[cgma-dev] r2723 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Tue Mar 17 14:18:46 CDT 2009
Author: janehu
Date: 2009-03-17 14:18:45 -0500 (Tue, 17 Mar 2009)
New Revision: 2723
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.hpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Added tweak_chamfer for curves and some minor changes.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-17 13:38:50 UTC (rev 2722)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-17 19:18:45 UTC (rev 2723)
@@ -48,6 +48,7 @@
#include "GC_MakeTrimmedCylinder.hxx"
#include "gce_MakeElips.hxx"
#include "BRepFilletAPI_MakeFillet.hxx"
+#include "BRepFilletAPI_MakeChamfer.hxx"
#include "BRepAdaptor_CompCurve.hxx"
#include "BRepFilletAPI_MakeFillet2d.hxx"
#include "ChFi2d_ConstructionError.hxx"
@@ -5952,18 +5953,56 @@
// with respect to the curve direction. If the given right offset
// is negative, the left offset is used. Users can preview to
// clarify the meaning of left and right.
-// Author :
-// Date :
+// Author : Jane Hu
+// Date : 03/2009
-CubitStatus OCCModifyEngine::tweak_chamfer( DLIList<Curve*> & /*curve_list*/,
- double /*left_offset*/,
- DLIList<BodySM*> & /*new_bodysm_list*/,
- double /*right_offset*/,
- CubitBoolean /*keep_old_body*/,
- CubitBoolean /*preview*/ ) const
+CubitStatus OCCModifyEngine::tweak_chamfer( DLIList<Curve*> & curve_list,
+ double left_offset,
+ DLIList<BodySM*> & new_bodysm_list,
+ double right_offset,
+ CubitBoolean keep_old_body,
+ CubitBoolean preview ) const
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
- return CUBIT_FAILURE;
+ CubitStatus stat;
+ int count = 0;
+ for(int i = 0; i < curve_list.size(); i++)
+ BodySM * new_bodysm_ptr = NULL;
+ stat = tweak_fillet(curve_list.get_and_step(), left_offset, right_offset,
+ new_bodysm_ptr , keep_old_body, CUBIT_FALSE, CUBIT_FALSE);
+ if(stat && new_bodysm_ptr)
+ count++;
+ new_bodysm_list.append(new_bodysm_ptr);
+ if(count == 0)
+ return CUBIT_FAILURE;
+ if(preview)
+ GfxPreview::clear();
+ for(int i = 0; i < new_bodysm_list.size(); i++)
+ BodySM* new_bodysm = new_bodysm_list.get_and_step();
+ TopoDS_Shape* modified_shape =
+ CAST_TO(new_bodysm, OCCBody)->get_TopoDS_Shape();
+ TopExp_Explorer Ex;
+ Ex.Init(*modified_shape, TopAbs_FACE);
+ for( ; Ex.More(); Ex.Next() )
+ TopoDS_Face face = TopoDS::Face(Ex.Current());
+ // Draw this face
+ OCCDrawTool::instance()->draw_FACE( &face, CUBIT_BLUE, CUBIT_TRUE );
+ GfxPreview::flush();
+ OCCQueryEngine::instance()->delete_solid_model_entities(new_bodysm_list);
+ new_bodysm_list.clean_out();
+ return CUBIT_SUCCESS;
@@ -5974,20 +6013,20 @@
// The offsets are in the direction of the supplied edges. If
// multiple vertices are supplied, only one offset value is
// allowed and the edges are not used.
-// Author :
-// Date :
+// Date : 03/09
CubitStatus
-OCCModifyEngine::tweak_chamfer( DLIList<Point*> & /*point_list*/,
- double /*offset1*/,
- Curve * /*edge1*/,
- double /*offset2*/,
- Curve * /*edge2*/,
- double /*offset3*/,
- Curve * /*edge3*/,
+OCCModifyEngine::tweak_chamfer( DLIList<Point*> & point_list,
+ double offset1,
+ Curve * edge1,
+ double offset2,
+ Curve * edge2,
+ double offset3,
+ Curve * edge3,
@@ -6052,9 +6091,29 @@
// Function : tweak_fillet
// Member Type: PUBLIC
+// Description: Create a round fillet (or blend) at the given curves on a solid
+// body. The fillet/chamfer has a variable radius from the
+// start to the end of the curve.
+// Date : 01/09
+CubitStatus OCCModifyEngine::tweak_fillet( Curve * curve_ptr,
+ double start_radius,
+ double end_radius,
+ BodySM *& new_bodysm_ptr,
+ return tweak_fillet(curve_ptr, start_radius, end_radius, new_bodysm_ptr,
+ keep_old_body, preview, CUBIT_TRUE);
+// Function : tweak_fillet
+// Member Type: private
-// body. The fillet has a variable radius from the start to the
-// end of the curve.
// Author : Jane Hu
// Date : 01/09
@@ -6063,7 +6122,8 @@
double end_radius,
- CubitBoolean preview ) const
+ CubitBoolean preview,
+ CubitBoolean if_fillet ) const
OCCCurve *occ_curve = CAST_TO(curve_ptr, OCCCurve);
TopoDS_Edge* topo_edge = occ_curve->get_TopoDS_Edge();
@@ -6073,6 +6133,7 @@
TopTools_IndexedDataMapOfShapeListOfShape M;
DLIList<TopoDS_CompSolid*> shape_list;
OCCBody * body = NULL;
+ TopoDS_Face* s;
for(int j = 0; j < bodies->size(); j++)
body = bodies->get_and_step();
@@ -6089,6 +6150,22 @@
shape_list.append_unique(body->get_TopoDS_Shape());
+ if(!if_fillet) //for chamfer, need to know the face for the curve.
+ DLIList<TopologyBridge*> parents;
+ occ_curve->get_parents_virt(parents); //OCCCoEdges
+ assert(parents.size() > 1);
+ OCCCoEdge* coedge = CAST_TO(parents.get(), OCCCoEdge);
+ parents.clean_out();
+ coedge->get_parents_virt(parents); //OCCLoops
+ assert(parents.size() > 0);
+ OCCLoop* loop = CAST_TO(parents.get(), OCCLoop);
+ loop->get_parents_virt(parents); //OCCSurface
+ s = CAST_TO(parents.get(), OCCSurface)->get_TopoDS_Face();
if(shape_list.size() != 1)
@@ -6105,26 +6182,35 @@
else
newShape = *shape;
- BRepFilletAPI_MakeFillet fillet(newShape);
- fillet.Add(start_radius, end_radius, *topo_edge);
- fillet.Build();
- if(!fillet.IsDone())
+ BRepBuilderAPI_MakeShape* fillet;
+ if(if_fillet)
+ fillet = new BRepFilletAPI_MakeFillet(newShape);
+ dynamic_cast<BRepFilletAPI_MakeFillet*>(fillet)->Add(start_radius, end_radius, *topo_edge);
+ else
+ fillet = new BRepFilletAPI_MakeChamfer(newShape);
+ dynamic_cast<BRepFilletAPI_MakeChamfer*>(fillet)->Add(start_radius, end_radius, *topo_edge, *s);
+ fillet->Build();
+ if(!fillet->IsDone())
PRINT_ERROR("Can't create fillet on given curve.\n");
- TopoDS_Shape modified_shape = fillet.Shape();
+ TopoDS_Shape modified_shape = fillet->Shape();
if( !preview )
TopExp_Explorer Ex;
Ex.Init(newShape, TopAbs_SOLID);
TopoDS_Solid old_solid = TopoDS::Solid(Ex.Current());
- OCCLump::update_OCC_entity(old_solid , modified_shape, &fillet);
+ OCCLump::update_OCC_entity(old_solid , modified_shape, fillet);
DLIList<TopologyBridge*> tbs = OCCQueryEngine::instance()->populate_topology_bridge(modified_shape);
new_bodysm_ptr = CAST_TO(tbs.get(), BodySM);
- return CUBIT_SUCCESS;
else
@@ -6140,8 +6226,9 @@
+ delete fillet;
@@ -6181,7 +6268,11 @@
TopExp::MapShapesAndAncestors(ashape, TopAbs_VERTEX, TopAbs_FACE, M);
if(!M.Contains(*vertex))
continue;
+ if(face->my_body() == NULL )
+ PRINT_ERROR("Can only create fillet on sheet body.\n");
shape_list.append_unique(face->get_TopoDS_Face());
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2009-03-17 13:38:50 UTC (rev 2722)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2009-03-17 19:18:45 UTC (rev 2723)
@@ -601,6 +601,14 @@
TopoDS_Shape& stitched_shape) const;
private:
+ CubitStatus tweak_fillet( Curve * curve_ptr,
+ CubitBoolean if_fillet ) const;
CubitStatus do_loft(BRepOffsetAPI_ThruSections& loft,
Surface * face1,
Surface * face2) const;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2009-03-17 13:38:50 UTC (rev 2722)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2009-03-17 19:18:45 UTC (rev 2723)
@@ -588,6 +588,8 @@
CubitBoolean bounded,
CubitBoolean closest)
+ //If this function has shortcomes in using BRepExtrema_DistShapeShape,
+ //look also at IntTools_EdgeEdge.
OCCCurve *occ_curve1 = CAST_TO(curve1, OCCCurve);
if (occ_curve1 == NULL)
More information about the cgma-dev
