[cgma-dev] CGMA check for *cubit* failed.
    Steve Jackson
    sjackson at cae.wisc.edu
    Thu Aug 20 16:26:54 CDT 2009
Developers please note: the build failure that originated in r3108 and
caused last night's tests to fail can be fixed by adding the line
#include "parallel/FileOptions.hpp"
to itaps/iGeom_CGMA.cc.
~S
Nightly Test wrote:
> Making check in compat
> make[1]: Entering directory `/home/jason/cgm/test/cubit/compat'
> make[1]: Nothing to be done for `check'.
> make[1]: Leaving directory `/home/jason/cgm/test/cubit/compat'
> Making check in util
> make[1]: Entering directory `/home/jason/cgm/test/cubit/util'
> make[1]: Leaving directory `/home/jason/cgm/test/cubit/util'
> Making check in geom
> make[1]: Entering directory `/home/jason/cgm/test/cubit/geom'
> Making check in .
> make[2]: Entering directory `/home/jason/cgm/test/cubit/geom'
> make[2]: Nothing to be done for `check-am'.
> make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom'
> Making check in Cholla
> make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/Cholla'
> make[2]: Nothing to be done for `check'.
> make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/Cholla'
> Making check in facetbool
> make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/facetbool'
> make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/facetbool'
> make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/facet'
> make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/facet'
> Making check in virtual
> make[2]: Entering directory `/home/jason/cgm/test/cubit/geom/virtual'
> make[2]: Leaving directory `/home/jason/cgm/test/cubit/geom/virtual'
> make[1]: Leaving directory `/home/jason/cgm/test/cubit/geom'
> Making check in init
> make[1]: Entering directory `/home/jason/cgm/test/cubit/init'
> make[1]: Leaving directory `/home/jason/cgm/test/cubit/init'
> Making check in .
> make[1]: Entering directory `/home/jason/cgm/test/cubit'
> make[1]: Leaving directory `/home/jason/cgm/test/cubit'
> Making check in itaps
> make[1]: Entering directory `/home/jason/cgm/test/cubit/itaps'
> make  check-recursive
> make[2]: Entering directory `/home/jason/cgm/test/cubit/itaps'
> Making check in .
> make[3]: Entering directory `/home/jason/cgm/test/cubit/itaps'
> /bin/sh ../libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I.     -Wall -pipe -pedantic -g -Wno-long-long -MT iGeom_CGMA.lo -MD -MP -MF .deps/iGeom_CGMA.Tpo -c -o iGeom_CGMA.lo ../../trunk/itaps/iGeom_CGMA.cc
>  c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I. -Wall -pipe -pedantic -g -Wno-long-long -MT iGeom_CGMA.lo -MD -MP -MF .deps/iGeom_CGMA.Tpo -c ../../trunk/itaps/iGeom_CGMA.cc -o iGeom_CGMA.o
> ../../trunk/itaps/iGeom_CGMA.cc: In function ‘void igeom_load_(iGeom_Instance_Private*, const char*, const char*, int*, int, int)’:
> ../../trunk/itaps/iGeom_CGMA.cc:319: error: ‘FileOptions’ was not declared in this scope
> ../../trunk/itaps/iGeom_CGMA.cc:319: error: expected `;' before ‘opts’
> ../../trunk/itaps/iGeom_CGMA.cc:321: error: ‘FOErrorCode’ was not declared in this scope
> ../../trunk/itaps/iGeom_CGMA.cc:321: error: expected `;' before ‘rval’
> ../../trunk/itaps/iGeom_CGMA.cc:322: error: ‘FO_SUCCESS’ was not declared in this scope
> ../../trunk/itaps/iGeom_CGMA.cc:322: error: ‘rval’ was not declared in this scope
> make[3]: *** [iGeom_CGMA.lo] Error 1
> make[3]: Leaving directory `/home/jason/cgm/test/cubit/itaps'
> make[2]: *** [check-recursive] Error 1
> make[2]: Leaving directory `/home/jason/cgm/test/cubit/itaps'
> make[1]: *** [check] Error 2
> make[1]: Leaving directory `/home/jason/cgm/test/cubit/itaps'
> make: *** [check-recursive] Error 1
More information about the cgma-dev
