[cgma-dev] r2817 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Tue Apr 14 16:13:03 CDT 2009
Author: janehu
Date: 2009-04-14 16:13:02 -0500 (Tue, 14 Apr 2009)
New Revision: 2817
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
fix for the modify testing.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-04-13 18:20:51 UTC (rev 2816)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-04-14 21:13:02 UTC (rev 2817)
@@ -2376,7 +2376,7 @@
 		  if (count_intersection == 1 )
 		    PRINT_WARNING("Cant make a scar on existing face without splitting it. \n");
-	      if (stat)
+	      if (stat || count_intersection == 2)
 		  BRepBuilderAPI_MakeWire myWire;
 		  edge_list->reset();
@@ -3511,10 +3511,9 @@
     check_operation(common_shape, from_shape, is_volume[i], has_changed,
                     &intersector, keep_old);
-    if(from_shape->IsNull())
+    if(from_shape->IsNull() )
       PRINT_INFO("The %d body did not have common part with the tool_body.\n", i+1);
-      new_bodies.append(from_body);
     else
       tbs += OCCQueryEngine::instance()->populate_topology_bridge(*from_shape);
@@ -3526,6 +3525,9 @@
       new_bodies.append(bodysm);
+  if(tbs.size() == 0)
+    stat = CUBIT_FAILURE;
   //ok, we're done with all cuts, delete unnecessaries.
   if(!keep_old)
     OCCQueryEngine::instance()->delete_solid_model_entities(tool_body_ptr);
@@ -3547,6 +3549,8 @@
       delete shape;
+  if(!stat)
+    return stat;
   return CUBIT_SUCCESS;
@@ -3589,7 +3593,7 @@
      //got cut. Update the entities
-     if(after_mass < TOL && !no_volume) //no common section
+     if(after_mass < TOL || no_volume) //no common section
        cut_shape.Nullify();
      has_changed = CUBIT_TRUE;
      TopExp_Explorer Ex;
@@ -4443,7 +4447,10 @@
     continue;
   OCCQueryEngine::instance()->delete_solid_model_entities(acurve);
-  return CUBIT_SUCCESS;
+  if(result_body_list.size()>0)
+    return CUBIT_SUCCESS;
+  else
+    return CUBIT_FAILURE;
More information about the cgma-dev mailing list
