[cgma-dev] Finding ACIS in Cubit
Robert Smith
smithrm at mcs.anl.gov
Mon Oct 19 13:11:49 CDT 2009
Interestingly, I'm getting a very similar error. I'm trying to
configure CGM with an MPICH2 build using the PG 8.0.5 compiler.
I tried your compile test below and I get a name different than that
in libcubiti19.so. The results are below. I don't get the same
issues if I'm using MPICH based on GCC 4.2.4 or Intel 11.0.
smithrm at octagon:~/projects/test$ nm icc_acistest.o
U _ZN15AcisQueryEngine9instance_E
U __gxx_personality_v0
U __intel_new_proc_init
0000000000000000 T main
smithrm at octagon:~/projects/test$ nm gcc_acistest.o
smithrm at octagon:~/projects/test$ nm pg_acistest.o
0000000000000018 t __mainEND
U _main
U instance___15AcisQueryEngine
0000000000000000 t pgCC_compiled.
smithrm at octagon:~/projects/test$ nm ../sharp/3rdparty/Cubit/Cubit64/
cubit-10.2-amd64/bin/libcubiti19.so | grep AcisQueryEngine
0000000001abc680 D _ZN15AcisQueryEngine9instance_E
On Oct 19, 2009, at 1:03 PM, Jed Brown wrote:
> Jason Kraftcheck wrote:
>> I see that in this output the script is no longer trying to use
>> libtool,
>> which is a start. I'm still unsure why the link is failing. If you
>> compile the following (just compile, not link: g++ -c ...):
>> class AcisQueryEngine { public: static AcisQueryEngine* instance_; };
>> int main()
>> AcisQueryEngine::instance_ = 0;
>> return 0;
>> and then run "nm main.o | fgrep instance_". Is it the same mangled
>> name
>> as you see the Cubit library?
> $ cat > acis.C
> int main()
> return 0;
> $ g++ -c acis.C
> $ nm acis.o
> $ nm -D /home/jed/usr/cubit-20091014/bin/libcubiti19.so |grep
> AcisQueryEngine.*instance_
> 0000000001da4148 D _ZN15AcisQueryEngine9instance_E
> They match.
> Jed
More information about the cgma-dev
