[cgma-dev] r2721 - cgm/trunk
    kraftche at cae.wisc.edu
    Tue Mar 17 08:37:42 CDT 2009
Author: kraftche
Date: 2009-03-17 08:37:42 -0500 (Tue, 17 Mar 2009)
New Revision: 2721
Added:
   cgm/trunk/configure.ac
Removed:
   cgm/trunk/configure.in
Log:
For some time now the recommended name for this file is "configure.ac" rather
than the old "configure.in".  Some Linux distros (e.g. Debian and derivatives)
are installing autoconf as a wrapper that calles either a very old version
of autoconf (2.13) or the current version based on the configure.in/ac suffix.
So rename the configure file.
Copied: cgm/trunk/configure.ac (from rev 2720, cgm/trunk/configure.in)
--- cgm/trunk/configure.ac	                        (rev 0)
+++ cgm/trunk/configure.ac	2009-03-17 13:37:42 UTC (rev 2721)
@@ -0,0 +1,443 @@
+#                           Standard Stuff
+AC_INIT(CGMA, 10.2.2)
+AC_CONFIG_MACRO_DIR([m4])
+AC_CANONICAL_SYSTEM
+AM_INIT_AUTOMAKE(CGMA,10.2.2)
+AC_DISABLE_SHARED
+AC_PROG_SED
+EXTRA_GNU_FLAGS="-Wall -pipe -pedantic"
+SNL_CHECK_COMPILERS
+AC_PROG_FC
+AM_CONDITIONAL(build_parallel, [test "x$WITH_MPI" != "xno"])
+AC_PROG_LIBTOOL
+LIBS="-lm"
+AC_PROG_LIBTOOL
+AC_C_BIGENDIAN( [LITTLE_ENDIAN=], [LITTLE_ENDIAN=-DLITTLE_ENDIAN=BYTE_ORDER] )
+AC_SUBST(LITTLE_ENDIAN)
+#                Fortran Stuff for ITAPS C bindings
+if test "x" != "x$FC"; then
+  AC_FC_WRAPPERS
+fi
+#                              Extract libtool config
+ITAPS_LIBTOOL_VAR( [CXX], [compiler_lib_search_path], [CGM_CXX_LINKFLAGS])
+ITAPS_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
+AC_SUBST(CGM_CXX_LINKFLAGS)
+AC_SUBST(CGM_CXX_LIBS)
+#                              MPI OPTIONS
+if test "x$WITH_MPI" != "xno"; then
+  CXXFLAGS="$CXXFLAGS -DUSE_MPI"
+  CGM_PARALLEL_INCLUDE='-I${CGM_DIR}/geom/parallel'
+  CGM_PARALLEL_LIB='-L${CGM_DIR}/geom/parallel -lcubit_parallel'
+  CGM_PARALLEL_LIB_FILE='${CGM_LIBDIR}/libcubit_parallel.la'
+fi
+AM_CONDITIONAL(USE_MPI, [test "xno" != "x$WITH_MPI"])
+AC_SUBST(CGM_PARALLEL_INCLUDE)
+AC_SUBST(CGM_PARALLEL_LIB)
+AC_SUBST(CGM_PARALLEL_LIB_FILE)
+#                           CGM-specific Checks
+SNL_CANT_USE_STD
+SNL_TEMPLATE_DEFS_INCLUDED
+AC_SUBST(CANT_USE_STD)
+AC_SUBST(CANT_USE_STD_IO)
+AC_SUBST(TEMPLATE_DEFS_INCLUDED)
+AM_CONDITIONAL(INCLUDE_TEMPLATE_DEFS, test x$TEMPLATE_DEFS_INCLUDED != x)
+#                         Use Cubit shared libraries
+CUBIT_FILE=no
+CUBIT_BIN_DIR=no
+HAVE_ACIS_DEF=
+AC_ARG_WITH( cubit,
+             AC_HELP_STRING([--with-cubit=<dir>],[Use CGM from CUBIT shared library]),
+             [CUBIT_DIR="$withval"
+              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-cubit=\"${withval}\""],
+             [CUBIT_DIR=no])
+AC_ARG_WITH( CUBIT,
+             AC_HELP_STRING([--with-CUBIT=<dir>],[DEPRECATED.  Use --with-cubit (small case)]),
+              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-cubit=\"${withval}\""])
+if test "x$CUBIT_DIR" == "xyes"; then
+  AC_MSG_ERROR([Option --with-CUBIT without specifying Cubit directory.])
+elif test "x$CUBIT_DIR" != "xno"; then
+  if ! test -d "$CUBIT_DIR"; then
+    AC_MSG_ERROR([$CUBIT_DIR: not a directory.])
+  fi
+  CUBIT_LDFLAGS=
+  CUBIT_LTFLAGS=
+  CUBIT_LIBS=no
+  if test -d "$CUBIT_DIR/bin"; then
+    CUBIT_BIN_DIR="$CUBIT_DIR/bin"
+  elif test -d "$CUBIT_DIR/lib"; then
+    CUBIT_BIN_DIR="$CUBIT_DIR/lib"
+  elif test -d "$CUBIT_DIR/libs"; then
+    CUBIT_BIN_DIR="$CUBIT_DIR/libs"
+  else
+    CUBIT_BIN_DIR="$CUBIT_DIR"
+  fi
+  CUBIT_LDFLAGS="-L$CUBIT_BIN_DIR"
+  CUBIT_LTFLAGS="-R$CUBIT_BIN_DIR"
+  cat >conftest.cc <<EOCUBITCT
+class AcisQueryEngine { public: static AcisQueryEngine* instance_; };
+int main() {
+  AcisQueryEngine::instance_ = 0;
+  return 0;
+EOCUBITCT
+  pattern=["${CUBIT_BIN_DIR}/*cubiti[0-9][0-9].*"]
+  for file in $pattern; do
+    AC_MSG_CHECKING([for AcisQueryEngine::instance_ in $file])
+    num=[`expr X"$file" : X".*cubiti\([0-9][0-9]\)\..*"`]
+    if ./libtool --mode=link $CXX $LDFLAGS $CUBIT_LDFLAGS $CUBIT_LTFLAGS -lcubiti$num conftest.cc -o conftest >&5 2>&5; then
+      CUBIT_LIBS="-lcubiti$num"
+      CUBIT_FILE=`expr x"$file" : x"$CUBIT_BIN_DIR/\(.*\)"`
+      CUBIT_FILE="${CUBIT_BIN_DIR}/$CUBIT_FILE"
+      AC_MSG_RESULT(yes)
+    else
+      AC_MSG_RESULT(no)
+    fi
+  done
+  rm -f conftest.cc
+  if test "x$CUBIT_LIBS" = "xno"; then
+    AC_MSG_ERROR("Cubit library not found in $CUBIT_BIN_DIR")
+  fi
+  CGM_EXT_LIBS="$CGM_EXT_LIBS $CUBIT_LIBS"
+  CGM_EXT_LDFLAGS="$CGM_EXT_LDFLAGS $CUBIT_LDFLAGS"
+  CGM_EXT_LTFLAGS="$CGM_EXT_LTFLAGS $CUBIT_LTFLAGS"
+  CUBIT_CGM="-DCUBIT_CGM"
+dnl  AC_DEFINE( HAVE_ACIS, "Have CGM ACIS Implementation" )
+  HAVE_ACIS_DEF=-DHAVE_ACIS
+fi
+AC_SUBST(CUBIT_BIN_DIR)
+AC_SUBST(CUBIT_LDFLAGS)
+AC_SUBST(CUBIT_LTFLAGS)
+AC_SUBST(CUBIT_LIBS)
+AC_SUBST(CUBIT_FILE)
+AC_SUBST(CUBIT_CGM)
+AM_CONDITIONAL(BUILD_CGM,[test x"$CUBIT_DIR" == x"no"])
+AM_CONDITIONAL(WITH_CUBIT,[test x"$CUBIT_DIR" != x"no"])
+#                           ACIS OPTIONS
+ACIS_BASE_LIBS='-lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase'
+ACIS_STEP_LIBS='-lacisstep -lxstep'
+ACIS_IGES_LIBS='-lacisiges -lxiges'
+AC_ARG_WITH( acis,
+             AC_HELP_STRING([--with-acis=<dir>],[Build with ACIS support, specify directory where ACIS is installed.]),
+             [ACIS_DIR=$withval
+              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-acis=\"${withval}\""],
+              [ACIS_DIR=no] )
+AC_ARG_WITH( ACIS,
+             AC_HELP_STRING([--with-ACIS],[DEPRECATED.  Use --wtih-acis (small case)]),
+              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-acis=\"${withval}\""] )
+AC_ARG_WITH( ACIS-system, AC_HELP_STRING([--with-acis-system=SYS],
+          [Specify ACIS system name (e.g. linux_so), default is to autodetect.]),
+             [ACIS_SYSTEM=$withval],[ACIS_SYSTEM=] )
+AC_ARG_WITH( acis-version, AC_HELP_STRING([--with-acis-version=INT],
+[Specify ACIS version as an integer value (100*major+10*minor+point), default is to autodetect.]),
+[if ! test "$withval" -gt "600"; then
+  AC_MSG_ERROR("ACIS-version must be an integer greater than 600.")
+ fi
+ ACIS_VERSION=$withval],
+[ACIS_VERSION=0])
+if test "x$ACIS_DIR" == "x"; then
+  ACIS_DIR=no
+fi
+if test "x$ACIS_DIR" == "xno"; then
+  ACIS_LIB_DIR=
+  ACIS_LINK_FLAGS=
+fi
+if test "x$ACIS_DIR" != "xno"; then
+  if test "x$CUBIT_DIR" != "xno"; then
+    AC_MSG_ERROR("Conflicting options:  Cannot specifiy both --with-ACIS and --with-CUBIT")
+  fi
+  AC_CHECK_FILE( [${srcdir}/geom/ACIS/AcisQueryEngine.hpp], [],
+                 [AC_MSG_ERROR([ACIS source not present.  Checkout ACIS_SRC and move to ACIS])] )
+  if test "$ACIS_DIR" == "yes"; then ACIS_DIR=.; fi
+  SNL_ACIS_ENV
+  SNL_ACIS_TRANSLATOR
+  if test x$ACIS_STEP_TRANSLATOR != x; then
+    ACIS_LIBS="$ACIS_LIBS $ACIS_STEP_LIBS"
+    ACIS_XLIBS="$ACIS_XLATE_LIBS"
+  fi
+  if test x$ACIS_IGES_TRANSLATOR != x; then
+    ACIS_LIBS="$ACIS_LIBS $ACIS_IGES_LIBS"
+  fi
+  CGM_ACIS_LIBS='-lcubit_ACIS'
+  ACIS_LIBS="$ACIS_LIBS $ACIS_XLIBS $ACIS_BASE_LIBS"
+  ACIS_LINK_FLAGS="-L$ACIS_LIB_DIR"
+  ACIS_HEALER="-DACIS_HEALER"
+  ACIS_INCLUDES="-I$ACIS_DIR/include"
+  ACIS_LTFLAGS="-R$ACIS_LIB_DIR"
+  CGM_EXT_LIBS="$CGM_EXT_LIBS $ACIS_LIBS"
+  CGM_EXT_LDFLAGS="$CGM_EXT_LDFLAGS $ACIS_LINK_FLAGS"
+  CGM_EXT_INCLUDE="$CGM_EXT_INCLUDE $ACIS_INCLUDES"
+  CGM_EXT_LTFLAGS="$CGM_EXT_LTFLAGS $ACIS_LTFLAGS"
+  if test "x$GXX" = "xyes"; then
+    CPPFLAGS="$CPPFLAGS -isystem $ACIS_DIR/include"
+  fi
+  ACIS_DEFS='$(ACIS_STEP_TRANSLATOR) $(ACIS_IGES_TRANSLATOR) -DCUBIT_ACIS_VERSION=$(ACIS_VERSION) -DACIS_VERSION=$(ACIS_VERSION) -D$(ACIS_PLATFORM) -DACIS_LOCAL_OPS'
+dnl  AC_DEFINE( HAVE_ACIS )
+fi
+# ACIS (at least up to version 16) requires new.h.
+# Newer C++ compilers may not provide this backwards-compatibility
+# file.  Check if it is present, and if not, use our own.
+ACIS_NEW_COMPAT_INC='-I${top_srcdir}/compat/new'
+  AC_LANG_PUSH(C++)
+  AC_CHECK_HEADER([new.h],[],[ACIS_INCLUDES="$ACIS_INCLUDES $ACIS_NEW_COMPAT_INC"])
+  AC_LANG_POP(C++)
+fi
+AC_SUBST(ACIS_DEFS)
+AC_SUBST(ACIS_DIR)
+AC_SUBST(ACIS_LINK_FLAGS)
+AC_SUBST(ACIS_LIB_DIR)
+AC_SUBST(ACIS_INCLUDES)
+AC_SUBST(ACIS_LIBS)
+AC_SUBST(CGM_ACIS_LIBS)
+AC_SUBST(ACIS_HEALER)
+AC_SUBST(ACIS_VERSION)
+AC_SUBST(ACIS_PLATFORM)
+AC_SUBST(ACIS_STEP_TRANSLATOR)
+AC_SUBST(ACIS_IGES_TRANSLATOR)
+AC_SUBST(HAVE_ACIS_DEF)
+AM_CONDITIONAL(build_ACIS, test x$ACIS_DIR != xno)
+#                           iGeom Babel
+AC_ARG_WITH(babel,
+[AC_HELP_STRING([--with-babel=DIR], [Specify directory containing babel])],
+[BABEL_DIR=$withval
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-babel=\"${withval}\""
+ ], [BABEL_DIR=no])
+case "x$BABEL_DIR" in
+  xno)
+    BABEL_DIR=
+    USE_BABEL=no
+  xyes|x)
+    BABEL_DIR=/usr/local
+    AC_CHECK_FILE([${BABEL_DIR}/bin/babel], [USE_BABEL=yes], [USE_BABEL=no])
+esac
+AC_SUBST(BABEL_DIR)
+AC_SUBST(USE_BABEL)
+AM_CONDITIONAL(USE_BABEL, [test "xno" != "x$USE_BABEL"])
+#                           OCC Options
+# Add --with-occ option to configure script
+AC_ARG_WITH( occ,
+             [AC_HELP_STRING([--with-occ=<dir>],[OpenCascade shared library directory])],
+             [occ_DIR="$withval"
+              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-occ=\"${withval}\""],
+             [occ_DIR=no] )
+# if user specified option (other than --without-occ)
+CUBIT_OCC_LIB=
+HAVE_OCC_DEF=
+if test "x$occ_DIR" != "xno"; then
+  OCC_LIBS="-lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKTopAlgo -lTKHLR -lTKIGES -lTKMesh -lTKPrim -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTopAlgo -lTKXSBase -lTKLCAF"
+  CUBIT_OCC_LIB="-lcubit_OCC"
+  # Set OCC_INC_FLAG and OCC_LIB_FLAG based on --with-occ option
+  if test "x$occ_DIR" = "x"; then
+    OCC_INC_FLAG=
+    OCC_LIB_DIR=
+    OCC_LIB_FLAG=
+  else
+    AC_CACHE_CHECK( [for 'include' subdir of $occ_DIR],
+                    [ac_cv_occ_include_dir],
+                    [ac_cv_occ_include_dir=NONE
+                     for subdir in inc ros/inc include; do
+                       if test -f "${occ_DIR}/${subdir}/Standard_Version.hxx"; then
+                         ac_cv_occ_include_dir="$subdir"
+                         break
+                       elif test -d "${occ_DIR}/${subdir}"; then
+                         ac_cv_occ_include_dir="$subdir";
+                       fi
+                     done] )
+    if test "xNONE" = "x$ac_cv_occ_include_dir"; then
+      AC_MSG_ERROR([Count not find include dir in: $occ_DIR])
+    else
+      OCC_INC_FLAG="-I${occ_DIR}/$ac_cv_occ_include_dir"
+    fi
+    AC_CACHE_CHECK( [for 'lib' subdir of $occ_DIR],
+                    [ac_cv_occ_lib_dir],
+                    [ac_cv_occ_lib_dir=NONE
+                     uname=`uname`
+                     for subdir in lib ros/lib ros/${uname}/lib ros/$uname ; do
+                       if test -d "${occ_DIR}/${subdir}"; then
+                         ac_cv_occ_lib_dir="$subdir"
+                         for file in ${occ_DIR}/${subdir}/libTKernel.* ; do
+                           if test -f $file; then
+                             break 2
+                           fi
+                         done
+                       fi
+                     done] )
+    if test "xNONE" = "x$ac_cv_occ_lib_dir"; then
+      AC_MSG_ERROR([Count not find lib dir in: $occ_DIR])
+    else
+      OCC_LIB_DIR="$occ_DIR/$ac_cv_occ_lib_dir"
+      OCC_LIB_FLAG="-L$OCC_LIB_DIR"
+    fi
+  fi
+  # Check of OCC is present and working
+  # Save old value of these variables and update working ones
+  old_CPPFLAGS="$CPPFLAGS"
+  old_LDFLAGS="$LDFLAGS"
+  CPPFLAGS="$CPPFLAGS ${OCC_INC_FLAG}"
+  LDFLAGS="$LDFLAGS -L$OCC_LIB_DIR"
+  # Check if 64-bit
+  AC_MSG_CHECKING([if platform is 64-bit (-D_OCC64)])
+  AC_TRY_COMPILE([],[int array[6-(int)sizeof(void*)];],[AC_MSG_RESULT(no)],
+                 [AC_MSG_RESULT(yes); OCC_INC_FLAG="$OCC_INC_FLAG -D_OCC64"])
+  # OCC requires some defines
+  AC_LANG_PUSH(C++)
+  AC_CHECK_HEADER([iostream],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOSTREAM"])
+  AC_CHECK_HEADER([iostream.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOSTREAM_H"])
+  AC_CHECK_HEADER([iomanip],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOMANIP"])
+  AC_CHECK_HEADER([iomanip.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOMANIP_H"])
+  AC_CHECK_HEADER([fstream],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_FSTREAM"])
+  AC_CHECK_HEADER([fstream.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_FSTREAM_H"])
+  AC_CHECK_HEADER([limits.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_LIMITS_H"])
+  # Check for OCC headers Stadard_Version.hxx
+  AC_CHECK_HEADER( [Standard_Version.hxx], [],
+                 [AC_MSG_ERROR([OpenCascade config error:Standard_Version.hxx not found])] )
+  # Check if libTKernel.so contains function 'create_mailbox'
+  # OCC 6.3 has build error where libTKernel.so requires libdl.so,
+  #   but does not list that in the shared library dependencies.
+  #   Try to work around this bug by detecting the need for -ldl.
+  AC_CHECK_LIB( [TKernel], [create_mailbox],,
+                [unset ac_cv_lib_TKernel_create_mailbox
+                               [OCC_LIBS="$OCC_LIBS -ldl"],
+                               [AC_MSG_ERROR([OpenCascade config error: libTKernel not found ])],
+                               [-ldl] )
+  AC_LANG_POP(C++)
+  # Restore original values of variables
+  CPPFLAGS="$old_CPPFLAGS"
+  LDFLAGS="$old_LDFLAGS"
+  HAVE_OCC_DEF="-DHAVE_OCC"
+  # Append to CGM global values
+  CGM_EXT_LIBS="$CGM_EXT_LIBS $OCC_LIBS"
+  CGM_EXT_LDFLAGS="$CGM_EXT_LDFLAGS $OCC_LIB_FLAG"
+  CGM_EXT_INCLUDE="$CGM_EXT_INCLUDE $OCC_INC_FLAG"
+  # NOTE: No CGM_EXT_LTFLAGS because OCC libs are .la files (not needed)
+fi
+# Export these variables as variables in Makefiles
+AC_SUBST(OCC_INC_FLAG)
+AC_SUBST(OCC_LIB_DIR)
+AC_SUBST(OCC_LIB_FLAG)
+AC_SUBST(OCC_LIBS)
+AC_SUBST(CUBIT_OCC_LIB)
+AC_SUBST(HAVE_OCC_DEF)
+#                           Define variables for linking
+AC_SUBST(CGM_EXT_LIBS)
+AC_SUBST(CGM_EXT_LDFLAGS)
+AC_SUBST(CGM_EXT_LTFLAGS)
+AC_SUBST(CGM_EXT_INCLUDE)
+# Allow "if build_OCC" in Makefile.am
+AM_CONDITIONAL( build_OCC, [test "x$occ_DIR" != "xno"] )
+#                           Output Files
+AC_SUBST(AM_CPPFLAGS)
+AC_SUBST(DISTCHECK_CONFIGURE_FLAGS)
+AC_MSG_RESULT([CXXFLAGS = $CXXFLAGS])
+dnl AC_OUTPUT_COMMANDS( [if test -f util/CubitUtilConfigure.h; then true; else echo "#define CUBIT_UTIL_EXPORT" > util/CubitUtilConfigure.h; fi],
+dnl                     [if test -f geom/CubitGeomConfigure.h; then true; else echo "#define CUBIT_GEOM_EXPORT" > geom/CubitGeomConfigure.h; fi] )
+AC_CONFIG_HEADERS(config.h)
+AC_CONFIG_HEADERS(itaps/iBase_FCDefs.h)
+AC_CONFIG_FILES(Makefile
+           util/Makefile
+           geom/Makefile
+           geom/ACIS/Makefile
+           geom/Cholla/Makefile
+           geom/facet/Makefile
+           geom/facetbool/Makefile
+           geom/OCC/Makefile
+           geom/parallel/Makefile
+           geom/virtual/Makefile
+           init/Makefile
+           compat/Makefile
+           cgm.make
+           itaps/Makefile
+           itaps/iGeom-Defs.inc
+	   itaps/SIDL/Makefile
+	   itaps/SIDL/common.make
+           itaps/SIDL/iGeom-SIDL-Defs.inc
+           test/Makefile
+           cgm_apps/Makefile
+           cgm_apps/examples/Makefile
+           cgm_apps/examples/driverc++/Makefile
+           cgm_apps/examples/facetdriver/Makefile
+AC_OUTPUT
+if test "x$CUBIT_DIR" != "xno" && test "x$CUBIT_DIR" != "x"; then
+   AC_MSG_WARN([Linking against Cubit-based CGM; you'll need to add Cubit's 'bin' directory
+                to your LD_LIBRARY_PATH before linking, or add -R (linux) or equivalent (non-linux)
+                to your link statement to link applications.])
+fi
Property changes on: cgm/trunk/configure.ac
___________________________________________________________________
Deleted: cgm/trunk/configure.in
--- cgm/trunk/configure.in	2009-03-17 13:37:01 UTC (rev 2720)
+++ cgm/trunk/configure.in	2009-03-17 13:37:42 UTC (rev 2721)
@@ -1,443 +0,0 @@
-#                           Standard Stuff
-AC_INIT(CGMA, 10.2.2)
-AC_CONFIG_MACRO_DIR([m4])
-AC_CANONICAL_SYSTEM
-AM_INIT_AUTOMAKE(CGMA,10.2.2)
-AC_DISABLE_SHARED
-AC_PROG_SED
-EXTRA_GNU_FLAGS="-Wall -pipe -pedantic"
-SNL_CHECK_COMPILERS
-AC_PROG_FC
-AM_CONDITIONAL(build_parallel, [test "x$WITH_MPI" != "xno"])
-AC_PROG_LIBTOOL
-LIBS="-lm"
-AC_PROG_LIBTOOL
-AC_C_BIGENDIAN( [LITTLE_ENDIAN=], [LITTLE_ENDIAN=-DLITTLE_ENDIAN=BYTE_ORDER] )
-AC_SUBST(LITTLE_ENDIAN)
-#                Fortran Stuff for ITAPS C bindings
-if test "x" != "x$FC"; then
-  AC_FC_WRAPPERS
-fi
-#                              Extract libtool config
-ITAPS_LIBTOOL_VAR( [CXX], [compiler_lib_search_path], [CGM_CXX_LINKFLAGS])
-ITAPS_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
-AC_SUBST(CGM_CXX_LINKFLAGS)
-AC_SUBST(CGM_CXX_LIBS)
-#                              MPI OPTIONS
-if test "x$WITH_MPI" != "xno"; then
-  CXXFLAGS="$CXXFLAGS -DUSE_MPI"
-  CGM_PARALLEL_INCLUDE='-I${CGM_DIR}/geom/parallel'
-  CGM_PARALLEL_LIB='-L${CGM_DIR}/geom/parallel -lcubit_parallel'
-  CGM_PARALLEL_LIB_FILE='${CGM_LIBDIR}/libcubit_parallel.la'
-fi
-AM_CONDITIONAL(USE_MPI, [test "xno" != "x$WITH_MPI"])
-AC_SUBST(CGM_PARALLEL_INCLUDE)
-AC_SUBST(CGM_PARALLEL_LIB)
-AC_SUBST(CGM_PARALLEL_LIB_FILE)
-#                           CGM-specific Checks
-SNL_CANT_USE_STD
-SNL_TEMPLATE_DEFS_INCLUDED
-AC_SUBST(CANT_USE_STD)
-AC_SUBST(CANT_USE_STD_IO)
-AC_SUBST(TEMPLATE_DEFS_INCLUDED)
-AM_CONDITIONAL(INCLUDE_TEMPLATE_DEFS, test x$TEMPLATE_DEFS_INCLUDED != x)
-#                         Use Cubit shared libraries
-CUBIT_FILE=no
-CUBIT_BIN_DIR=no
-HAVE_ACIS_DEF=
-AC_ARG_WITH( cubit,
-             AC_HELP_STRING([--with-cubit=<dir>],[Use CGM from CUBIT shared library]),
-             [CUBIT_DIR="$withval"
-              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-cubit=\"${withval}\""],
-             [CUBIT_DIR=no])
-AC_ARG_WITH( CUBIT,
-             AC_HELP_STRING([--with-CUBIT=<dir>],[DEPRECATED.  Use --with-cubit (small case)]),
-              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-cubit=\"${withval}\""])
-if test "x$CUBIT_DIR" == "xyes"; then
-  AC_MSG_ERROR([Option --with-CUBIT without specifying Cubit directory.])
-elif test "x$CUBIT_DIR" != "xno"; then
-  if ! test -d "$CUBIT_DIR"; then
-    AC_MSG_ERROR([$CUBIT_DIR: not a directory.])
-  fi
-  CUBIT_LDFLAGS=
-  CUBIT_LTFLAGS=
-  CUBIT_LIBS=no
-  if test -d "$CUBIT_DIR/bin"; then
-    CUBIT_BIN_DIR="$CUBIT_DIR/bin"
-  elif test -d "$CUBIT_DIR/lib"; then
-    CUBIT_BIN_DIR="$CUBIT_DIR/lib"
-  elif test -d "$CUBIT_DIR/libs"; then
-    CUBIT_BIN_DIR="$CUBIT_DIR/libs"
-  else
-    CUBIT_BIN_DIR="$CUBIT_DIR"
-  fi
-  CUBIT_LDFLAGS="-L$CUBIT_BIN_DIR"
-  CUBIT_LTFLAGS="-R$CUBIT_BIN_DIR"
-  cat >conftest.cc <<EOCUBITCT
-class AcisQueryEngine { public: static AcisQueryEngine* instance_; };
-int main() {
-  AcisQueryEngine::instance_ = 0;
-  return 0;
-EOCUBITCT
-  pattern=["${CUBIT_BIN_DIR}/*cubiti[0-9][0-9].*"]
-  for file in $pattern; do
-    AC_MSG_CHECKING([for AcisQueryEngine::instance_ in $file])
-    num=[`expr X"$file" : X".*cubiti\([0-9][0-9]\)\..*"`]
-    if ./libtool --mode=link $CXX $LDFLAGS $CUBIT_LDFLAGS $CUBIT_LTFLAGS -lcubiti$num conftest.cc -o conftest >&5 2>&5; then
-      CUBIT_LIBS="-lcubiti$num"
-      CUBIT_FILE=`expr x"$file" : x"$CUBIT_BIN_DIR/\(.*\)"`
-      CUBIT_FILE="${CUBIT_BIN_DIR}/$CUBIT_FILE"
-      AC_MSG_RESULT(yes)
-    else
-      AC_MSG_RESULT(no)
-    fi
-  done
-  rm -f conftest.cc
-  if test "x$CUBIT_LIBS" = "xno"; then
-    AC_MSG_ERROR("Cubit library not found in $CUBIT_BIN_DIR")
-  fi
-  CGM_EXT_LIBS="$CGM_EXT_LIBS $CUBIT_LIBS"
-  CGM_EXT_LDFLAGS="$CGM_EXT_LDFLAGS $CUBIT_LDFLAGS"
-  CGM_EXT_LTFLAGS="$CGM_EXT_LTFLAGS $CUBIT_LTFLAGS"
-  CUBIT_CGM="-DCUBIT_CGM"
-dnl  AC_DEFINE( HAVE_ACIS, "Have CGM ACIS Implementation" )
-  HAVE_ACIS_DEF=-DHAVE_ACIS
-fi
-AC_SUBST(CUBIT_BIN_DIR)
-AC_SUBST(CUBIT_LDFLAGS)
-AC_SUBST(CUBIT_LTFLAGS)
-AC_SUBST(CUBIT_LIBS)
-AC_SUBST(CUBIT_FILE)
-AC_SUBST(CUBIT_CGM)
-AM_CONDITIONAL(BUILD_CGM,[test x"$CUBIT_DIR" == x"no"])
-AM_CONDITIONAL(WITH_CUBIT,[test x"$CUBIT_DIR" != x"no"])
-#                           ACIS OPTIONS
-ACIS_BASE_LIBS='-lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase'
-ACIS_STEP_LIBS='-lacisstep -lxstep'
-ACIS_IGES_LIBS='-lacisiges -lxiges'
-AC_ARG_WITH( acis,
-             AC_HELP_STRING([--with-acis=<dir>],[Build with ACIS support, specify directory where ACIS is installed.]),
-             [ACIS_DIR=$withval
-              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-acis=\"${withval}\""],
-              [ACIS_DIR=no] )
-AC_ARG_WITH( ACIS,
-             AC_HELP_STRING([--with-ACIS],[DEPRECATED.  Use --wtih-acis (small case)]),
-              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-acis=\"${withval}\""] )
-AC_ARG_WITH( ACIS-system, AC_HELP_STRING([--with-acis-system=SYS],
-          [Specify ACIS system name (e.g. linux_so), default is to autodetect.]),
-             [ACIS_SYSTEM=$withval],[ACIS_SYSTEM=] )
-AC_ARG_WITH( acis-version, AC_HELP_STRING([--with-acis-version=INT],
-[Specify ACIS version as an integer value (100*major+10*minor+point), default is to autodetect.]),
-[if ! test "$withval" -gt "600"; then
-  AC_MSG_ERROR("ACIS-version must be an integer greater than 600.")
- fi
- ACIS_VERSION=$withval],
-[ACIS_VERSION=0])
-if test "x$ACIS_DIR" == "x"; then
-  ACIS_DIR=no
-fi
-if test "x$ACIS_DIR" == "xno"; then
-  ACIS_LIB_DIR=
-  ACIS_LINK_FLAGS=
-fi
-if test "x$ACIS_DIR" != "xno"; then
-  if test "x$CUBIT_DIR" != "xno"; then
-    AC_MSG_ERROR("Conflicting options:  Cannot specifiy both --with-ACIS and --with-CUBIT")
-  fi
-  AC_CHECK_FILE( [${srcdir}/geom/ACIS/AcisQueryEngine.hpp], [],
-                 [AC_MSG_ERROR([ACIS source not present.  Checkout ACIS_SRC and move to ACIS])] )
-  if test "$ACIS_DIR" == "yes"; then ACIS_DIR=.; fi
-  SNL_ACIS_ENV
-  SNL_ACIS_TRANSLATOR
-  if test x$ACIS_STEP_TRANSLATOR != x; then
-    ACIS_LIBS="$ACIS_LIBS $ACIS_STEP_LIBS"
-    ACIS_XLIBS="$ACIS_XLATE_LIBS"
-  fi
-  if test x$ACIS_IGES_TRANSLATOR != x; then
-    ACIS_LIBS="$ACIS_LIBS $ACIS_IGES_LIBS"
-  fi
-  CGM_ACIS_LIBS='-lcubit_ACIS'
-  ACIS_LIBS="$ACIS_LIBS $ACIS_XLIBS $ACIS_BASE_LIBS"
-  ACIS_LINK_FLAGS="-L$ACIS_LIB_DIR"
-  ACIS_HEALER="-DACIS_HEALER"
-  ACIS_INCLUDES="-I$ACIS_DIR/include"
-  ACIS_LTFLAGS="-R$ACIS_LIB_DIR"
-  CGM_EXT_LIBS="$CGM_EXT_LIBS $ACIS_LIBS"
-  CGM_EXT_LDFLAGS="$CGM_EXT_LDFLAGS $ACIS_LINK_FLAGS"
-  CGM_EXT_INCLUDE="$CGM_EXT_INCLUDE $ACIS_INCLUDES"
-  CGM_EXT_LTFLAGS="$CGM_EXT_LTFLAGS $ACIS_LTFLAGS"
-  if test "x$GXX" = "xyes"; then
-    CPPFLAGS="$CPPFLAGS -isystem $ACIS_DIR/include"
-  fi
-  ACIS_DEFS='$(ACIS_STEP_TRANSLATOR) $(ACIS_IGES_TRANSLATOR) -DCUBIT_ACIS_VERSION=$(ACIS_VERSION) -DACIS_VERSION=$(ACIS_VERSION) -D$(ACIS_PLATFORM) -DACIS_LOCAL_OPS'
-dnl  AC_DEFINE( HAVE_ACIS )
-fi
-# ACIS (at least up to version 16) requires new.h.
-# Newer C++ compilers may not provide this backwards-compatibility
-# file.  Check if it is present, and if not, use our own.
-ACIS_NEW_COMPAT_INC='-I${top_srcdir}/compat/new'
-  AC_LANG_PUSH(C++)
-  AC_CHECK_HEADER([new.h],[],[ACIS_INCLUDES="$ACIS_INCLUDES $ACIS_NEW_COMPAT_INC"])
-  AC_LANG_POP(C++)
-fi
-AC_SUBST(ACIS_DEFS)
-AC_SUBST(ACIS_DIR)
-AC_SUBST(ACIS_LINK_FLAGS)
-AC_SUBST(ACIS_LIB_DIR)
-AC_SUBST(ACIS_INCLUDES)
-AC_SUBST(ACIS_LIBS)
-AC_SUBST(CGM_ACIS_LIBS)
-AC_SUBST(ACIS_HEALER)
-AC_SUBST(ACIS_VERSION)
-AC_SUBST(ACIS_PLATFORM)
-AC_SUBST(ACIS_STEP_TRANSLATOR)
-AC_SUBST(ACIS_IGES_TRANSLATOR)
-AC_SUBST(HAVE_ACIS_DEF)
-AM_CONDITIONAL(build_ACIS, test x$ACIS_DIR != xno)
-#                           iGeom Babel
-AC_ARG_WITH(babel,
-[AC_HELP_STRING([--with-babel=DIR], [Specify directory containing babel])],
-[BABEL_DIR=$withval
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-babel=\"${withval}\""
- ], [BABEL_DIR=no])
-case "x$BABEL_DIR" in
-  xno)
-    BABEL_DIR=
-    USE_BABEL=no
-  xyes|x)
-    BABEL_DIR=/usr/local
-    AC_CHECK_FILE([${BABEL_DIR}/bin/babel], [USE_BABEL=yes], [USE_BABEL=no])
-esac
-AC_SUBST(BABEL_DIR)
-AC_SUBST(USE_BABEL)
-AM_CONDITIONAL(USE_BABEL, [test "xno" != "x$USE_BABEL"])
-#                           OCC Options
-# Add --with-occ option to configure script
-AC_ARG_WITH( occ,
-             [AC_HELP_STRING([--with-occ=<dir>],[OpenCascade shared library directory])],
-             [occ_DIR="$withval"
-              DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-occ=\"${withval}\""],
-             [occ_DIR=no] )
-# if user specified option (other than --without-occ)
-CUBIT_OCC_LIB=
-HAVE_OCC_DEF=
-if test "x$occ_DIR" != "xno"; then
-  OCC_LIBS="-lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKTopAlgo -lTKHLR -lTKIGES -lTKMesh -lTKPrim -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTopAlgo -lTKXSBase -lTKLCAF"
-  CUBIT_OCC_LIB="-lcubit_OCC"
-  # Set OCC_INC_FLAG and OCC_LIB_FLAG based on --with-occ option
-  if test "x$occ_DIR" = "x"; then
-    OCC_INC_FLAG=
-    OCC_LIB_DIR=
-    OCC_LIB_FLAG=
-  else
-    AC_CACHE_CHECK( [for 'include' subdir of $occ_DIR],
-                    [ac_cv_occ_include_dir],
-                    [ac_cv_occ_include_dir=NONE
-                     for subdir in inc ros/inc include; do
-                       if test -f "${occ_DIR}/${subdir}/Standard_Version.hxx"; then
-                         ac_cv_occ_include_dir="$subdir"
-                         break
-                       elif test -d "${occ_DIR}/${subdir}"; then
-                         ac_cv_occ_include_dir="$subdir";
-                       fi
-                     done] )
-    if test "xNONE" = "x$ac_cv_occ_include_dir"; then
-      AC_MSG_ERROR([Count not find include dir in: $occ_DIR])
-    else
-      OCC_INC_FLAG="-I${occ_DIR}/$ac_cv_occ_include_dir"
-    fi
-    AC_CACHE_CHECK( [for 'lib' subdir of $occ_DIR],
-                    [ac_cv_occ_lib_dir],
-                    [ac_cv_occ_lib_dir=NONE
-                     uname=`uname`
-                     for subdir in lib ros/lib ros/${uname}/lib ros/$uname ; do
-                       if test -d "${occ_DIR}/${subdir}"; then
-                         ac_cv_occ_lib_dir="$subdir"
-                         for file in ${occ_DIR}/${subdir}/libTKernel.* ; do
-                           if test -f $file; then
-                             break 2
-                           fi
-                         done
-                       fi
-                     done] )
-    if test "xNONE" = "x$ac_cv_occ_lib_dir"; then
-      AC_MSG_ERROR([Count not find lib dir in: $occ_DIR])
-    else
-      OCC_LIB_DIR="$occ_DIR/$ac_cv_occ_lib_dir"
-      OCC_LIB_FLAG="-L$OCC_LIB_DIR"
-    fi
-  fi
-  # Check of OCC is present and working
-  # Save old value of these variables and update working ones
-  old_CPPFLAGS="$CPPFLAGS"
-  old_LDFLAGS="$LDFLAGS"
-  CPPFLAGS="$CPPFLAGS ${OCC_INC_FLAG}"
-  LDFLAGS="$LDFLAGS -L$OCC_LIB_DIR"
-  # Check if 64-bit
-  AC_MSG_CHECKING([if platform is 64-bit (-D_OCC64)])
-  AC_TRY_COMPILE([],[int array[6-(int)sizeof(void*)];],[AC_MSG_RESULT(no)],
-                 [AC_MSG_RESULT(yes); OCC_INC_FLAG="$OCC_INC_FLAG -D_OCC64"])
-  # OCC requires some defines
-  AC_LANG_PUSH(C++)
-  AC_CHECK_HEADER([iostream],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOSTREAM"])
-  AC_CHECK_HEADER([iostream.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOSTREAM_H"])
-  AC_CHECK_HEADER([iomanip],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOMANIP"])
-  AC_CHECK_HEADER([iomanip.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_IOMANIP_H"])
-  AC_CHECK_HEADER([fstream],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_FSTREAM"])
-  AC_CHECK_HEADER([fstream.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_FSTREAM_H"])
-  AC_CHECK_HEADER([limits.h],[OCC_INC_FLAG="$OCC_INC_FLAG -DHAVE_LIMITS_H"])
-  # Check for OCC headers Stadard_Version.hxx
-  AC_CHECK_HEADER( [Standard_Version.hxx], [],
-                 [AC_MSG_ERROR([OpenCascade config error:Standard_Version.hxx not found])] )
-  # Check if libTKernel.so contains function 'create_mailbox'
-  # OCC 6.3 has build error where libTKernel.so requires libdl.so,
-  #   but does not list that in the shared library dependencies.
-  #   Try to work around this bug by detecting the need for -ldl.
-  AC_CHECK_LIB( [TKernel], [create_mailbox],,
-                [unset ac_cv_lib_TKernel_create_mailbox
-                               [OCC_LIBS="$OCC_LIBS -ldl"],
-                               [AC_MSG_ERROR([OpenCascade config error: libTKernel not found ])],
-                               [-ldl] )
-  AC_LANG_POP(C++)
-  # Restore original values of variables
-  CPPFLAGS="$old_CPPFLAGS"
-  LDFLAGS="$old_LDFLAGS"
-  HAVE_OCC_DEF="-DHAVE_OCC"
-  # Append to CGM global values
-  CGM_EXT_LIBS="$CGM_EXT_LIBS $OCC_LIBS"
-  CGM_EXT_LDFLAGS="$CGM_EXT_LDFLAGS $OCC_LIB_FLAG"
-  CGM_EXT_INCLUDE="$CGM_EXT_INCLUDE $OCC_INC_FLAG"
-  # NOTE: No CGM_EXT_LTFLAGS because OCC libs are .la files (not needed)
-fi
-# Export these variables as variables in Makefiles
-AC_SUBST(OCC_INC_FLAG)
-AC_SUBST(OCC_LIB_DIR)
-AC_SUBST(OCC_LIB_FLAG)
-AC_SUBST(OCC_LIBS)
-AC_SUBST(CUBIT_OCC_LIB)
-AC_SUBST(HAVE_OCC_DEF)
-#                           Define variables for linking
-AC_SUBST(CGM_EXT_LIBS)
-AC_SUBST(CGM_EXT_LDFLAGS)
-AC_SUBST(CGM_EXT_LTFLAGS)
-AC_SUBST(CGM_EXT_INCLUDE)
-# Allow "if build_OCC" in Makefile.am
-AM_CONDITIONAL( build_OCC, [test "x$occ_DIR" != "xno"] )
-#                           Output Files
-AC_SUBST(AM_CPPFLAGS)
-AC_SUBST(DISTCHECK_CONFIGURE_FLAGS)
-AC_MSG_RESULT([CXXFLAGS = $CXXFLAGS])
-dnl AC_OUTPUT_COMMANDS( [if test -f util/CubitUtilConfigure.h; then true; else echo "#define CUBIT_UTIL_EXPORT" > util/CubitUtilConfigure.h; fi],
-dnl                     [if test -f geom/CubitGeomConfigure.h; then true; else echo "#define CUBIT_GEOM_EXPORT" > geom/CubitGeomConfigure.h; fi] )
-AC_CONFIG_HEADERS(config.h)
-AC_CONFIG_HEADERS(itaps/iBase_FCDefs.h)
-AC_CONFIG_FILES(Makefile
-           util/Makefile
-           geom/Makefile
-           geom/ACIS/Makefile
-           geom/Cholla/Makefile
-           geom/facet/Makefile
-           geom/facetbool/Makefile
-           geom/OCC/Makefile
-           geom/parallel/Makefile
-           geom/virtual/Makefile
-           init/Makefile
-           compat/Makefile
-           cgm.make
-           itaps/Makefile
-           itaps/iGeom-Defs.inc
-	   itaps/SIDL/Makefile
-	   itaps/SIDL/common.make
-           itaps/SIDL/iGeom-SIDL-Defs.inc
-           test/Makefile
-           cgm_apps/Makefile
-           cgm_apps/examples/Makefile
-           cgm_apps/examples/driverc++/Makefile
-           cgm_apps/examples/facetdriver/Makefile
-AC_OUTPUT
-if test "x$CUBIT_DIR" != "xno" && test "x$CUBIT_DIR" != "x"; then
-   AC_MSG_WARN([Linking against Cubit-based CGM; you'll need to add Cubit's 'bin' directory
-                to your LD_LIBRARY_PATH before linking, or add -R (linux) or equivalent (non-linux)
-                to your link statement to link applications.])
-fi
More information about the cgma-dev
