[cgma-dev] CGMA source update failed: all tests aborted
Jason Kraftcheck kraftche at cae.wisc.edu
Wed Sep 23 11:44:41 CDT 2009
Steve Jackson wrote:
> I'm likely the one responsible for this error, because I was the one fiddling
> with directory metadata in CGM yesterday.  However, I can't reproduce any svn
> locking errors, and I don't have access to the nightly testing framework, so
> I can't investigate it further.
> Can somebody (Jason?) either look into this, or advise me on how I can look
> into it myself?  If not, I'll roll back yesterday's metadata update (r3159).
> ~S
This is fixed.  The fact that we a) cannot release the ACIS portion of CGMA
and b) still want it to be part of the CGM automake build, we do some odd
stuff (have an empty dummy directory that gets checked out by default, etc.)
   The nightly test builds include the real ACIS source, which requires a
password to check out.  This arrangement means that manual action (on my
part) is required for a) updating the source used for nightly tests for any
change to the ACIS source and b) sorting out svn issues for any change to
the dummy ACIS directory (not changes to files within, but changes that
add/remove files and/or attributes.)
- jason
More information about the cgma-dev mailing list
