[cgma-dev] r2818 - cgm/trunk/test
jiangtao_ma at yahoo.com
Tue Apr 14 16:13:40 CDT 2009
Author: janehu
Date: 2009-04-14 16:13:40 -0500 (Tue, 14 Apr 2009)
New Revision: 2818
Modified:
cgm/trunk/test/modify.cpp
Log:
Added assertions for auto-testing.
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2009-04-14 21:13:02 UTC (rev 2817)
+++ cgm/trunk/test/modify.cpp 2009-04-14 21:13:40 UTC (rev 2818)
@@ -79,7 +79,7 @@
PRINT_INFO("Operation Failed");
int ret_val = ( CubitMessage::instance()->error_count() );
- if ( ret_val != 7 )
+ if ( ret_val != 9 )
PRINT_ERROR("Errors found during Mergechk session.\n");
@@ -415,33 +415,32 @@
Body* from_body2 = gmti->cylinder(8, 4, 2, 0);
Body* tool_body = gmti->cylinder(10, 1, 1, 1);
d = from_body->measure(); //d = 219.91
- assert(d - 219.91 < 0.01);
+ assert(d - 219.91 < 0.01 && d > 219.91);
bodysm = from_body->get_body_sm_ptr();
CubitVector center1;
CAST_TO(bodysm, OCCBody)->mass_properties(center1, d);
d = from_body2->measure();//d = 67.02
- assert(d - 67.02 < 0.01);
+ assert(d - 67.02 < 0.01&& d > 67.02);
d = tool_body->measure(); //d = 31.41
- assert(d - 31.41 < 0.01);
+ assert(d - 31.41 < 0.01 && d > 31.41);
// test for sphere making
Body* test_body = gmti->sphere(5);
d = test_body->measure(); //d = 523.598
- assert(d - 523.598 < 0.01);
+ assert(d - 523.598 < 0.01 && d > 523.598);
//test for prism making
test_body = gmti->prism(10, 4, 4,2);
d = test_body->measure(); //d = 320
- assert(-d + 320 < 0.1);
+ assert(-d + 320 < 0.1 && d < 320);
//test for pyramid making
test_body = gmti->pyramid(10, 4, 5, 2, 3);
d = test_body->measure(); //d = 130.6666
- assert(d - 130.666 < 0.001);
+ assert(d - 130.666 < 0.001&& d > 130.666);
//test for torus making
test_body = gmti->torus(10,5);
d = test_body->measure(); //d = 4934.8
- assert(d - 4934.8 < 0.1);
+ assert(d - 4934.8 < 0.1&& d > 4934.8);
//test for planar_sheet making
CubitVector p1(0, 0, 0);
CubitVector p2(0, 0, 1);
@@ -449,7 +448,7 @@
CubitVector p4(0, 1, 0);
test_body = gmti->planar_sheet(p1, p2, p3, p4);
- assert(1-d < 0.001);
+ assert(1-d < 0.001 && d < 1);
bodies.clean_out();
gti->bodies(bodies);
//delete all entities
@@ -488,7 +487,7 @@
v = new_bodies.get()->center_point(); //v = (7.5, 5, .05)
int n = new_bodies.get()->num_ref_faces();
assert( n == 6);
- assert (50 -d < 0.0001);
+ assert (50 -d < 0.0001 && d < 50);
CubitVector test_v(7.5, 5, .5);
assert (v == test_v);
//new bodies has 2 bodies, one has a volume = 10 and the other has a
@@ -522,7 +521,7 @@
new_bodies.clean_out();
CubitStatus stat = gmti->imprint(from_bodies, ref_edges, new_bodies, CUBIT_FALSE, CUBIT_TRUE );
//Updated volume(s): 30
- //assert(new_bodies.get()->num_ref_faces() == 6);
+ assert(new_bodies.get()->num_ref_faces() == 8);
//test edge imprint on surface
CubitVector vv(5,1,4.0);
@@ -543,6 +542,7 @@
stat = gmti->imprint(unimprint_faces, ref_edges, new_bodies, CUBIT_FALSE);
//Updated volume(s): 31
+ assert(new_bodies.get()->num_ref_faces() == 6);
face_list.clean_out();
@@ -653,7 +653,7 @@
surfaces.append(ref_faces.step_and_get()->get_surface_ptr());
ome->flip_normals(surfaces);
normal = ref_faces.get()->normal_at(v1); //(-1,0,0)
- assert(normal == -test_normal);
+ assert(normal == -test_normal0);
normal = ref_faces.step_and_get()->normal_at(v2); //(0,0,1)
assert(normal == test_normal2);
gti->delete_Body(test_body);
@@ -671,7 +671,9 @@
from_bodies.append(copy_tool_body);
from_bodies.append(from_body2);
stat = gmti->imprint(from_bodies, new_bodies, CUBIT_FALSE);
- //Updated volume(s): 35 no cuts performed
+ //Updated volume(s): 35
+ assert(new_bodies.size() == 1 && from_bodies.size() == 2);
+ assert(new_bodies.get()->num_ref_faces() == 7);
//test body imprinted by curves.
ref_edges.clean_out();
@@ -680,7 +682,8 @@
from_bodies.append(copy_tool_body2);
- //Updated volume(s): 37, 1 cut performed
+ //Updated volume(s): 37, 0 cut performed
//test body cutting a shell, one surface got cut as the result.
CubitVector v_move6(1,-1,0);
@@ -696,7 +699,7 @@
assert( n == 1);
- assert(1-d<0.00001);
+ assert(1-d<0.00001 && d < 1);
CubitVector test_v1(0.5,0.5,1);
assert(v == test_v1);
@@ -724,7 +727,10 @@
//Updated volume(s): 39, 40
//one body gets 4 cuts, the other 3.
//one body gets 10 faces, the other 9.
+ assert(new_bodies.size() == 2);
+ assert(new_bodies.get()->num_ref_faces() == 10);
+ assert(new_bodies.step_and_get()->num_ref_faces() == 9);
//test imprint projected edges
bodies.clean_out();
@@ -749,8 +755,10 @@
CUBIT_FALSE);
//Created volume(s): 42
if(new_bodies.size())
n = new_bodies.get()->num_ref_faces();//n = 8, new_bodies.size() == 1
+ assert(n == 8 && new_bodies.size() == 1);
//delete all bodies.
bodies.clean_out();
@@ -774,7 +782,8 @@
//Updated volume(s): 44
//Destroyed volume(s): 43
d = new_bodies.get()->measure(); //d = 1
+ assert(1-d < 0.00001 && d <= 1);
//2. common body is part of from body, update the correponding face
tool_body = gmti->brick(4, 4, 4);
gti->translate(tool_body,v_move5);
@@ -783,6 +792,7 @@
stat = gmti->intersect(tool_body, from_bodies, new_bodies, CUBIT_FALSE);
d = new_bodies.get()->measure(); //d = 0.5
+ assert(0.5-d < 0.0001 && d < 0.5);
//Destroyed volume(s): 45
@@ -798,10 +808,12 @@
//nothing changed
stat = gmti->intersect(tool_body, from_bodies, new_bodies, CUBIT_TRUE);
//"The 1 body did not have common part with the tool_body."
+ assert(stat == CUBIT_FAILURE);
//from_body get deleted
//Destroyed volume(s): 44, 46
bodies.clean_out();
@@ -826,6 +838,7 @@
//new_bodies = intersect bodies;bodies = outside bodies; body is dummy
stat = gmti->chop(from_bodies, new_bodies, bodies, body, CUBIT_FALSE);
+ assert(0.5-d<0.00001 && d < 0.5);
//Created volume(s): 49
//Destroyed volume(s): 47
//Updated volume(s): 48
@@ -854,7 +867,8 @@
//Destroyed volume(s): 51
//Updated volume(s): 50
d = bodies.get()->measure();//d = 63
+ assert(d-63<0.0001 && d>63);
bodies.clean_out();
@@ -877,8 +891,9 @@
//Updated volume(s): 54
//Destroyed volume(s): 53
d = new_bodies.get()->measure(); //d = 2
- n = new_bodies.get()->num_ref_faces(); //d = 10
+ n = new_bodies.get()->num_ref_faces(); //n = 10
+ assert(d-2<0.0001 && d>2 && n == 10);
bodies.clean_out();
gti->bodies(bodies); //bodies.size() = 1
free_entities.clean_out();
@@ -903,7 +918,8 @@
//Destroyed volume(s): 55
d = new_bodies.get()->measure(); //d = 64.5
- //d = 13. because fusion keeps the imprintings.
+ assert(d-64.5<0.00001 && d > 64.5 && n == 13);
+ //n = 13. because fusion keeps the imprintings.
bodies.clean_out();
@@ -932,6 +948,8 @@
//Destroyed volume(s): 58
d = new_bodies.get()->measure(); //d = 518.3627
n = new_bodies.get()->num_ref_faces(); //n = 5
+ assert(d-518.3627<0.0001 && d > 518.3627 && n==5);
//find the top most surface as the opening of the thick body.
ref_faces.clean_out();
new_bodies.get()->ref_faces(ref_faces);
@@ -951,6 +969,7 @@
//Updated volume(s): 57
n = new_bodies.get()->num_ref_faces(); //n = 9
d = new_bodies.get()->measure(); //d = 72.4074
+ assert(n == 9 && d-72.4074<0.0001 && d>72.4074);
bodies.clean_out();
gti->bodies(bodies); //bodies.size() = 2
@@ -971,7 +990,8 @@
gmti->sweep_translational(refentities, v_move8, 0, 1, CUBIT_FALSE, CUBIT_FALSE);
body = CAST_TO(refentities.get(), Body);
d = body->measure();
- //d = 39.2699
+ assert(d - 39.2699 < 0.0001 && d >39.2699);
refentities.clean_out();
refentities.append(draft_face);
CubitVector v_move8ii(0,0,10);
@@ -979,6 +999,8 @@
//d = 66.3676 theoretical calculation is 66.7833, error 0.62%
+ assert(d - 66.3676 < 0.0001 && d > 66.3676);
DLIList<RefEdge*> edges;
body->ref_edges(edges);
@@ -987,12 +1009,15 @@
//d = area = 90.1292 theoretica calculation is 90.5754, error 0.49%
+ assert(d - 90.1292 < 0.0001 && d > 90.1292);
refentities.append(perp_face);
gmti->sweep_perpendicular(refentities, 10, 0.087, 1, CUBIT_FALSE, CUBIT_FALSE);
//Testing for sweep_rotational function
//1. Negative testing: surface rotates along an intersection axis, fails.
@@ -1003,8 +1028,9 @@
CubitVector sweep_axis(1,0,0);
CubitVector point(0, 2, 15);
double angle = 1.57;
- gmti->sweep_rotational(refentities, center, sweep_axis, angle, 0, 0, 1,
+ stat =gmti->sweep_rotational(refentities, center, sweep_axis, angle, 0, 0, 1,
CUBIT_FALSE, CUBIT_TRUE, CUBIT_FALSE);
//2. surface rotates along a non-intersection axis
refentities.append(rotate_face);
@@ -1012,13 +1038,14 @@
- //d = 9.8646
+ assert(d - 9.8646 < 0.0001 && d > 9.8646);
//3. closed curve rotates along an intersecting axis, fails
refentities.append(rotate_edges.get());
//4. closed curve rotates along a non-intersecting axis with make_solid
// option set to be true.
@@ -1027,7 +1054,7 @@
- //d = 9.8646
//5. closed curve rotates along a non-intersecting axis with make_solid
// option set to be false.
@@ -1037,7 +1064,7 @@
CUBIT_FALSE, CUBIT_FALSE, CUBIT_FALSE);
- //d = 19.7292
+ assert(d - 19.7292 < 0.0001 && d> 19.7292);
//6. open curve rotates along an intersecting axis with make_solid
// option set to be true. Failed
@@ -1051,8 +1078,9 @@
CubitVector apoint(0,-0.5,15);
refentities.append(edge1);
- gmti->sweep_rotational(refentities, apoint, sweep_axis, angle, 0, 0, 1,
+ stat=gmti->sweep_rotational(refentities, apoint, sweep_axis, angle, 0, 0, 1,
//7. open curve rotates along an intersecting axis at end points with
// make_solid option set to be true.
@@ -1062,7 +1090,7 @@
- //d = 1.046667
+ assert(1.046667-d < 0.0001 && d < 1.046667);
//8. open curve rotates along an intersecting axis at end points with
// make_solid option set to be false.
@@ -1072,14 +1100,15 @@
- //d = 3.14
+ assert( d - 3.14 > -0.0001 && d < 3.14);
//9. staight line rotate about itself fails.
RefEdge* edge2 = gmti->make_RefEdge(vt1, vt2, rotate_face);
refentities.append(edge2);
- gmti->sweep_rotational(refentities, center, rotate_axis, -angle, 0, 0, 1,
+ stat=gmti->sweep_rotational(refentities, center, rotate_axis, -angle, 0, 0, 1,
//10. open curve rotates along a non-intersect axis with make_solid option
// set to be true.
@@ -1089,7 +1118,7 @@
- //d = 5.0828
+ assert(d - 5.0828 < 0.0001 && d > 5.0828);
//11. open curve rotates along a non-intersect axis with make_solid option
// set to be false.
@@ -1099,7 +1128,7 @@
- //d = 8.07227
+ assert(d - 8.07227 < 0.001 && d > 8.07227);
//test sweep_along_curve function
//sweep along a straight curve with draft
@@ -1114,6 +1143,7 @@
//d = 134.7152, theoretical calculation is 135.66363, error 0.67%
+ assert(d -134.7152 < 0.0001 && d > 134.7152);
//sweep along two curves which make a G1 continous wire, no draft is performed
@@ -1136,6 +1166,7 @@
//d = 93.697, no effect of draft angle.
+ assert(d - 93.697 < 0.001 && d > 93.697);
bodies.clean_out();
More information about the cgma-dev
