[cgma-dev] r2743 - in cgm/trunk/geom: . OCC facet
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Tue Mar 24 14:21:44 CDT 2009
Author: janehu
Date: 2009-03-24 14:21:42 -0500 (Tue, 24 Mar 2009)
New Revision: 2743
Modified:
   cgm/trunk/geom/GeometryModifyEngine.hpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.hpp
   cgm/trunk/geom/facet/FacetModifyEngine.cpp
   cgm/trunk/geom/facet/FacetModifyEngine.hpp
Log:
Added chamfer for vertices function, since there's no member's in GeometryModifyEngine, there's no need to make the functions const. It doesn't have an api for chamfer vertices in opencasecade library, we need to call non-const functions in OCCModifyEngine to accomplish it.
Modified: cgm/trunk/geom/GeometryModifyEngine.hpp
--- cgm/trunk/geom/GeometryModifyEngine.hpp	2009-03-23 14:47:00 UTC (rev 2742)
+++ cgm/trunk/geom/GeometryModifyEngine.hpp	2009-03-24 19:21:42 UTC (rev 2743)
@@ -746,7 +746,7 @@
                                      DLIList<BodySM*> &new_bodysm_list,
                                      double right_offset = -1.0,
                                      CubitBoolean keep_old_body = CUBIT_FALSE,
-                                     CubitBoolean preview = CUBIT_FALSE ) const = 0;
+                                     CubitBoolean preview = CUBIT_FALSE )  = 0;
   /**<  Chamfer curves on solid bodies.  The left and right offsets are with
     *   respect to the curve direction.  If the given right offset is negative,
     *   the left offset is used.  Users can preview to clarify the meaning of
@@ -762,7 +762,7 @@
                                      double offset3 = -1.0,
                                      Curve *edge3 = NULL,
   /**<  Chamfer vertices on solid or sheet bodies.  On a solid body there can
     *   be up to 3 offsets; on a sheet body up to 2 offsets.  The offsets are
     *   in the direction of the supplied edges (for a solid) or the loop
@@ -774,7 +774,7 @@
                                     double radius,
   /**<  Create a round fillet (or blend) at the given curves on solid bodies.
@@ -783,7 +783,7 @@
                                     double end_radius,
                                     BodySM *&new_bodysm_ptr,
   /**<  Create a round fillet (or blend) at the given curve on a solid body.
     *   The fillet has a variable radius from the start to the end of the curve.
@@ -792,7 +792,7 @@
                                     double radius,
   /**<  Create a round fillet (or blend) at the given vertices on sheet bodies.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-03-23 14:47:00 UTC (rev 2742)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-03-24 19:21:42 UTC (rev 2743)
@@ -5961,10 +5961,13 @@
                                             DLIList<BodySM*> & new_bodysm_list,
                                             double right_offset,
                                             CubitBoolean keep_old_body,
-                                            CubitBoolean preview ) const
+                                            CubitBoolean preview )
   CubitStatus stat;
   int count = 0;
+  if(right_offset <= 0.0)
+    right_offset = left_offset;
   for(int i = 0; i < curve_list.size(); i++)
     BodySM * new_bodysm_ptr = NULL;
@@ -6028,12 +6031,314 @@
                                 double offset3,
                                 Curve * edge3,
-  PRINT_ERROR("Option not supported for mesh based geometry.\n");
-  return CUBIT_FAILURE;
+  // Sort out vertices between sheet and solid bodies
+  DLIList<Point*> solid_points, sheet_points;
+  DLIList<OCCSurface*> s_list;
+  DLIList<OCCBody*> bodies;
+  if( sort_points_by_body_type( point_list, solid_points, sheet_points,
+                                s_list, bodies ) == CUBIT_FAILURE )
+    return CUBIT_FAILURE;
+  if(solid_points.size() > 0 && solid_points.size() != bodies.size())
+    PRINT_ERROR( "cannot find bodies corresponding to the points.\n" );
+  if(sheet_points.size() > 0 && sheet_points.size() != s_list.size())
+    PRINT_ERROR( "cannot find surfaces corresponding to the points.\n" );
+  // Do simple forms
+  if( edge1 == NULL || offset2 <= 0.0 )
+    if( tweak_chamfer_solid( solid_points, bodies, offset1, new_bodysm_list,
+      keep_old_body, preview )== CUBIT_FAILURE )
+    return tweak_fillet_chamfer_sheet( sheet_points, s_list, offset1,
+           CUBIT_FALSE, new_bodysm_list, keep_old_body, preview );
+  if( solid_points.size() > 1 || sheet_points.size() > 1 )
+    PRINT_ERROR( "cannot chamfer multiple vertices with a variable radius.\n" );
+  if( solid_points.size() )
+    Point *point_ptr = solid_points.get();
+    if( tweak_chamfer_solid( point_ptr, bodies.get(), offset1, edge1,
+        offset2, edge2, offset3, edge3,
+        new_bodysm_list, keep_old_body, preview ) == CUBIT_FAILURE )
+    return CUBIT_SUCCESS;
+  if( sheet_points.size() )
+    Point *point_ptr = sheet_points.get();
+    if( tweak_chamfer_sheet( point_ptr, s_list.get(), offset1, edge1, offset2,
+        edge2, new_bodysm_list, keep_old_body, preview ) == CUBIT_FAILURE )
+CubitStatus
+OCCModifyEngine::tweak_chamfer_solid( DLIList<Point*> &point_list,
+                                    DLIList<OCCBody*> &bodies,
+                                    double radius,
+                                    DLIList<BodySM*> &new_bodysm_list,
+                                    CubitBoolean keep_old_body,
+  for(int i = 0; i < point_list.size(); i++)
+    DLIList<TopologyBridge*> parents;
+    OCCPoint* point = CAST_TO(point_list.get_and_step(), OCCPoint);
+    OCCBody* body = bodies.get_and_step();
+    if(point != NULL)
+      point->get_parents_virt(parents); //OCCCurves
+    assert(parents.size() == 3);
+    DLIList<Curve*> curves;
+    for(int j = 0; j < 3; j++)
+      OCCCurve* occ_curve = CAST_TO(parents.get_and_step(), OCCCurve);
+      curves.append(occ_curve);
+    CubitStatus stat;
+    stat = tweak_chamfer_solid(point, body,radius, curves.pop(), radius,
+                        curves.pop(), radius, curves.pop(), new_bodysm_list,
+                        keep_old_body, CUBIT_FALSE );
+    if(!stat)
+  if(preview)
+    GfxPreview::clear();
+    for(int i = 0; i < new_bodysm_list.size(); i++)
+      BodySM* new_bodysm = new_bodysm_list.get_and_step();
+      TopoDS_Shape* modified_shape =
+          CAST_TO(new_bodysm, OCCBody)->get_TopoDS_Shape();
+      TopExp_Explorer Ex;
+      Ex.Init(*modified_shape, TopAbs_FACE);
+      for( ; Ex.More(); Ex.Next() )
+        TopoDS_Face face = TopoDS::Face(Ex.Current());
+        // Draw this face
+        OCCDrawTool::instance()->draw_FACE( &face, CUBIT_BLUE, CUBIT_TRUE );
+    GfxPreview::flush();
+    OCCQueryEngine::instance()->delete_solid_model_entities(new_bodysm_list);
+    new_bodysm_list.clean_out();
+CubitStatus
+OCCModifyEngine::tweak_chamfer_solid( Point* point_ptr,
+                                    OCCBody* body,
+                                    double r1,
+                                    Curve *c1,
+                                    double r2,
+                                    Curve *c2,
+                                    double r3,
+                                    Curve *c3,
+                                    DLIList<BodySM *> &new_bodysm_list,
+  if(r1 <= 0.0 || r2 <= 0.0 || r3 <= 0.0)
+    PRINT_ERROR( "Chamfer radii must be greater than zero.\n" );
+  curves.append(c1);
+  curves.append(c2);
+  curves.append(c3);
+  DLIList<double> radii;
+  radii.append(r1);
+  radii.append(r2);
+  radii.append(r3);
+  //check point on curves
+  OCCPoint* occ_point = CAST_TO(point_ptr, OCCPoint);
+  CubitVector position = occ_point->coordinates();
+  DLIList<CubitVector> locations;
+  for(int i = 0; i < 3; i++)
+    OCCCurve *occ_curve = NULL;
+    occ_curve = CAST_TO(curves.get_and_step(), OCCCurve);
+    double length = occ_curve->measure();
+    DLIList<OCCPoint*> point_list;
+    occ_curve->get_points(point_list);
+    CubitBoolean in = point_list.is_in_list(occ_point);
+    if(!in)
+      PRINT_ERROR( "Point is not on curve.\n" );
+    //find cutting points on curves
+    double u, u1, u2;
+    occ_curve->get_param_range(u1,u2);
+    u = occ_curve->u_from_position(position);
+    if(fabs(u-u1) < TOL)
+      u = occ_curve->u_from_arc_length(u1, radii[i]);
+    else
+      u = occ_curve->u_from_arc_length(u1, length-radii[i]);
+    CubitVector c_p;
+    occ_curve->position_from_u(u, c_p);
+    locations.append(c_p);
+  //decide normal
+  CubitVector v1, v2, normal;
+  CubitVector point_1 = locations.pop();
+  CubitVector point_2 = locations.pop();
+  CubitVector point_3 = locations.pop();
+  v1 = point_2 - point_1;
+  v2 = point_1 - point_3;
+  normal = ~(v1 * v2);
+  CubitVector center;
+  double volume;
+  body->mass_properties(center, volume);
+  CubitVector dir = ~(center - position);
+  if(normal % dir > 0.0)//1, 3, 2 order
+    CubitVector v = point_2;
+    point_2 = point_3;
+    point_3 = v;
+  DLIList<BodySM*> bodies;
+  BodySM* new_body;
+  if(keep_old_body || preview)
+    new_body = copy_body(body);
+  else
+    new_body = body;
+  bodies.append(new_body);
+  const CubitVector p1 = point_1;
+  const CubitVector p2 = point_2;
+  const CubitVector p3 = point_3;
+  CubitStatus status = section(bodies, p1, p2, p3,
+                               new_bodysm_list, true,false, false);
+  if(!status)
+  if(!preview)
+     OCCSurface* surf = CAST_TO(new_bodysm, OCCBody)->my_sheet_surface();
+     TopoDS_Face* modified_shape = surf->get_TopoDS_Face();
+     // Draw this face
+     OCCDrawTool::instance()->draw_FACE( modified_shape, CUBIT_BLUE, CUBIT_TRUE );
+CubitStatus
+OCCModifyEngine::sort_points_by_body_type( DLIList<Point*> &point_list,
+                                         DLIList<Point*> &solid_points,
+                                         DLIList<Point*> &sheet_points,
+                                         DLIList<OCCSurface*> &s_list,
+                                         DLIList<OCCBody*> &bodies )
+  for (int i = 0; i < point_list.size(); i++)
+    int curve_size = 0;
+    if(point != NULL)
+      if(parents.size() < 2)
+        PRINT_ERROR( "Vertex found not attached to any surfaces.\n" );
+      else if(parents.size() > 3)
+        PRINT_ERROR( "Vertex found attached to multiple bodies.\n" );
+      curve_size = parents.size();
+    OCCCurve* occ_curve = CAST_TO(parents.get(), OCCCurve);
+    parents.clean_out();
+    occ_curve->get_parents_virt(parents); //OCCCoEdges
+    if(parents.size() == 0)
+    OCCCoEdge* coedge = CAST_TO(parents.get(), OCCCoEdge);
+    coedge->get_parents_virt(parents);  //OCCLoops
+    assert(parents.size() > 0);
+    OCCLoop* loop = CAST_TO(parents.get(), OCCLoop);
+    loop->get_parents_virt(parents); //OCCSurface
+    OCCSurface* s = CAST_TO(parents.get(), OCCSurface);
+    if(s->my_body() != NULL && curve_size == 2) //sheet body
+      s_list.append(s);
+      sheet_points.append(point);
+    else if(s->my_body() != NULL && curve_size == 3) //shell body
+      PRINT_ERROR( "Vertex found attached to multiple surfaces but not on bodies.\n" );
+    else
+      solid_points.append(point);
+      OCCQueryEngine* oqe = OCCQueryEngine::instance();
+      DLIList <OCCBody* > *occ_bodies = oqe->BodyList;
+      for(int i = 0; i < occ_bodies->size(); i++)
+        DLIList<OCCSurface*> surfaces;
+        OCCBody* occ_body = occ_bodies->get_and_step();
+        occ_body->get_all_surfaces(surfaces);
+        if(surfaces.is_in_list(s))
+          bodies.append(occ_body);
+          break;
 // Function   : tweak_fillet
 // Member Type: PUBLIC
@@ -6046,7 +6351,7 @@
                                            double radius,
   CubitStatus stat;
   int count = 0;
@@ -6106,7 +6411,7 @@
                                            double end_radius,
                                            BodySM *& new_bodysm_ptr,
   return tweak_fillet(curve_ptr, start_radius, end_radius, new_bodysm_ptr,
                       keep_old_body, preview, CUBIT_TRUE);
@@ -6127,7 +6432,7 @@
                                            CubitBoolean preview,
-                                           CubitBoolean if_fillet ) const
+                                           CubitBoolean if_fillet )
   //check if this id is valid
@@ -6271,68 +6576,86 @@
                                double radius,
-  OCCQueryEngine* oqe = OCCQueryEngine::instance();
-  DLIList <OCCSurface* > *faces = oqe->SurfaceList;
+  return tweak_fillet_chamfer_sheet(ref_vertex_list, s_list, radius, CUBIT_TRUE,
+         new_bodysm_list, keep_old_body, preview);
+CubitStatus
+OCCModifyEngine::tweak_fillet_chamfer_sheet( DLIList<Point*> & ref_vertex_list,
+                               DLIList<OCCSurface*> faces,
+                               double radius,
+                               CubitBoolean is_fillet,
+                               DLIList<BodySM*> & new_bodysm_list,
   TopTools_IndexedDataMapOfShapeListOfShape M;
-  DLIList<TopoDS_Face*> shape_list;
+  if(ref_vertex_list.size() != faces.size())
   for(int i = 0; i < ref_vertex_list.size(); i ++)
     Point* pnt = ref_vertex_list.get_and_step();
     OCCPoint* occ_pnt = CAST_TO(pnt, OCCPoint);
     TopoDS_Vertex* vertex = occ_pnt->get_TopoDS_Vertex();
-    OCCSurface* face = NULL;
-    shape_list.clean_out();
-    for(int j = 0; j <  faces->size(); j++)
+    OCCSurface* face = faces.get_and_step();
+    if(!is_fillet)
-      face = faces->get_and_step();
-      TopExp_Explorer Ex;
-      TopoDS_Face ashape = *(face->get_TopoDS_Face());
-      M.Clear();
-      TopExp::MapShapesAndAncestors(ashape, TopAbs_VERTEX, TopAbs_FACE, M);
-      if(!M.Contains(*vertex))
-        continue;
-      if(face->my_body() == NULL )
+      //find the two edges sharing the vertex.
+      DLIList<OCCCurve*> curves;
+      face->get_curves(curves);
+      int size = curves.size();
+      for(int j = 0; j < size; j ++)
-        PRINT_ERROR("Can only create fillet on sheet body.\n");
-      shape_list.append_unique(face->get_TopoDS_Face());
-    if(shape_list.size() != 1)
-      PRINT_ERROR("Can't create fillet on given vertex.\n");
-    TopoDS_Face *shape = shape_list.get();
-    TopoDS_Face newShape;
-    if(keep_old_body)
-      BRepBuilderAPI_Copy api_copy(*shape);
-      newShape = TopoDS::Face(api_copy.ModifiedShape(*shape));
+        OCCCurve *curve = curves.get();
+        curve->get_points(point_list);
+        if(!point_list.is_in_list(occ_pnt))
+          curves.remove();
+        else
+          curves.step();
+      assert (curves.size()==2);
+      tweak_chamfer_sheet(pnt, face, radius, curves.pop(), radius, curves.pop(),
+                        new_bodysm_list, keep_old_body, CUBIT_FALSE);
     else
-      newShape = *shape;
+      TopoDS_Face *shape = face->get_TopoDS_Face();
+      TopoDS_Face newShape;
+      if(keep_old_body)
+        BRepBuilderAPI_Copy api_copy(*shape);
+        newShape = TopoDS::Face(api_copy.ModifiedShape(*shape));
+      else
+        newShape = *shape;
-    BRepFilletAPI_MakeFillet2d fillet(newShape);
-    TopoDS_Edge fillet_edge = fillet.AddFillet(*vertex, radius);
+      BRepFilletAPI_MakeFillet2d fillet(newShape);
+      TopoDS_Edge fillet_edge;
+      fillet_edge = fillet.AddFillet(*vertex, radius);
+      fillet.Build();
+      if(fillet.Status() != ChFi2d_IsDone)
+        PRINT_ERROR("Can't create fillet on given curve.\n");
+      TopoDS_Shape modified_shape = fillet.Shape();
-    if(fillet.Status() != ChFi2d_IsDone)
-      PRINT_ERROR("Can't create fillet on given curve.\n");
+      OCCSurface::update_OCC_entity(newShape , modified_shape, &fillet);
+      TopoDS_Face modified_face = TopoDS::Face(modified_shape);
+      Surface* surf = OCCQueryEngine::instance()->populate_topology_bridge(modified_face, CUBIT_TRUE);
+      BodySM* new_bodysm_ptr = CAST_TO(surf,OCCSurface)->my_body();
+      new_bodysm_list.append(new_bodysm_ptr);
-    TopoDS_Shape modified_shape = fillet.Shape();
-    OCCSurface::update_OCC_entity(newShape , modified_shape, &fillet);
-    TopoDS_Face modified_face = TopoDS::Face(modified_shape);
-    Surface* surf = OCCQueryEngine::instance()->populate_topology_bridge(modified_face, CUBIT_TRUE);
-    BodySM* new_bodysm_ptr = CAST_TO(surf,OCCSurface)->my_body();
-    new_bodysm_list.append(new_bodysm_ptr);
   if(!preview )
@@ -6355,6 +6678,74 @@
+CubitStatus
+OCCModifyEngine::tweak_chamfer_sheet(Point* pnt,
+                                     OCCSurface* face,
+                                     double d1,
+                                     Curve* edge1,
+                                     double d2,
+                                     Curve* edge2,
+  if(keep_old_body)
+  else
+  if(edge1 == NULL || edge2 == NULL)
+    PRINT_ERROR("Cannot find the two edges for the vertex.\n");
+  TopoDS_Edge* topo_e1 = CAST_TO(edge1, OCCCurve)->get_TopoDS_Edge();
+  TopoDS_Edge* topo_e2 = CAST_TO(edge2, OCCCurve)->get_TopoDS_Edge();
+  fillet_edge = fillet.AddChamfer( *topo_e1, *topo_e2, d1, d2);
+  fillet.Build() ;
+    PRINT_ERROR("Can't create chamfer on given vertex.\n");
+  if( !preview )
+    Ex.Init(newShape, TopAbs_SOLID);
+    TopoDS_Solid old_solid = TopoDS::Solid(Ex.Current());
+    OCCLump::update_OCC_entity(old_solid , modified_shape, &fillet);
+    DLIList<TopologyBridge*> tbs = OCCQueryEngine::instance()->populate_topology_bridge(modified_shape);
+    BodySM* new_bodysm_ptr = CAST_TO(tbs.get(), BodySM);
+  else
+    Ex.Init(modified_shape, TopAbs_FACE);
+      // Draw this face
 // Function   : tweak_move
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2009-03-23 14:47:00 UTC (rev 2742)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2009-03-24 19:21:42 UTC (rev 2743)
@@ -397,7 +397,7 @@
-                                     CubitBoolean preview = CUBIT_FALSE ) const;
+                                     CubitBoolean preview = CUBIT_FALSE ) ;
@@ -413,7 +413,7 @@
     *   in the direction of the supplied edges.  If multiple vertices are
@@ -424,7 +424,7 @@
                                     double radius,
@@ -433,7 +433,7 @@
                                     double end_radius,
                                     BodySM *&new_body_ptr,
@@ -442,7 +442,7 @@
                                     double radius,
@@ -601,13 +601,56 @@
                           TopoDS_Shape& stitched_shape) const;
 private:
+ CubitStatus tweak_chamfer_sheet(Point* pnt,
+                                 OCCSurface* face,
+                                 double d1,
+                                 Curve* edge1,
+                                 double d2,
+                                 Curve* edge2,
+                                 CubitBoolean preview ) ;
+ CubitStatus tweak_fillet_chamfer_sheet( DLIList<Point*> & ref_vertex_list,
+                               double radius,
+ CubitStatus tweak_chamfer_solid( Point* point_ptr,
+                                    OCCBody* body,
+                                    double r1,
+                                    Curve *c1,
+                                    double r2,
+                                    Curve *c2,
+                                    double r3,
+                                    Curve *c3,
+                                    CubitBoolean preview );
+ CubitStatus tweak_chamfer_solid( DLIList<Point*> &point_list,
+                                    double radius,
+ CubitStatus sort_points_by_body_type( DLIList<Point*> &point_list,
+                                         DLIList<OCCBody*> &bodies );
  CubitStatus tweak_fillet( Curve * curve_ptr,
                            double start_radius,
                            double end_radius,
-                           CubitBoolean if_fillet ) const;
+                           CubitBoolean if_fillet ) ;
  CubitStatus do_loft(BRepOffsetAPI_ThruSections& loft,
                      Surface * face1,
Modified: cgm/trunk/geom/facet/FacetModifyEngine.cpp
--- cgm/trunk/geom/facet/FacetModifyEngine.cpp	2009-03-23 14:47:00 UTC (rev 2742)
+++ cgm/trunk/geom/facet/FacetModifyEngine.cpp	2009-03-24 19:21:42 UTC (rev 2743)
@@ -2710,7 +2710,7 @@
                                               DLIList<BodySM*> & /*new_bodysm_list*/,
                                               double /*right_offset*/,
                                               CubitBoolean /*keep_old_body*/,
-                                              CubitBoolean /*preview*/ ) const
+                                              CubitBoolean /*preview*/ )
@@ -2737,7 +2737,7 @@
                                   double /*offset3*/,
                                   Curve * /*edge3*/,
@@ -2755,7 +2755,7 @@
                                              double /*radius*/,
@@ -2775,7 +2775,7 @@
                                              double /*end_radius*/,
                                              BodySM *& /*new_bodysm_ptr*/,
@@ -2794,7 +2794,7 @@
                                  double /*radius*/,
Modified: cgm/trunk/geom/facet/FacetModifyEngine.hpp
--- cgm/trunk/geom/facet/FacetModifyEngine.hpp	2009-03-23 14:47:00 UTC (rev 2742)
+++ cgm/trunk/geom/facet/FacetModifyEngine.hpp	2009-03-24 19:21:42 UTC (rev 2743)
@@ -488,7 +488,7 @@
@@ -504,7 +504,7 @@
@@ -515,7 +515,7 @@
                                     double radius,
@@ -524,7 +524,7 @@
                                     double end_radius,
@@ -533,7 +533,7 @@
                                     double radius,
More information about the cgma-dev mailing list
