[cgma-dev] r3191 - cgm/trunk
kraftche at cae.wisc.edu
Fri Oct 2 11:32:42 CDT 2009
Author: kraftche
Date: 2009-10-02 11:32:41 -0500 (Fri, 02 Oct 2009)
New Revision: 3191
Modified:
cgm/trunk/configure.ac
Log:
fix detection of libcubitiXX.so such that it works with libtool 2.x
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac 2009-10-02 13:23:51 UTC (rev 3190)
+++ cgm/trunk/configure.ac 2009-10-02 16:32:41 UTC (rev 3191)
@@ -99,27 +99,42 @@
CUBIT_LDFLAGS="-L$CUBIT_BIN_DIR"
CUBIT_LTFLAGS="-R$CUBIT_BIN_DIR"
- cat >conftest.cc <<EOCUBITCT
-class AcisQueryEngine { public: static AcisQueryEngine* instance_; };
-int main() {
- AcisQueryEngine::instance_ = 0;
- return 0;
-EOCUBITCT
+ AC_LANG_PUSH([C++])
+ old_LIBS="$LIBS"
+ old_LDFLAGS="$LDFLAGS"
+ LDFLAGS="$LDFLAGS -L$CUBIT_BIN_DIR"
+ old_SHLIB_PATH="$SH_LIBPATH"
+ old_PATH="$PATH" # windows!
+ LD_LIBRARY_PATH="${CUBIT_BIN_DIR}:$LD_LIBRARY_PATH"
+ SHLIB_PATH="${CUBIT_BIN_DIR}:$SHLIB_PATH"
+ PATH="${CUBIT_BIN_DIR}:$PATH"
+ export LD_LIBRARY_PATH
+ export SHLIB_PATH
+ export PATH
pattern=["${CUBIT_BIN_DIR}/*cubiti[0-9][0-9].*"]
for file in $pattern; do
AC_MSG_CHECKING([for AcisQueryEngine::instance_ in $file])
num=[`expr X"$file" : X".*cubiti\([0-9][0-9]\)\..*"`]
- if ./libtool --mode=link $CXX $LDFLAGS $CUBIT_LDFLAGS $CUBIT_LTFLAGS -lcubiti$num conftest.cc -o conftest >&5 2>&5; then
- CUBIT_LIBS="-lcubiti$num"
- CUBIT_FILE=`expr x"$file" : x"$CUBIT_BIN_DIR/\(.*\)"`
- CUBIT_FILE="${CUBIT_BIN_DIR}/$CUBIT_FILE"
- AC_MSG_RESULT(yes)
- else
- AC_MSG_RESULT(no)
- fi
+ LIBS="$old_LIBS -lcubiti$num"
+ AC_LINK_IFELSE([AC_LANG_PROGRAM(
+ [class AcisQueryEngine { public: static AcisQueryEngine* instance_; };],
+ [AcisQueryEngine::instance_ = 0;])],
+ [CUBIT_LIBS="-lcubiti$num"
+ CUBIT_FILE=`expr x"$file" : x"$CUBIT_BIN_DIR/\(.*\)"`
+ CUBIT_FILE="${CUBIT_BIN_DIR}/$CUBIT_FILE"
+ AC_MSG_RESULT(yes)
+ break],
+ [AC_MSG_RESULT(no)])
done
- rm -f conftest.cc
+ LIBS="$old_LIBS"
+ LDFLAGS="$old_LDFLAGS"
+ LD_LIBRARY_PATH="$old_LD_LIBRARY_PATH"
+ SHLIB_PATH="$old_SHLIB_PATH"
+ PATH="$old_PATH"
+ export SHLIB_PATH
+ export PATH
+ AC_LANG_POP([C++])
if test "x$CUBIT_LIBS" = "xno"; then
AC_MSG_ERROR("Cubit library not found in $CUBIT_BIN_DIR")
@@ -441,7 +456,8 @@
AC_OUTPUT
if test "x$CUBIT_DIR" != "xno" && test "x$CUBIT_DIR" != "x"; then
- AC_MSG_WARN([Linking against Cubit-based CGM; you'll need to add Cubit's 'bin' directory
- to your LD_LIBRARY_PATH before linking, or add -R (linux) or equivalent (non-linux)
- to your link statement to link applications.])
+ AC_MSG_WARN(
+[Linking against Cubit-based CGM; you'll need to add Cubit's 'bin' directory
+to your LD_LIBRARY_PATH before linking, or add -R (linux) or equivalent
+(non-linux) to your link statement to link applications.])
fi
More information about the cgma-dev
