[cgma-dev] r2799 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Fri Apr 3 15:02:36 CDT 2009
Author: janehu
Date: 2009-04-03 15:02:36 -0500 (Fri, 03 Apr 2009)
New Revision: 2799
Modified:
cgm/trunk/geom/OCC/OCCAttribSet.cpp
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCCoEdge.hpp
cgm/trunk/geom/OCC/OCCCurve.cpp
cgm/trunk/geom/OCC/OCCLoop.cpp
cgm/trunk/geom/OCC/OCCLump.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCPoint.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCShell.cpp
cgm/trunk/geom/OCC/OCCSurface.cpp
Log:
Fixed some of the memery problems reported by valgrind.
Modified: cgm/trunk/geom/OCC/OCCAttribSet.cpp
--- cgm/trunk/geom/OCC/OCCAttribSet.cpp 2009-04-03 19:35:55 UTC (rev 2798)
+++ cgm/trunk/geom/OCC/OCCAttribSet.cpp 2009-04-03 20:02:36 UTC (rev 2799)
@@ -122,8 +122,9 @@
strings->step(); //type string filters out
for(int i = 0; strings && i < size; i++)
+ char const* string1 = strings->get_and_step()->c_str();
TCollection_ExtendedString
- cstring((Standard_CString)strings->get_and_step()->c_str() );
+ cstring(string1, Standard_True );
attr_string->SetValue(i, cstring) ;
@@ -168,7 +169,9 @@
DLIList<int*>* ints = csa->int_data_list();
CubitString type = csa->character_type();
- TCollection_ExtendedString cstring( (Standard_CString)type.c_str() );
+ char const* string1 = type.c_str();
+ Standard_Boolean isMultiByte = Standard_True;
+ TCollection_ExtendedString cstring( string1, isMultiByte );
DLIList<double*>* doubles = csa->double_data_list();
DLIList<CubitString*>* strings = csa->string_data_list();
@@ -233,7 +236,8 @@
for(int i = 0; i < strings->size()-1; i++)
CubitString astring = *strings->get_and_step();
- TCollection_ExtendedString string( (Standard_CString)astring.c_str() );
+ char const* string1 = astring.c_str();
+ TCollection_ExtendedString string( string1 , Standard_True);
if(attr_strings->Value(i) != string)
is_same = CUBIT_FALSE;
@@ -355,7 +359,8 @@
temp_string[j-1] = ToCharacter(c);
temp_string[length2] = '\0';
- string = new CubitString(&temp_string[0]);
+ const char *s = &temp_string[0];
+ string = new CubitString(s);
strings.append(string);
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2009-04-03 19:35:55 UTC (rev 2798)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2009-04-03 20:02:36 UTC (rev 2799)
@@ -90,7 +90,7 @@
TopoDS_CompSolid * the_comp = new TopoDS_CompSolid(theshape);
if(myTopoDSShape)
- delete myTopoDSShape;
+ delete (TopoDS_CompSolid*)myTopoDSShape;
myTopoDSShape = the_comp;
@@ -121,7 +121,7 @@
OCCBody::~OCCBody()
if (myTopoDSShape)
GeometryQueryEngine* OCCBody::get_geometry_query_engine() const
Modified: cgm/trunk/geom/OCC/OCCCoEdge.hpp
--- cgm/trunk/geom/OCC/OCCCoEdge.hpp 2009-04-03 19:35:55 UTC (rev 2798)
+++ cgm/trunk/geom/OCC/OCCCoEdge.hpp 2009-04-03 20:02:36 UTC (rev 2799)
@@ -60,7 +60,8 @@
inline void set_curve(Curve* curve) {myCurve = curve;}
- inline LoopSM* loop() const { return myLoop; }
+ inline LoopSM* loop() const { if(myLoop)return myLoop;
+ else return NULL; }
inline void set_loop(LoopSM * loop) {myLoop = loop;}
@@ -121,8 +122,8 @@
private:
int myMark;
- Curve *myCurve;
- LoopSM *myLoop;
+ Curve *myCurve ;
+ LoopSM *myLoop ;
CubitSense edgeSense;
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp 2009-04-03 19:35:55 UTC (rev 2798)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp 2009-04-03 20:02:36 UTC (rev 2799)
@@ -111,7 +111,7 @@
OCCCurve::~OCCCurve()
if (myTopoDSEdge)
- delete myTopoDSEdge;
+ delete (TopoDS_Edge *)myTopoDSEdge;
void OCCCurve::set_TopoDS_Edge(TopoDS_Edge edge)
@@ -121,7 +121,7 @@
TopoDS_Edge* the_edge = new TopoDS_Edge(edge);
if(myTopoDSEdge)
myTopoDSEdge = the_edge;
@@ -997,7 +997,8 @@
return (Curve*) NULL;
- BRepAlgo_NormalProjection aProjection(*face);
+ BRepAlgo_NormalProjection aProjection;
+ aProjection.Init(*face);
aProjection.Add(*edge);
aProjection.Build();
if (!aProjection.IsDone())
Modified: cgm/trunk/geom/OCC/OCCLoop.cpp
--- cgm/trunk/geom/OCC/OCCLoop.cpp 2009-04-03 19:35:55 UTC (rev 2798)
+++ cgm/trunk/geom/OCC/OCCLoop.cpp 2009-04-03 20:02:36 UTC (rev 2799)
@@ -62,7 +62,7 @@
disconnect_all_curves();
if (myTopoDSWire)
- delete myTopoDSWire;
+ delete (TopoDS_Wire*)myTopoDSWire;
void OCCLoop::set_TopoDS_Wire(TopoDS_Wire loop)
@@ -71,7 +71,7 @@
return;
TopoDS_Wire* the_wire = new TopoDS_Wire(loop);
if(myTopoDSWire)
myTopoDSWire = the_wire;
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp 2009-04-03 19:35:55 UTC (rev 2798)
+++ cgm/trunk/geom/OCC/OCCLump.cpp 2009-04-03 20:02:36 UTC (rev 2799)
@@ -77,7 +77,7 @@
OCCLump::~OCCLump()
if (myTopoDSSolid)
- delete myTopoDSSolid;
+ delete (TopoDS_Solid*)myTopoDSSolid;
void OCCLump::set_TopoDS_Solid(TopoDS_Solid solid)
@@ -87,7 +87,7 @@
TopoDS_Solid* the_solid = new TopoDS_Solid(solid);
if(myTopoDSSolid)
- delete myTopoDSSolid ;
+ delete (TopoDS_Solid*)myTopoDSSolid ;
myTopoDSSolid = the_solid;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-04-03 19:35:55 UTC (rev 2798)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-04-03 20:02:36 UTC (rev 2799)
@@ -3545,7 +3545,7 @@
double orig_mass = myProps.Mass();
TopTools_IndexedMapOfShape M;
TopExp::MapShapes(cut_shape, TopAbs_SOLID, M);
- double after_mass;
+ double after_mass = 0.0;
CubitBoolean no_volume = CUBIT_FALSE;
if(M.Extent() > 0)
Modified: cgm/trunk/geom/OCC/OCCPoint.cpp
--- cgm/trunk/geom/OCC/OCCPoint.cpp 2009-04-03 19:35:55 UTC (rev 2798)
+++ cgm/trunk/geom/OCC/OCCPoint.cpp 2009-04-03 20:02:36 UTC (rev 2799)
@@ -81,7 +81,7 @@
OCCPoint::~OCCPoint()
if (myTopoDSVertex)
- delete myTopoDSVertex;
+ delete (TopoDS_Vertex*)myTopoDSVertex;
void OCCPoint::set_TopoDS_Vertex(TopoDS_Vertex vertex)
@@ -90,7 +90,7 @@
return;
TopoDS_Vertex* the_vertex = new TopoDS_Vertex(vertex);
if(myTopoDSVertex)
myTopoDSVertex = the_vertex;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2009-04-03 19:35:55 UTC (rev 2798)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2009-04-03 20:02:36 UTC (rev 2799)
@@ -1209,7 +1209,8 @@
else if(strcmp(file_type, "IGES") == 0)
IGESControl_Reader reader;
- IFSelect_ReturnStatus stat = reader.ReadFile( (char*) file_name);
+ const Standard_CString string1 = file_name;
+ IFSelect_ReturnStatus stat = reader.ReadFile( string1);
if (stat != IFSelect_RetDone)
PRINT_INFO("%s: Cannot open file", file_name );
@@ -2273,11 +2274,11 @@
CubitStatus stat = unhook_Curve_from_OCC(curve);
- if (stat)
- CurveList->remove(fcurve);
- delete curve;
+ if (!stat)
+ return CUBIT_FAILURE;
+ CurveList->remove(fcurve);
+ delete fcurve;
return stat;
@@ -2921,7 +2922,7 @@
OCCCoEdge* coedge = children.pop();
CAST_TO(coedge->curve(), OCCCurve)->remove_loop(CAST_TO(loop, OCCLoop));
- delete coedge;
+ delete (OCCCoEdge*)coedge;
unhook_LoopSM_from_OCC(loop);
delete loop;
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp 2009-04-03 19:35:55 UTC (rev 2798)
+++ cgm/trunk/geom/OCC/OCCShell.cpp 2009-04-03 20:02:36 UTC (rev 2799)
@@ -72,7 +72,7 @@
OCCShell::~OCCShell()
if(myTopoDSShell)
- delete myTopoDSShell;
+ delete (TopoDS_Shell*)myTopoDSShell;
OCCCoFace* OCCShell::remove_coface(OCCCoFace *coface)
@@ -87,7 +87,7 @@
TopoDS_Shell* the_shell = new TopoDS_Shell(shell);
if (myTopoDSShell)
myTopoDSShell = the_shell;
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2009-04-03 19:35:55 UTC (rev 2798)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2009-04-03 20:02:36 UTC (rev 2799)
@@ -96,7 +96,7 @@
OCCSurface::~OCCSurface()
if(myTopoDSFace)
- delete myTopoDSFace;
+ delete (TopoDS_Face*)myTopoDSFace;
void OCCSurface::set_TopoDS_Face(TopoDS_Face& face)
@@ -106,7 +106,7 @@
TopoDS_Face* face_ptr = new TopoDS_Face(face);
if(myTopoDSFace)
myTopoDSFace = face_ptr ;
@@ -1001,7 +1001,7 @@
if (!old_surface.IsSame(new_surface))
- TopAbs_ShapeEnum shapetype;
+ TopAbs_ShapeEnum shapetype = TopAbs_SHAPE;
if(!new_surface.IsNull())
shapetype = new_surface.TShape()->ShapeType();
if(shapetype == TopAbs_FACE || new_surface.IsNull())
More information about the cgma-dev
