[cgma-dev] Seg fault when loading OCC geometry with associations
Jason Kraftcheck
kraftche at cae.wisc.edu
Mon Mar 30 10:17:48 CDT 2009
Tim Tautges wrote:
> Jed Brown wrote:
>> Why does CGM use different options delimiters (":,\n\t") than MOAB
>> (";")? I have discovered "ENGINE=OCC" for iGeom_newGeom and "TYPE=OCC"
>> for iGeom_load by reading the source, but are there other options to be
>> aware of?
> Likely that MOAB got updated and CGM didn't; Jason, can you fix this one?
This is fixed, but probably not in quite the way it was requested. The
behavior of MOAB's direct API (described above) is not the same as what
is required and implemented for the iMesh API. As this bug was with the
iGeom API implementation for CGM, I have made it conform to the ITAPS
spec.
The ITAPS interfaces specify no fixed or default separator character for
options strings. They require that the first character of every passed
option string be an caller-specified separator character (even when the
string contains only one option and therefore no other separator
characters.)
- jason
More information about the cgma-dev
