[cgma-dev] r2804 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Mon Apr 6 16:58:02 CDT 2009
Author: janehu
Date: 2009-04-06 16:58:02 -0500 (Mon, 06 Apr 2009)
New Revision: 2804
Modified:
cgm/trunk/geom/OCC/OCCLoop.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCSurface.cpp
Log:
Fixed the mktwocyls file's crash.
Modified: cgm/trunk/geom/OCC/OCCLoop.cpp
--- cgm/trunk/geom/OCC/OCCLoop.cpp 2009-04-06 16:01:33 UTC (rev 2803)
+++ cgm/trunk/geom/OCC/OCCLoop.cpp 2009-04-06 21:58:02 UTC (rev 2804)
@@ -89,7 +89,8 @@
for (int i = myCoEdgeList.size(); i--; )
OCCCoEdge* coedge = myCoEdgeList.get_and_step();
- assert(coedge->loop() == this);
+ OCCLoop *loop = CAST_TO(coedge->loop(), OCCLoop);
+ assert(loop == this);
myCoEdgeList.clean_out();
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-04-06 16:01:33 UTC (rev 2803)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-04-06 21:58:02 UTC (rev 2804)
@@ -2286,24 +2286,37 @@
else
curve = OCCQueryEngine::instance()->populate_topology_bridge(from_edge);
OCCCurve* occ_curve = CAST_TO(curve, OCCCurve);
- CubitPointContainment pc = occ_curve->point_containment(p);
+ CubitPointContainment pc = CUBIT_PNT_OFF;
+ if(occ_curve->geometry_type() == STRAIGHT_CURVE_TYPE)
+ pc = occ_curve->point_containment(p);
- if(pc == CUBIT_PNT_ON) //overlap
- //check if they are the same edge, so don't need to be split
- //the overlapped edges are considered the same if they have the
- //same length
- if((d2 - d1) > TOL)
- added = CUBIT_TRUE;
- splitor.Add(edge, from_edge);
+ if(pc == CUBIT_PNT_ON) //overlap
+ //check if they are the same edge, so don't need to be split
+ //the overlapped edges are considered the same if they have the
+ //same length
+ if((d2 - d1) > TOL)
+ added = CUBIT_TRUE;
+ splitor.Add(edge, from_edge);
+ else
+ skipped = CUBIT_TRUE;
+ total_edges--;
+ break;
- else
- skipped = CUBIT_TRUE;
- total_edges--;
- break;
+ else if(list_of_edges.Extent() == 1 && (d2 - d1) <= TOL)
+ if(list_of_edges.Extent() == 1 && !skipped)
+ Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
+ curve_list.append(curve);
if(added)
@@ -2334,7 +2347,15 @@
DLIList<DLIList<TopoDS_Edge*>*> edge_lists;
if (total_edges >= 1)
- CubitStatus stat = sort_curves(curve_list, edge_lists);
+ CubitStatus stat = CUBIT_SUCCESS;
+ if(curve_list.size() > 0)
+ stat = sort_curves(curve_list, edge_lists);
+ else
+ TopoDS_Face* topo_face = new TopoDS_Face(from_face);
+ from_faces.append(topo_face);
+ continue;
DLIList<TopoDS_Edge*>* edge_list;
int size = edge_lists.size();
for (int iii = 0; iii < size; iii++)
@@ -2348,10 +2369,10 @@
count_intersection = check_intersection(edge_list, from_face);
- if (count_intersection < 2)
+ if (count_intersection == 1 )
PRINT_WARNING("Cant make a scar on existing face without splitting it. \n");
- if (stat || count_intersection == 2)
+ if (stat)
BRepBuilderAPI_MakeWire myWire;
edge_list->reset();
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2009-04-06 16:01:33 UTC (rev 2803)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2009-04-06 21:58:02 UTC (rev 2804)
@@ -305,9 +305,8 @@
if (curvature_2 != NULL)
*curvature_2 = CubitVector(MaxD.X(), MaxD.Y(), MaxD.Z());
- return CUBIT_SUCCESS;
- return CUBIT_FAILURE;
+ return CUBIT_SUCCESS;
More information about the cgma-dev
