity_handle,
+     *         parametric position
+     * Get the two principle curvature vectors for a face at a parametric
+     * position.  Magnitudes of vectors are curvature, directions are
+     * directions of principal curvatures.
+  void iGeom_getFcCvtrUV( iGeom_Instance instance,
+                          iBase_EntityHandle face_handle,
                           double u,
                           double v,
                           double* cvtr1_i,
@@ -1824,10 +2166,28 @@
                           double* cvtr2_k,
                           int* err );
-/**\brief
-  void iGeom_getFcArrCvtrUV( iGeom_Instance,
+    /**\brief  Get the curvature(s) on face(s) at given parametric position(s)
+     * Get the curvature(s) on face(s) at given parametric position(s).  If
+     * either the number of faces or number of coordinate pairs is unity, then
+     * \param face_handles Face(s) being queried
+     * \param face_handles_size Number of entities being queried
+     * \param uv Starting parametric coordinates
+     * \param uv_size Number of values in uv array
+  void iGeom_getFcArrCvtrUV( iGeom_Instance instance,
                              int storage_order,
@@ -1841,19 +2201,37 @@
                              int* cvtr_2_size,
                              int* err );
-/**\brief
-  void iGeom_isEntPeriodic( iGeom_Instance,
+    /**\brief  Return whether an entity is periodic
+     * Return whether an entity is periodic (=1) or not (=0) in the u and v
+     * directions.
+     * \param entity_handle Entity being queried
+     * \param in_u Entity is periodic in u direction (=1) or not (=0)
+     * \param in_v Entity is periodic in v direction (=1) or not (=0)
+  void iGeom_isEntPeriodic( iGeom_Instance instance,
                             int* in_u,
                             int* in_v,
                             int* err );
-/**\brief
-  void iGeom_isArrPeriodic( iGeom_Instance,
+    /**\brief  Return whether entities are periodic
+     * Return whether entities are periodic (=1) or not (=0) in the u and v
+     * directions.
+     * \param entity_handles_size Number of entities being queried
+     * \param in_uv Array of pairs of integers representing whether
+     *        entity_handles[i] is periodic (=1) or not (=0) in u and v
+     *        directions
+     * \param in_uv_allocated Allocated size of in_uv array
+     * \param in_uv_size Occupied size of in_uv array
+  void iGeom_isArrPeriodic( iGeom_Instance instance,
                             int** in_uv,
@@ -1861,18 +2239,31 @@
                             int* in_uv_size,
                             int* err );
-/**\brief
-  void iGeom_isFcDegenerate( iGeom_Instance,
+    /**\brief  Return whether a face is degenerate
+     * Return whether a face is degenerate (=1) or not (=0).
+     * \param is_degenerate Face is degenerate (=1) or not (=0)
+  void iGeom_isFcDegenerate( iGeom_Instance instance,
                              int* is_degenerate,
                              int* err );
-/**\brief
-  void iGeom_isFcArrDegenerate( iGeom_Instance,
+    /**\brief  Return whether faces are degenerate
+     * Return whether faces are degenerate (=1) or not (=0).
+     * \param degenerate face_handles[i] is degenerate (=1) or not (=0)
+     * \param degenerate_allocated Allocated size of degenerate array
+     * \param degenerate_size Occupied size of degenerate array
+  void iGeom_isFcArrDegenerate( iGeom_Instance instance,
                                 int** degenerate,
@@ -1880,26 +2271,48 @@
                                 int* degenerate_size,
                                 int* err );
-/**\brief
-  void iGeom_getTolerance( iGeom_Instance,
+    /**\brief  Get the tolerance of the instance
+     * Get the tolerance at the modeler level.  type is an integer representing
+     * the type of the tolerance, where 0 = no tolerance information,
+     * 1 = modeler-level tolerance, 2 = entity-level tolerances.  If type is 1,
+     * tolerance returns the modeler-level tolerance.  If type is 2, use
+     * iGeom_getEntTolerance to query the tolerance on a per-entity basis.
+     * \param type Type of tolerance used by the modeler
+     * \param tolerance Modeler-level tolerance, if any
+  void iGeom_getTolerance( iGeom_Instance instance,
                            int* type,
                            double* tolerance,
                            int* err );
-/**\brief
-  void iGeom_getEntTolerance( iGeom_Instance,
+    /**\brief  Get the tolerance of the specified entity
+     * Get the tolerance of the specified entity.
+     * \param entity_handle Entity handle being queried
+     * \param tolerance Pointer to tolerance returned from function
+  void iGeom_getEntTolerance( iGeom_Instance instance,
                               double* tolerance,
                               int* err );
-/**\brief
-  void iGeom_getArrTolerance( iGeom_Instance,
+    /**\brief  Get the tolerances of the specified entities
+     * Get the tolerances of the specified entities.
+     * \param tolerance Pointer to array of tolerances returned from function
+     * \param tolerance_allocated Pointer to allocated size of tolerance array
+     * \param tololerance_size Pointer to occupied size of tolerance array
+  void iGeom_getArrTolerance( iGeom_Instance instance,
                               double** tolerances,
@@ -1907,50 +2320,43 @@
                               int* tolerances_size,
                               int* err );
-    /**\brief  Initialize an iterator over specified entity type, topology, and size
+    /**\brief  Initialize an iterator over specified entity type
-     * Initialize an iterator over specified entity type, topology, and size,
-     * for a specified set or instance.  Iterator returned can be used as input
-     * to functions returning the entity for the iterator.  If all entities of
-     * a specified type and/or topology are to be iterated, specify
-     * iBase_ALL_TYPES or iGeom_ALL_TOPOLOGIES, respectively.  Specified type
-     * or topology must be a value in the iBase_EntityType or
-     * iGeom_EntityTopology enumerations, respectively.
+     * Initialize an iterator over specified entity type for a specified set or
+     * instance.  Iterator returned can be used as input to functions returning
+     * the entity for the iterator.  If all entities of a specified type are to
+     * be iterated, specify iBase_ALL_TYPES.  Specified type must be a value in
+     * the iBase_EntityType enumeration.
      * \param entity_set_handle Entity set being iterated
      * \param requested_entity_type Type of entity to iterate
-     * \param requested_entity_topology Topology of entity to iterate
      * \param entity_iterator Pointer to iterator returned from function
-  void iGeom_initEntIter( iGeom_Instance,
+  void iGeom_initEntIter( iGeom_Instance instance,
                           iBase_EntitySetHandle entity_set_handle,
-                          int entity_dimension,
+                          int requested_entity_type,
                           iGeom_EntityIterator* entity_iterator,
                           int* err );
-    /**\brief Initialize an array iterator over specified entity type, topology, and
-     *        size
+    /**\brief  Initialize an array iterator over specified entity type and size
-     * Initialize an array iterator over specified entity type, topology, and
-     * size, for a specified set or instance.  Iterator returned can be used
-     * as input to functions returning entities for the iterator.  If all
-     * entities of a specified type and/or topology are to be iterated,
-     * specify iBase_ALL_TYPES or iGeom_ALL_TOPOLOGIES, respectively.
-     * Specified type or topology must be a value in the iBase_EntityType or
+     * Initialize an array iterator over specified entity type and size for a
+     * specified set or instance.  Iterator returned can be used as input to
+     * functions returning entities for the iterator.  If all entities of a
+     * specified type are to be iterated, specify iBase_ALL_TYPES. Specified
+     * type must be a value in the iBase_EntityType enumerations.
      * \param requested_array_size Size of chunks of handles returned for each
      *        value of the iterator
      * \param entArr_iterator Pointer to iterator returned from function
-  void iGeom_initEntArrIter( iGeom_Instance,
+  void iGeom_initEntArrIter( iGeom_Instance instance,
                              int requested_array_size,
                              iGeom_EntityArrIterator* entArr_iterator,
                              int* err );
@@ -1970,8 +2376,8 @@
      *        is valid. A zero value indicates the value is NOT valid.
-  void iGeom_getNextEntIter( iGeom_Instance,
-                             iGeom_EntityIterator,
+  void iGeom_getNextEntIter( iGeom_Instance instance,
+                             iGeom_EntityIterator entity_iterator,
                              int* has_data,
                              int* err );
@@ -1996,8 +2402,8 @@
      *        valid.
-  void iGeom_getNextEntArrIter( iGeom_Instance,
-                                iGeom_EntityArrIterator,
+  void iGeom_getNextEntArrIter( iGeom_Instance instance,
+                                iGeom_EntityArrIterator entArr_iterator,
                                 iBase_EntityHandle** entity_handles,
                                 int* entity_handles_allocated,
                                 int* entity_handles_size,
@@ -2011,8 +2417,8 @@
      * \param entity_iterator Iterator to reset
-  void iGeom_resetEntIter( iGeom_Instance,
+  void iGeom_resetEntIter( iGeom_Instance instance,
                            int* err );
     /**\brief  Reset the array iterator
@@ -2022,8 +2428,8 @@
      * \param entArr_iterator Iterator to reset
-  void iGeom_resetEntArrIter( iGeom_Instance,
+  void iGeom_resetEntArrIter( iGeom_Instance instance,
                               int* err );
     /**\brief  Destroy the specified iterator
@@ -2033,7 +2439,9 @@
      * \param entity_iterator Iterator which gets destroyed
-  void iGeom_endEntIter( iGeom_Instance, iGeom_EntityIterator, int* err );
+  void iGeom_endEntIter( iGeom_Instance instance,
+                         int* err );
     /**\brief  Destroy the specified array iterator
@@ -2042,31 +2450,53 @@
      * \param entArr_iterator Iterator which gets destroyed
-  void iGeom_endEntArrIter( iGeom_Instance, iGeom_EntityArrIterator, int* err );
+  void iGeom_endEntArrIter( iGeom_Instance instance,
+                            int* err );
-/**\brief Make a copy of the specified entity
-  void iGeom_copyEnt( iGeom_Instance,
+    /**\brief  Make a copy of the specified entity
+     * Make a copy of the specified entity
+     * \param source entity to be copied
+     * \param copy the newly-created entity
+  void iGeom_copyEnt( iGeom_Instance instance,
                       iBase_EntityHandle source,
                       iBase_EntityHandle* copy,
                       int* err );
-/**\brief
-  void iGeom_sweepEntAboutAxis( iGeom_Instance,
+    /**\brief  Sweep (extrude) an entity about an axis
+     * Sweep (extrude) an entity by the given angle about the given axis.
+     * \param geom_entity the entity to rotate
+     * \param angle the rotational angle, in degrees
+     * \param axis_x x coordinate of the axis
+     * \param axis_y y coordinate of the axis
+     * \param axis_z z coordinate of the axis
+     * \param geom_entity2 Pointer to new entity handle returned from function
+  void iGeom_sweepEntAboutAxis( iGeom_Instance instance,
                                 iBase_EntityHandle geom_entity,
                                 double angle,
-                                double axis_normal_x,
-                                double axis_normal_y,
-                                double axis_normal_z,
+                                double axis_x,
+                                double axis_y,
+                                double axis_z,
                                 iBase_EntityHandle* geom_entity2,
                                 int* err );
-  /**\brief Delete all entities and sets
-  void iGeom_deleteAll( iGeom_Instance, int* err );
+    /**\brief  Delete all entities and sets
+     * Delete all entities and sets
+  void iGeom_deleteAll( iGeom_Instance instance,
+                        int* err );
     /**\brief  Delete specified entity
@@ -2075,164 +2505,252 @@
      * \param entity_handle Entity to be deleted
-  void iGeom_deleteEnt( iGeom_Instance,
-                        iBase_EntityHandle,
+  void iGeom_deleteEnt( iGeom_Instance instance,
+                        iBase_EntityHandle entity_handle,
                         int* err );
-    /**\brief Create a sphere centered on the origin
+    /**\brief Create a sphere
+     * Create a sphere of the specified radius centered on the origin.
+     * \param radius radius of the sphere
+     * \param geom_entity Pointer to new entity handle returned from function
-  void iGeom_createSphere( iGeom_Instance,
+  void iGeom_createSphere( iGeom_Instance instance,
                            double radius,
-                           iBase_EntityHandle* sphere_handle_out,
+                           iBase_EntityHandle* geom_entity,
                            int* err );
-/**\brief Create a prism centered on the origin
-void iGeom_createPrism( iGeom_Instance,
-                   double height,
-		   int n_sides,
-		   double major_rad,
-	           double minor_rad,
-	           iBase_EntityHandle* prism_handle_out,
-                   int* err );
+    /**\brief  Create a prism
+     * Create a prism parallel to the z-axis and centered at the origin (so
+     * that its z-coordinate extents are +height/2 and -height/2).
+     * \param height height of new prism
+     * \param n_sides number of sides of new prism
+     * \param major_rad major radius of new prism
+     * \param minor_rad minor radius of new prism
+  void iGeom_createPrism( iGeom_Instance instance,
+                          double height,
+                          int n_sides,
+                          double major_rad,
+                          double minor_rad,
+                          int* err );
-/**\brief Create an axis-oriented box
- * Create an axis-oriented box of the given dimensions, centered at the origin
-  void iGeom_createBrick( iGeom_Instance,
+    /**\brief  Create an axis-oriented box
+     * Create an axis-oriented box of the given dimensions, centered at the
+     * origin.
+     * \param x x dimension of new box
+     * \param y y dimension of new box
+     * \param z z dimension of new box
+  void iGeom_createBrick( iGeom_Instance instance,
                           double x,
                           double y,
                           double z,
                           int* err );
-/**\brief Create a cylinder
- * Create a cylinder parallel to the z-axis and centered at the origin
- * (so that its z-coordinate extents are +height/2 and -height/2).
- * \param height The height of the cylinder.
- * \param major_rad The x-axis radius
- * \param minor_rad The y-axis radius. If minor_rad is 0, the cylinder will
- *                  be circular (as if minor_rad == major_rad).
-  void iGeom_createCylinder( iGeom_Instance,
+    /**\brief  Create a cylinder
+     * Create a cylinder parallel to the z-axis and centered at the origin (so
+     * \param height The height of the cylinder.
+     * \param major_rad The x-axis radius
+     * \param minor_rad The y-axis radius. If minor_rad is 0, the cylinder will
+     *        be circular (as if minor_rad == major_rad).
+  void iGeom_createCylinder( iGeom_Instance instance,
                              double height,
                              double major_rad,
                              double minor_rad,
                              int* err );
-/**\brief Create a cone or tapered cylinder
- * Create a cone parallel to the z-axis and centered at the origin
- * The 'base' of the cylinder is at z = -height/2, and the top is at +height/2.
- * \param height The height of the cone.
- * \param major_rad_base The x-axis radius at the base of the cylinder
- * \param minor_rad_base The y-axis radius at the base.  If minor_rad_base is 0,
- *                       the cylinder will be circular (as if
- *                       minor_rad_base == major_rad_base)
- * \param rad_top The x-axis radius at the top of the cone.  The y-axis radius
- *                at the top of the cone will be inferred to keep the aspect
- *                ratio of the top of the cone the same as the bottom.
- *                If rad_top is 0, the cone terminates at a point.
-  void iGeom_createCone( iGeom_Instance,
-			 double height,
-			 double major_rad_base,
-			 double minor_rad_base,
-			 double rad_top,
-			 iBase_EntityHandle* geom_entity,
-			 int* err );
+    /**\brief  Create a cone or tapered cylinder
+     * Create a cone parallel to the z-axis and centered at the origin (so that
+     * its z-coordinate extents are +height/2 and -height/2). The 'base' of the
+     * cylinder is at z = -height/2, and the top is at +height/2.
+     * \param height The height of the cone.
+     * \param major_rad_base The x-axis radius at the base of the cylinder
+     * \param minor_rad_base The y-axis radius at the base.  If minor_rad_base
+     *        is 0, the cylinder will be circular (as if minor_rad_base ==
+     *        major_rad_base)
+     * \param rad_top The x-axis radius at the top of the cone.  The y-axis
+     *        radius at the top of the cone will be inferred to keep the aspect
+     *        ratio of the top of the cone the same as the bottom. If rad_top is
+     *        0, the cone terminates at a point.
+  void iGeom_createCone( iGeom_Instance instance,
+                         double height,
+                         double major_rad_base,
+                         double minor_rad_base,
+                         double rad_top,
+                         int* err );
-/**\brief Create a torus
- * Create a torus centered on the origin and encircling the z-axis.
- * \param major_rad The distance from the origin to the center of the
- *                  torus's circular cross-section.
- * \param minor_rad The radius of the cross-section.
-  void iGeom_createTorus( iGeom_Instance,
+    /**\brief  Create a torus
+     * Create a torus centered on the origin and encircling the z-axis.
+     * \param major_rad The distance from the origin to the center of the
+     *        torus's circular cross-section.
+     * \param minor_rad The radius of the cross-section.
+  void iGeom_createTorus( iGeom_Instance instance,
                           double major_rad,
                           double minor_rad,
                           int* err );
-/**\brief Move an entity by the given vector
-  void iGeom_moveEnt( iGeom_Instance,
+    /**\brief  Move an entity by the given vector
+     * Move an entity by translating it along the given vector.
+     * \param geom_entity the entity to move
+     * \param x x coordinate of the vector
+     * \param y y coordinate of the vector
+     * \param z z coordinate of the vector
+  void iGeom_moveEnt( iGeom_Instance instance,
                       double x,
                       double y,
                       double z,
                       int* err );
-/**\brief Rotate an entity about a given axis
- * \param angle The rotational angle, in degrees.
-  void iGeom_rotateEnt( iGeom_Instance,
+    /**\brief  Rotate an entity about an axis
+     * Rotate an entity by the given angle about the given axis.
+  void iGeom_rotateEnt( iGeom_Instance instance,
                         double angle,
+                        double axis_x,
+                        double axis_y,
+                        double axis_z,
                         int* err );
-/**\brief
-  void iGeom_reflectEnt( iGeom_Instance,
+   /**\brief  Reflect an entity across a plane
+     * Reflect an entity across the given plane
+     * \param geom_entity the entity to reflect
+     * \param plane_normal_x x coordinate of the plane's normal
+     * \param plane_normal_y y coordinate of the plane's normal
+     * \param plane_normal_z z coordinate of the plane's normal
+  void iGeom_reflectEnt( iGeom_Instance instance,
                          double plane_normal_x,
                          double plane_normal_y,
                          double plane_normal_z,
                          int* err );
-/**\brief
-  void iGeom_scaleEnt( iGeom_Instance,
+   /**\brief  Scale an entity in the x, y, and z directions
+     * Scale an entity in the x, y, and z directions.
+     * \param geom_entity the entity to scale
+     * \param scale_x factor to scale by in the x direction
+     * \param scale_y factor to scale by in the y direction
+     * \param scale_z factor to scale by in the z direction
+  void iGeom_scaleEnt( iGeom_Instance instance,
                        double scale_x,
                        double scale_y,
                        double scale_z,
                        int* err );
-/**\brief
-  void iGeom_uniteEnts( iGeom_Instance,
+    /**\brief  Geometrically unite entities
+     * Geometrically unite the specified entities.
+     * \param geom_entities Array of entity handles being united
+     * \param geom_entities_size Number of entities in geom_entities array
+  void iGeom_uniteEnts( iGeom_Instance instace,
                         iBase_EntityHandle const* geom_entities,
                         int geom_entities_size,
                         int* err );
-/**\brief
-  void iGeom_subtractEnts( iGeom_Instance,
+    /**\brief  Geometrically subtract one entity from another
+     * Geometrically subtract the entity tool from the entity blank.
+     * \param blank The entity to subtract from
+     * \param tool The entity to subtract
+  void iGeom_subtractEnts( iGeom_Instance instance,
                            iBase_EntityHandle blank,
                            iBase_EntityHandle tool,
                            int* err );
-/**\brief
-  void iGeom_intersectEnts( iGeom_Instance,
+    /**\brief  Geometrically intersect a pair of entities
+     * Geometrically intersect a pair of entities.
+     * \param entity1 The entity to intersect
+     * \param entity2 The entity to intersect
+  void iGeom_intersectEnts( iGeom_Instance instance,
                             iBase_EntityHandle entity2,
-			    iBase_EntityHandle entity1,
-			    int* err );
+                            iBase_EntityHandle entity1,
+                            int* err );
-/**\brief
-  void iGeom_sectionEnt( iGeom_Instance,
+    /**\brief  Section (cut) a region with a plane
+     * Section (cut) a region with a plane, retaining one of the pieces and
+     * discarding the other.
+     * \param geom_entity The entity to section
+     * \param offset Distance of the plane from the origin
+     * \param reverse Keep the piece on the normal's side (=0) or not (=1)
+  void iGeom_sectionEnt( iGeom_Instance instance,
@@ -2242,24 +2760,35 @@
                          int* err );
-/**\brief
-  void iGeom_imprintEnts( iGeom_Instance,
+    /**\brief  Imprint entities
+     * Imprint entities by merging coincident surfaces.
+     * \param geom_entities Array of entity handles being imprinted
+  void iGeom_imprintEnts( iGeom_Instance instance,
                           int* err );
-/**\brief
-  void iGeom_mergeEnts( iGeom_Instance,
+    /**\brief  Merge ents
+     * Merge entities of corresponding topology/geometry within the specified
+     * tolerance.
+     * \param tolerance Tolerance within which entities are considered the same
+  void iGeom_mergeEnts( iGeom_Instance instance,
                         double tolerance,
                         int* err );
     /**\brief  Create an entity set
      * Create an entity set, either ordered (isList=1) or unordered
@@ -2271,12 +2800,11 @@
      * \param entity_set_created Entity set created by function
-  void iGeom_createEntSet(iGeom_Instance instance,
-                          int isList,
-                          iBase_EntitySetHandle* entity_set_created,
-                          int *err);
+  void iGeom_createEntSet( iGeom_Instance instance,
+                           int isList,
+                           iBase_EntitySetHandle* entity_set_created,
+                           int *err );
     /**\brief  Destroy an entity set
      * Destroy an entity set
@@ -2284,9 +2812,9 @@
      * \param entity_set Entity set to be destroyed
-  void iGeom_destroyEntSet(iGeom_Instance instance,
-                           iBase_EntitySetHandle entity_set,
-                           int *err);
+  void iGeom_destroyEntSet( iGeom_Instance instance,
+                            iBase_EntitySetHandle entity_set,
+                            int *err );
     /**\brief  Return whether a specified set is ordered or unordered
@@ -2297,10 +2825,10 @@
      * \param is_list Pointer to flag returned from function
-  void iGeom_isList(iGeom_Instance instance,
-                    int *is_list,
-                    int *err);
+  void iGeom_isList( iGeom_Instance instance,
+                     int *is_list,
+                     int *err );
     /**\brief  Get the number of entity sets contained in a set or interface
@@ -2315,13 +2843,12 @@
      * \param num_sets Pointer to the number of sets returned from function
-  void iGeom_getNumEntSets(iGeom_Instance instance,
-                           iBase_EntitySetHandle entity_set_handle,
-                           int num_hops,
-                           int *num_sets,
-                           int *err);
+  void iGeom_getNumEntSets( iGeom_Instance instance,
+                            iBase_EntitySetHandle entity_set_handle,
+                            int num_hops,
+                            int *num_sets,
+                            int *err );
     /**\brief  Get the entity sets contained in a set or interface
      * Get the entity sets contained in a set or interface.  If
@@ -2340,13 +2867,13 @@
      *        contained_set_handles array
-  void iGeom_getEntSets(iGeom_Instance instance,
-                        int num_hops,
-                        iBase_EntitySetHandle** contained_set_handles,
-                        int* contained_set_handles_allocated,
-                        int* contained_set_handles_size,
-                        int *err);
+  void iGeom_getEntSets( iGeom_Instance instance,
+                         int num_hops,
+                         iBase_EntitySetHandle** contained_set_handles,
+                         int* contained_set_handles_allocated,
+                         int* contained_set_handles_size,
+                         int *err );
     /**\brief  Add an entity to a set
@@ -2356,10 +2883,10 @@
      * \param entity_set Pointer to the set being added to
-  void iGeom_addEntToSet(iGeom_Instance instance,
-                         int *err);
+  void iGeom_addEntToSet( iGeom_Instance instance,
+                          int *err );
     /**\brief  Remove an entity from a set
@@ -2370,12 +2897,11 @@
      * \param entity_set Pointer to the set being removed from
-  void iGeom_rmvEntFromSet(iGeom_Instance instance,
-                           int *err);
+  void iGeom_rmvEntFromSet( iGeom_Instance instance,
+                            int *err );
     /**\brief  Add an array of entities to a set
      * Add an array of entities to a set
@@ -2385,13 +2911,12 @@
-  void iGeom_addEntArrToSet(iGeom_Instance instance,
-                            const iBase_EntityHandle* entity_handles,
-                            int entity_handles_size,
-                            int *err);
+  void iGeom_addEntArrToSet( iGeom_Instance instance,
+                             const iBase_EntityHandle* entity_handles,
+                             int entity_handles_size,
+                             int *err );
     /**\brief  Remove an array of entities from a set
      * Remove an array of entities from a set
@@ -2401,13 +2926,12 @@
-  void iGeom_rmvEntArrFromSet(iGeom_Instance instance,
-                              int *err);
+  void iGeom_rmvEntArrFromSet( iGeom_Instance instance,
+                               int *err );
     /**\brief  Add an entity set to a set
      * Add an entity set to a set
@@ -2416,12 +2940,11 @@
      * \param entity_set_handle Pointer to the set being added to
-  void iGeom_addEntSet(iGeom_Instance instance,
-                       iBase_EntitySetHandle entity_set_to_add,
-                       int *err);
+  void iGeom_addEntSet( iGeom_Instance instance,
+                        iBase_EntitySetHandle entity_set_to_add,
+                        int *err);
     /**\brief  Remove an entity set from a set
      * Remove an entity set from a set
@@ -2430,10 +2953,10 @@
      * \param entity_set_handle Pointer to the set being removed from
-  void iGeom_rmvEntSet(iGeom_Instance instance,
-                       iBase_EntitySetHandle entity_set_to_remove,
-                       int *err);
+  void iGeom_rmvEntSet( iGeom_Instance instance,
+                        iBase_EntitySetHandle entity_set_to_remove,
+                        int *err );
     /**\brief  Return whether an entity is contained in another set
@@ -2446,11 +2969,11 @@
      * \param is_contained Pointer to flag returned from function
-  void iGeom_isEntContained(iGeom_Instance instance,
-                            iBase_EntitySetHandle containing_entity_set,
-                            iBase_EntityHandle contained_entity,
-                            int *is_contained,
-                            int *err);
+  void iGeom_isEntContained( iGeom_Instance instance,
+                             iBase_EntitySetHandle containing_entity_set,
+                             iBase_EntityHandle contained_entity,
+                             int *is_contained,
+                             int *err );
     /**\brief  Return whether entities are contained in a set
@@ -2463,13 +2986,13 @@
   void iGeom_isEntArrContained( iGeom_Instance instance,
-                         /*in*/ iBase_EntitySetHandle containing_set,
-                         /*in*/ const iBase_EntityHandle* entity_handles,
-                         /*in*/ int num_entity_handles,
-                      /*inout*/ int** is_contained,
-                      /*inout*/ int* is_contained_allocated,
-                        /*out*/ int* is_contained_size,
-                        /*out*/ int* err );
+                                /*in*/ iBase_EntitySetHandle containing_set,
+                                /*in*/ const iBase_EntityHandle* entity_handles,
+                                /*in*/ int num_entity_handles,
+                                /*inout*/ int** is_contained,
+                                /*inout*/ int* is_contained_allocated,
+                                /*out*/ int* is_contained_size,
+                                /*out*/ int* err );
     /**\brief  Return whether an entity set is contained in another set
@@ -2482,11 +3005,11 @@
-  void iGeom_isEntSetContained(iGeom_Instance instance,
-                               iBase_EntitySetHandle contained_entity_set,
-                               int *err);
+  void iGeom_isEntSetContained( iGeom_Instance instance,
+                                iBase_EntitySetHandle contained_entity_set,
+                                int *err );
     /**\brief  Add parent/child links between two sets
@@ -2497,10 +3020,10 @@
      * \param child_entity_set Pointer to child set
-  void iGeom_addPrntChld(iGeom_Instance instance,
-                         iBase_EntitySetHandle parent_entity_set,
-                         iBase_EntitySetHandle child_entity_set,
-                         int *err);
+  void iGeom_addPrntChld( iGeom_Instance instance,
+                          iBase_EntitySetHandle parent_entity_set,
+                          iBase_EntitySetHandle child_entity_set,
+                          int *err );
     /**\brief  Remove parent/child links between two sets
@@ -2510,10 +3033,10 @@
-  void iGeom_rmvPrntChld(iGeom_Instance instance,
-                         int *err);
+  void iGeom_rmvPrntChld( iGeom_Instance instance,
+                          int *err );
     /**\brief  Return whether two sets are related by parent/child links
@@ -2525,11 +3048,11 @@
      * \param is_child Pointer to flag returned from function
-  void iGeom_isChildOf(iGeom_Instance instance,
-                       int *is_child,
-                       int *err);
+  void iGeom_isChildOf( iGeom_Instance instance,
+                        int *is_child,
+                        int *err );
     /**\brief  Get the number of child sets linked from a specified set
@@ -2543,11 +3066,11 @@
      * \param num_child Pointer to number of children returned from function
-  void iGeom_getNumChld(iGeom_Instance instance,
-                        int num_hops,
-                        int *num_child,
-                        int *err);
+  void iGeom_getNumChld( iGeom_Instance instance,
+                         int num_hops,
+                         int *num_child,
+                         int *err );
     /**\brief  Get the number of parent sets linked from a specified set
@@ -2561,11 +3084,11 @@
      * \param num_parent Pointer to number of parents returned from function
-  void iGeom_getNumPrnt(iGeom_Instance instance,
-                        int num_hops,
-                        int *num_parent,
-                        int *err);
+  void iGeom_getNumPrnt( iGeom_Instance instance,
+                         int num_hops,
+                         int *num_parent,
+                         int *err );
     /**\brief  Get the child sets linked from a specified set
@@ -2584,13 +3107,13 @@
      *        entity_set_handles array
-  void iGeom_getChldn(iGeom_Instance instance,
-                      iBase_EntitySetHandle from_entity_set,
-                      int num_hops,
-                      iBase_EntitySetHandle** entity_set_handles,
-                      int* entity_set_handles_allocated,
-                      int* entity_set_handles_size,
-                      int *err);
+  void iGeom_getChldn( iGeom_Instance instance,
+                       iBase_EntitySetHandle from_entity_set,
+                       int num_hops,
+                       iBase_EntitySetHandle** entity_set_handles,
+                       int* entity_set_handles_allocated,
+                       int* entity_set_handles_size,
+                       int *err );
     /**\brief  Get the parent sets linked from a specified set
@@ -2609,13 +3132,13 @@
-  void iGeom_getPrnts(iGeom_Instance instance,
-                      int num_hops,
-                      int *err);
+  void iGeom_getPrnts( iGeom_Instance instance,
+                       int num_hops,
+                       int *err );
     /**\brief  Create a tag with specified name, size, and type
@@ -2631,13 +3154,13 @@
      * \param tag_name_len Length of tag name string
-  void iGeom_createTag(iGeom_Instance instance,
-                       const char* tag_name,
-                       int tag_size,
-                       int tag_type,
-                       iBase_TagHandle* tag_handle,
-                       int *err,
-                       int tag_name_len );
+  void iGeom_createTag( iGeom_Instance instance,
+                        const char* tag_name,
+                        int tag_size,
+                        int tag_type,
+                        iBase_TagHandle* tag_handle,
+                        int *err,
+                        int tag_name_len );
     /**\brief  Destroy a tag
@@ -2651,10 +3174,10 @@
      *        set for that tag
-  void iGeom_destroyTag(iGeom_Instance instance,
-                        iBase_TagHandle tag_handle,
-                        int forced,
-                        int *err);
+  void iGeom_destroyTag( iGeom_Instance instance,
+                         iBase_TagHandle tag_handle,
+                         int forced,
+                         int *err);
     /**\brief  Get the name for a given tag handle
@@ -2666,11 +3189,11 @@
      * \param name_len Length of character string input to function
-  void iGeom_getTagName(iGeom_Instance instance,
-                        char *name,
-                        int* err,
-                        int name_len);
+  void iGeom_getTagName( iGeom_Instance instance,
+                         char *name,
+                         int* err,
+                         int name_len );
     /**\brief  Get size of a tag in units of numbers of tag data type
@@ -2680,10 +3203,10 @@
      * \param tag_size Pointer to tag size returned from function
-  void iGeom_getTagSizeValues(iGeom_Instance instance,
-                              int *tag_size,
-                              int *err);
+  void iGeom_getTagSizeValues( iGeom_Instance instance,
+                               int *tag_size,
+                               int *err );
     /**\brief  Get size of a tag in units of bytes
@@ -2693,10 +3216,10 @@
-  void iGeom_getTagSizeBytes(iGeom_Instance instance,
-                             int *tag_size,
-                             int *err);
+  void iGeom_getTagSizeBytes( iGeom_Instance instance,
+                              int *tag_size,
+                              int *err );
     /**\brief  Get a the handle of an existing tag with the specified name
@@ -2707,11 +3230,11 @@
-  void iGeom_getTagHandle(iGeom_Instance instance,
-                          iBase_TagHandle *tag_handle,
-                          int *err,
-                          int tag_name_len);
+  void iGeom_getTagHandle( iGeom_Instance instance,
+                           iBase_TagHandle *tag_handle,
+                           int *err,
     /**\brief  Get the data type of the specified tag handle
@@ -2722,12 +3245,11 @@
      * \param tag_type Pointer to tag type returned from function
-  void iGeom_getTagType(iGeom_Instance instance,
-                        int *tag_type,
-                        int *err);
+  void iGeom_getTagType( iGeom_Instance instance,
+                         int *tag_type,
+                         int *err );
     /**\brief  Set a tag value of arbitrary type on an entity set
      * Set a tag value of arbitrary type on an entity set.  Tag data is
@@ -2740,14 +3262,13 @@
      * \param tag_value_size Size in bytes of tag data
-  void iGeom_setEntSetData(iGeom_Instance instance,
-                           const char* tag_value,
-                           int tag_value_size,
-                           int *err);
+  void iGeom_setEntSetData( iGeom_Instance instance,
+                            const char* tag_value,
+                            int tag_value_size,
+                            int *err );
     /**\brief  Set a tag value of integer type on an entity set
      * Set a tag value of integer type on an entity set.
@@ -2757,13 +3278,12 @@
      * \param tag_value Tag value being set on entity set
-  void iGeom_setEntSetIntData(iGeom_Instance instance,
-                              int tag_value,
-                              int *err);
+  void iGeom_setEntSetIntData( iGeom_Instance instance,
+                               int tag_value,
+                               int *err );
     /**\brief  Set a tag value of double type on an entity set
      * Set a tag value of double type on an entity set.
@@ -2773,13 +3293,12 @@
-  void iGeom_setEntSetDblData(iGeom_Instance instance,
-                              double tag_value,
-                              int *err);
+  void iGeom_setEntSetDblData( iGeom_Instance instance,
+                               double tag_value,
+                               int *err );
     /**\brief  Set a tag value of entity handle type on an entity set
      * Set a tag value of entity handle type on an entity set.
@@ -2789,13 +3308,12 @@
-  void iGeom_setEntSetEHData(iGeom_Instance instance,
-                             iBase_EntityHandle tag_value,
-                             int *err);
+  void iGeom_setEntSetEHData( iGeom_Instance instance,
+                              iBase_EntityHandle tag_value,
+                              int *err );
     /**\brief  Get the value of a tag of arbitrary type on an entity set
      * Get the value of a tag of arbitrary type on an entity set.  Tag data
@@ -2808,13 +3326,13 @@
      * \param *tag_value_size Pointer to tag data array occupied size
-  void iGeom_getEntSetData(iGeom_Instance instance,
-                           char** tag_value,
-                           int* tag_value_allocated,
-                           int* tag_value_size,
-                           int *err);
+  void iGeom_getEntSetData( iGeom_Instance instance,
+                            char** tag_value,
+                            int* tag_value_allocated,
+                            int* tag_value_size,
+                            int *err );
     /**\brief  Get the value of a tag of integer type on an entity set
@@ -2825,11 +3343,11 @@
      * \param *out_data Pointer to tag value returned from function
-  void iGeom_getEntSetIntData(iGeom_Instance instance,
-                              int *out_data,
-                              int *err);
+  void iGeom_getEntSetIntData( iGeom_Instance instance,
+                               int *out_data,
+                               int *err );
     /**\brief  Get the value of a tag of double type on an entity set
@@ -2840,11 +3358,11 @@
-  void iGeom_getEntSetDblData(iGeom_Instance instance,
-                              double *out_data,
-                              int *err);
+  void iGeom_getEntSetDblData( iGeom_Instance instance,
+                               double *out_data,
+                               int *err );
     /**\brief  Get the value of a tag of entity handle type on an entity set
@@ -2855,11 +3373,11 @@
-  void iGeom_getEntSetEHData(iGeom_Instance instance,
-                             iBase_EntityHandle *out_data,
-                             int *err);
+  void iGeom_getEntSetEHData( iGeom_Instance instance,
+                              iBase_EntityHandle *out_data,
+                              int *err );
     /**\brief  Get all the tags associated with a specified entity set
@@ -2873,12 +3391,12 @@
      * \param *tag_handles_size Pointer to occupied size of tag_handles array
-  void iGeom_getAllEntSetTags(iGeom_Instance instance,
-                              iBase_TagHandle** tag_handles,
-                              int* tag_handles_allocated,
-                              int* tag_handles_size,
-                              int *err);
+  void iGeom_getAllEntSetTags( iGeom_Instance instance,
+                               iBase_TagHandle** tag_handles,
+                               int* tag_handles_allocated,
+                               int* tag_handles_size,
+                               int *err );
     /**\brief  Remove a tag value from an entity set
@@ -2888,12 +3406,11 @@
      * \param tag_handle Tag handle of tag being removed
-  void iGeom_rmvEntSetTag(iGeom_Instance instance,
-                          int *err);
+  void iGeom_rmvEntSetTag( iGeom_Instance instance,
+                           int *err );
     /**\brief  Get tag values of arbitrary type for an array of entities
      * Get tag values of arbitrary type for an array of entities.  Tag data
@@ -2908,14 +3425,14 @@
      * \param tag_values_size Pointer to occupied size of tag data array
-  void iGeom_getArrData(iGeom_Instance instance,
-                        char** tag_values,
-                        int* tag_values_allocated,
-                        int* tag_values_size,
-                        int *err);
+  void iGeom_getArrData( iGeom_Instance instance,
+                         char** tag_values,
+                         int* tag_values_allocated,
+                         int* tag_values_size,
+                         int *err );
     /**\brief  Get tag values of integer type for an array of entities
@@ -2930,14 +3447,14 @@
-  void iGeom_getIntArrData(iGeom_Instance instance,
-                           int** tag_values,
-                           int *err);
+  void iGeom_getIntArrData( iGeom_Instance instance,
+                            int** tag_values,
+                            int *err );
     /**\brief  Get tag values of double type for an array of entities
@@ -2952,14 +3469,14 @@
-  void iGeom_getDblArrData(iGeom_Instance instance,
-                           double** tag_values,
-                           int *err);
+  void iGeom_getDblArrData( iGeom_Instance instance,
+                            double** tag_values,
+                            int *err );
     /**\brief  Get tag values of entity handle type for an array of entities
@@ -2974,14 +3491,14 @@
      * \param tag_value_size Pointer to occupied size of tag data array
-  void iGeom_getEHArrData(iGeom_Instance instance,
-                          iBase_EntityHandle** tag_value,
-                          int *err);
+  void iGeom_getEHArrData( iGeom_Instance instance,
+                           iBase_EntityHandle** tag_value,
+                           int *err );
     /**\brief  Set tag values of arbitrary type on an array of entities
@@ -2995,13 +3512,13 @@
      * \param tag_values_size Size in total bytes of tag data
-  void iGeom_setArrData(iGeom_Instance instance,
-                        const char* tag_values,
-                        int tag_values_size,
-                        int *err);
+  void iGeom_setArrData( iGeom_Instance instance,
+                         const char* tag_values,
+                         int tag_values_size,
+                         int *err );
     /**\brief  Set tag values of integer type on an array of entities
@@ -3014,13 +3531,13 @@
      * \param tag_values_size Size in total number of integers of tag data
-  void iGeom_setIntArrData(iGeom_Instance instance,
-                           const int* tag_values,
-                           int *err);
+  void iGeom_setIntArrData( iGeom_Instance instance,
+                            const int* tag_values,
+                            int *err );
     /**\brief  Set tag values of double type on an array of entities
@@ -3033,13 +3550,13 @@
      * \param tag_values_size Size in total number of doubles of tag data
-  void iGeom_setDblArrData(iGeom_Instance instance,
-                           const double* tag_values,
-                           const int tag_values_size,
-                           int *err);
+  void iGeom_setDblArrData( iGeom_Instance instance,
+                            const double* tag_values,
+                            const int tag_values_size,
+                            int *err );
     /**\brief  Set tag values of entity handle type on an array of entities
@@ -3053,13 +3570,13 @@
      *        data
-  void iGeom_setEHArrData(iGeom_Instance instance,
-                          const iBase_EntityHandle* tag_values,
-                          int *err);
+  void iGeom_setEHArrData( iGeom_Instance instance,
+                           const iBase_EntityHandle* tag_values,
+                           int *err );
     /**\brief  Remove a tag value from an array of entities
@@ -3070,11 +3587,11 @@
-  void iGeom_rmvArrTag(iGeom_Instance instance,
-                       int *err);
+  void iGeom_rmvArrTag( iGeom_Instance instance,
+                        int *err );
@@ -3088,13 +3605,13 @@
-  void iGeom_getData(iGeom_Instance instance,
-                     char** tag_value,
-                     int *tag_value_allocated,
-                     int *tag_value_size,
-                     int *err);
+  void iGeom_getData( iGeom_Instance instance,
+                      char** tag_value,
+                      int *tag_value_allocated,
+                      int *tag_value_size,
+                      int *err );
@@ -3105,11 +3622,11 @@
-  void iGeom_getIntData(iGeom_Instance instance,
-                        int *out_data,
-                        int *err);
+  void iGeom_getIntData( iGeom_Instance instance,
+                         int *out_data,
+                         int *err );
@@ -3120,10 +3637,11 @@
-  void iGeom_getDblData(iGeom_Instance instance,
-                        /*in*/ const iBase_EntityHandle entity_handle,
-                        /*in*/ const iBase_TagHandle tag_handle,
-                        double *out_data, int *err);
+  void iGeom_getDblData( iGeom_Instance instance,
+                         /*in*/ const iBase_EntityHandle entity_handle,
+                         /*in*/ const iBase_TagHandle tag_handle,
+                         double *out_data,
+                         int *err );
@@ -3134,11 +3652,11 @@
-  void iGeom_getEHData(iGeom_Instance instance,
-                       int *err);
+  void iGeom_getEHData( iGeom_Instance instance,
+                        int *err );
@@ -3151,12 +3669,12 @@
-  void iGeom_setData(iGeom_Instance instance,
-                     int *err);
+  void iGeom_setData( iGeom_Instance instance,
+                      int *err );
@@ -3167,11 +3685,11 @@
-  void iGeom_setIntData(iGeom_Instance instance,
-                        int tag_value,
-                        int *err);
+  void iGeom_setIntData( iGeom_Instance instance,
+                         int tag_value,
+                         int *err );
@@ -3182,11 +3700,11 @@
-  void iGeom_setDblData(iGeom_Instance instance,
-                        double tag_value,
-                        int *err);
+  void iGeom_setDblData( iGeom_Instance instance,
+                         double tag_value,
+                         int *err );
@@ -3197,11 +3715,11 @@
-  void iGeom_setEHData(iGeom_Instance instance,
-                       int *err);
+  void iGeom_setEHData( iGeom_Instance instance,
+                        int *err );
     /**\brief  Get all the tags associated with a specified entity handle
@@ -3215,12 +3733,12 @@
-  void iGeom_getAllTags(iGeom_Instance instance,
-                        int *err);
+  void iGeom_getAllTags( iGeom_Instance instance,
+                         int *err );
@@ -3230,10 +3748,10 @@
-  void iGeom_rmvTag(iGeom_Instance instance,
-                    int *err);
+  void iGeom_rmvTag( iGeom_Instance instance,
+                     int *err );
     /**\brief  Subtract contents of one entity set from another
@@ -3244,11 +3762,11 @@
      * \param result_entity_set Pointer to entity set returned from function
-  void iGeom_subtract(iGeom_Instance instance,
-                      iBase_EntitySetHandle entity_set_1,
-                      iBase_EntitySetHandle entity_set_2,
-                      iBase_EntitySetHandle* result_entity_set,
-                      int *err);
+  void iGeom_subtract( iGeom_Instance instance,
+                       iBase_EntitySetHandle entity_set_1,
+                       iBase_EntitySetHandle entity_set_2,
+                       iBase_EntitySetHandle* result_entity_set,
+                       int *err );
     /**\brief  Intersect contents of one entity set with another
@@ -3259,11 +3777,11 @@
-  void iGeom_intersect(iGeom_Instance instance,
-                       int *err);
+  void iGeom_intersect( iGeom_Instance instance,
+                        int *err );
     /**\brief  Unite contents of one entity set with another
@@ -3274,11 +3792,11 @@
-  void iGeom_unite(iGeom_Instance instance,
-                   int *err);
+  void iGeom_unite( iGeom_Instance instance,
+                    int *err );
 #ifdef __cplusplus
 } // extern "C"
More information about the cgma-dev mailing list
