[cgma-dev] Seg fault when loading OCC geometry with associations
Jed Brown
jed at 59A2.org
Mon Mar 30 10:31:56 CDT 2009
On Mon 2009-03-30 10:17, Jason Kraftcheck wrote:
> This is fixed, but probably not in quite the way it was requested. The
> behavior of MOAB's direct API (described above) is not the same as what
> is required and implemented for the iMesh API. As this bug was with the
> iGeom API implementation for CGM, I have made it conform to the ITAPS
> spec.
> The ITAPS interfaces specify no fixed or default separator character for
> options strings. They require that the first character of every passed
> option string be an caller-specified separator character (even when the
> string contains only one option and therefore no other separator
> characters.)
Great. If I choose the separation character to be ';' and always place
it first, then the same options format should work with both. It would
help to document the available options somewhere (both for MOAB and
CGM), a list of options and a 1-line description would have saved me
some time.
Jane, I'm putting together a tidy test case to demonstrate the geometry
problem.
Jed
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20090330/75c3aaa8/attachment.pgp>
More information about the cgma-dev
