[cgma-dev] Cones in iGeom
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Aug 24 19:07:09 CDT 2009
I think it should stay a separate function, even though it's quite similar.
After you apply for an ANL acct, this can serve as verification that you can commit stuff.
- tim
Steve Jackson wrote:
> I want to be able to define cones through the iGeom interface.  (Tim and
> I have discussed this already, and agreed that such an extension to
> iGeom would be straightforward.)  Attached to this email is a patch that
> implements an iGeom_createCone function, with an interface derived from
> createCylinder.
> Indeed, the new function is almost identical to createCylinder.  If we
> want to avoid adding more functions to iGeom, it would be possible to
> simply extend the createCylinder function to accept one more argument,
> thus giving it the capacity to define cones as well as cylinders.  But
> perhaps it is better to leave the existing cylinder interface as it is,
> and add a new cone function like the one I've attached.
> If the attached patch meets the approval of the lead developers, I'd ask
> one of them to apply it to the repository.  Thanks.
> (By the way, it seems like the svn repository may have gone down this
> afternoon; I'm currently unable to contact it.)
> ~S
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
