[cgma-dev] r2744 - cgm/trunk/geom/ACIS_SRC
    jiangtao_ma at yahoo.com
    Tue Mar 24 14:23:54 CDT 2009
Author: janehu
Date: 2009-03-24 14:23:54 -0500 (Tue, 24 Mar 2009)
New Revision: 2744
Modified:
   cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
   cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp
Log:
Don't need the tweak fillet or chamfer function const.
Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp
--- cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp	2009-03-24 19:21:42 UTC (rev 2743)
+++ cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.cpp	2009-03-24 19:23:54 UTC (rev 2744)
@@ -1382,7 +1382,7 @@
                                              DLIList<BodySM*> &new_bodysm_list,
                                              double right_offset,
                                              CubitBoolean keep_old_body,
-                                             CubitBoolean preview ) const
+                                             CubitBoolean preview )
   return AcisTweakTool::instance()->tweak_chamfer( curve_list, left_offset,
 						   new_bodysm_list, right_offset, keep_old_body, preview );
@@ -1409,7 +1409,7 @@
                                  double offset3,
                                  Curve *edge3,
   return AcisTweakTool::instance()->tweak_chamfer( ref_vertex_list, offset1,
 						   new_bodysm_list, edge1, offset2, edge2, offset3, edge3, keep_old_body,
@@ -1428,7 +1428,7 @@
                                             double radius,
   return AcisTweakTool::instance()->tweak_fillet( curve_list, radius,
 						  new_bodysm_list, keep_old_body, preview );
@@ -1448,7 +1448,7 @@
                                             double end_radius,
                                             BodySM *&new_bodysm_ptr,
   return AcisTweakTool::instance()->tweak_fillet( curve_ptr, start_radius,
 						  end_radius, new_bodysm_ptr, keep_old_body, preview );
@@ -1467,7 +1467,7 @@
                                 double radius,
   return AcisTweakTool::instance()->tweak_fillet( ref_vertex_list, radius,
Modified: cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp
--- cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp	2009-03-24 19:21:42 UTC (rev 2743)
+++ cgm/trunk/geom/ACIS_SRC/AcisModifyEngine.hpp	2009-03-24 19:23:54 UTC (rev 2744)
@@ -998,7 +998,7 @@
                                      double right_offset = -1.0,
                                      CubitBoolean keep_old_body = CUBIT_FALSE,
-                                     CubitBoolean preview = CUBIT_FALSE ) const;
+                                     CubitBoolean preview = CUBIT_FALSE ) ;
   /**<  Chamfer curves on solid bodies.  The left and right offsets are with
     *   respect to the curve direction.  If the given right offset is negative,
     *   the left offset is used.  Users can preview to clarify the meaning of
@@ -1014,7 +1014,7 @@
                                      double offset3 = -1.0,
                                      Curve *edge3 = NULL,
   /**<  Chamfer vertices on solid or sheet bodies.  On a solid body there can
     *   be up to 3 offsets; on a sheet body up to 2 offsets.  The offsets are
     *   in the direction of the supplied edges.  If multiple vertices are
@@ -1025,7 +1025,7 @@
                                     double radius,
   /**<  Create a round fillet (or blend) at the given curves on solid bodies.
@@ -1034,7 +1034,7 @@
                                     double end_radius,
                                     BodySM *&new_body_ptr,
   /**<  Create a round fillet (or blend) at the given curve on a solid body.
     *   The fillet has a variable radius from the start to the end of the curve.
@@ -1043,7 +1043,7 @@
                                     double radius,
   /**<  Create a round fillet (or blend) at the given vertices on sheet bodies.
More information about the cgma-dev
