[cgma-dev] r3163 - cgm/trunk/itaps
sjackson at cae.wisc.edu sjackson at cae.wisc.edu
Wed Sep 23 14:54:03 CDT 2009
Author: sjackson
Date: 2009-09-23 14:54:02 -0500 (Wed, 23 Sep 2009)
New Revision: 3163
Modified:
   cgm/trunk/itaps/iGeom.h
Log:
Add ad-hoc documentation of how the geometry creation functions in iGeom work.
Modified: cgm/trunk/itaps/iGeom.h
--- cgm/trunk/itaps/iGeom.h	2009-09-22 22:44:57 UTC (rev 3162)
+++ cgm/trunk/itaps/iGeom.h	2009-09-23 19:54:02 UTC (rev 3163)
@@ -2041,7 +2041,7 @@
   void iGeom_endEntArrIter( iGeom_Instance, iGeom_EntityArrIterator, int* err );
-/**\brief
+/**\brief Make a copy of the specified entity
   void iGeom_copyEnt( iGeom_Instance,
@@ -2093,8 +2093,9 @@
 	           iBase_EntityHandle* prism_handle_out,
                    int* err );
-/**\brief
+/**\brief Create an axis-oriented box
+ * Create an axis-oriented box of the given dimensions, centered at the origin
   void iGeom_createBrick( iGeom_Instance,
                           double x,
@@ -2103,8 +2104,14 @@
                           iBase_EntityHandle* geom_entity,
                           int* err );
-/**\brief
+/**\brief Create a cylinder
+ * Create a cylinder parallel to the z-axis and centered at the origin
+ * (so that its z-coordinate extents are +height/2 and -height/2).
+ * \param height The height of the cylinder.
+ * \param major_rad The x-axis radius
+ * \param minor_rad The y-axis radius. If minor_rad is 0, the cylinder will
+ *                  be circular (as if minor_rad == major_rad).
   void iGeom_createCylinder( iGeom_Instance,
                              double height,
@@ -2113,8 +2120,21 @@
                              int* err );
-/**\brief
+/**\brief Create a cone or tapered cylinder
+ * Create a cone parallel to the z-axis and centered at the origin
+ * The 'base' of the cylinder is at z = -height/2, and the top is at +height/2.
+ * \param height The height of the cone.
+ * \param major_rad_base The x-axis radius at the base of the cylinder
+ * \param minor_rad_base The y-axis radius at the base.  If minor_rad_base is 0,
+ *                       the cylinder will be circular (as if
+ *                       minor_rad_base == major_rad_base)
+ * \param rad_top The x-axis radius at the top of the cone.  The y-axis radius
+ *                at the top of the cone will be inferred to keep the aspect
+ *                ratio of the top of the cone the same as the bottom.
+ *                If rad_top is 0, the cone terminates at a point.
   void iGeom_createCone( iGeom_Instance,
 			 double height,
@@ -2124,8 +2144,13 @@
 			 int* err );
-/**\brief
+/**\brief Create a torus
+ * Create a torus centered on the origin and encircling the z-axis.
+ * \param major_rad The distance from the origin to the center of the
+ *                  torus's circular cross-section.
+ * \param minor_rad The radius of the cross-section.
   void iGeom_createTorus( iGeom_Instance,
                           double major_rad,
@@ -2133,7 +2158,7 @@
                           int* err );
-/**\brief
+/**\brief Move an entity by the given vector
   void iGeom_moveEnt( iGeom_Instance,
@@ -2143,8 +2168,9 @@
                       double z,
                       int* err );
-/**\brief
+/**\brief Rotate an entity about a given axis
+ * \param angle The rotational angle, in degrees.
   void iGeom_rotateEnt( iGeom_Instance,
                         iBase_EntityHandle geom_entity,
More information about the cgma-dev mailing list
