[cgma-dev] r3323 - cgm/trunk/itaps
    jvporter at wisc.edu
    Tue Nov 10 16:50:23 CST 2009
Author: jvporter
Date: 2009-11-10 16:50:22 -0600 (Tue, 10 Nov 2009)
New Revision: 3323
Modified:
   cgm/trunk/itaps/iGeom_CGMA.cc
Log:
* Fix memory/sizing bugs in iGeom_getArr1stDrtv
* Make offset arrays from iGeom_getArr1stDrtv have the usual semantics
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc	2009-11-10 20:02:09 UTC (rev 3322)
+++ cgm/trunk/itaps/iGeom_CGMA.cc	2009-11-10 22:50:22 UTC (rev 3323)
@@ -4966,15 +4966,15 @@
                      int *v_offset_size,
                      int* err)
-  if (entity_handles_size != 2*uv_size) {
+  if (2*entity_handles_size != uv_size) {
     ERROR(iBase_INVALID_ENTITY_COUNT, "Mismatched input array sizes.");
     RETURN(iBase_INVALID_ENTITY_COUNT);
   CHECK_SIZE( *drvt_u, double, 3*entity_handles_size );
   CHECK_SIZE( *drvt_v, double, 3*entity_handles_size );
-  CHECK_SIZE( *u_offset, int, entity_handles_size );
-  CHECK_SIZE( *v_offset, int, entity_handles_size );
+  CHECK_SIZE( *u_offset, int, entity_handles_size+1 );
+  CHECK_SIZE( *v_offset, int, entity_handles_size+1 );
   size_t u_step, du_step, init;
   if (storage_order == iBase_BLOCKED) {
@@ -5015,15 +5015,18 @@
     v += u_step;
     du_x += du_step;
     du_y += du_step;
-    du_y += du_step;
+    du_z += du_step;
     dv_x += du_step;
     dv_y += du_step;
-    dv_y += du_step;
+    dv_z += du_step;
     (*u_offset)[i] = off;
     (*v_offset)[i] = off;
     off += du_step;
+  (*u_offset)[entity_handles_size] = off;
+  (*v_offset)[entity_handles_size] = off;
   RETURN(iBase_SUCCESS);
More information about the cgma-dev
