[cgma-dev] r2574 - in cgm/trunk/itaps: . SIDL
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Mon Jan 26 13:19:09 CST 2009
Author: kraftche
Date: 2009-01-26 13:19:09 -0600 (Mon, 26 Jan 2009)
New Revision: 2574
Modified:
   cgm/trunk/itaps/SIDL/iBase.sidl
   cgm/trunk/itaps/iBase.h
   cgm/trunk/itaps/iGeom.h
Log:
update iGeom for iBase changes
Modified: cgm/trunk/itaps/SIDL/iBase.sidl
--- cgm/trunk/itaps/SIDL/iBase.sidl	2009-01-26 19:15:35 UTC (rev 2573)
+++ cgm/trunk/itaps/SIDL/iBase.sidl	2009-01-26 19:19:09 UTC (rev 2574)
@@ -1,3 +1,14 @@
+ * Copyright 2006 Sandia Corporation.  Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
 // iBase PACKAGE --
 // ITAPS UTITLIES COMMON ACROSS INTERFACES
@@ -4,7 +15,7 @@
 //   ERRORS, TAGS
-package iBase version 0.7
+package iBase version 0.8
    enum EntityType {
       VERTEX,
@@ -273,20 +284,20 @@
       // add and remove entities
       void addEntToSet(in opaque entity_handle,
-                       inout opaque entity_set) throws iBase.Error;
+                       in opaque entity_set) throws iBase.Error;
       // if the entity isn't in the set, don't throw an error
       void rmvEntFromSet( in opaque entity_handle,
       void addEntArrToSet( in array<opaque> entity_handles,
                            in int entity_handles_size,
       void rmvEntArrFromSet( in array<opaque> entity_handles,
       // all entity sets are contained in root set
       // root set is contained in no other sets
@@ -295,12 +306,12 @@
       // add/remove entity sets
       void addEntSet( in opaque entity_set_to_add,
-                      inout opaque entity_set_handle)
+                      in opaque entity_set_handle)
                       throws iBase.Error;
       // if the entity set isn't in the set, don't throw an error
       void rmvEntSet( in opaque entity_set_to_remove,
                       throws iBase.Error;
       // check whether an entity is contained in the entity set
@@ -308,6 +319,13 @@
                           out int is_contained) throws iBase.Error;
+      // check whether entities are contained in the entity set
+      void isEntArrContained( in opaque containing_set,
+                              in array<opaque> entity_handles,
+                              in int entity_handles_size,
+                              inout array<int> is_contained,
+                              out int is_contained_size );
       // check whether an entity set is contained in another
       void isEntSetContained(in opaque containing_entity_set,
                              in opaque contained_entity_set,
@@ -321,15 +339,15 @@
       // Root set cannot be a child or parent
       // don't throw error if parent/child already exists
-      void addPrntChld( inout opaque parent_entity_set,
-			inout opaque child_entity_set) throws iBase.Error;
+      void addPrntChld( in opaque parent_entity_set,
+			                  in opaque child_entity_set) throws iBase.Error;
       // don't throw error if parent/child link doesn't exist
-      void rmvPrntChld( inout opaque parent_entity_set,
+      void rmvPrntChld( in opaque parent_entity_set,
       void isChildOf( in opaque parent_entity_set,
-		      in opaque child_entity_set,
+                      in opaque child_entity_set,
                       out int is_child) throws iBase.Error;
       void getNumChld( in opaque entity_set, in int num_hops,
Modified: cgm/trunk/itaps/iBase.h
--- cgm/trunk/itaps/iBase.h	2009-01-26 19:15:35 UTC (rev 2573)
+++ cgm/trunk/itaps/iBase.h	2009-01-26 19:19:09 UTC (rev 2574)
@@ -15,10 +15,10 @@
      * TYPEDEF'S
-  typedef void* iBase_Instance;
-  typedef void* iBase_EntityHandle;
-  typedef void* iBase_EntitySetHandle;
-  typedef void* iBase_TagHandle;
+  typedef struct iBase_Instance_Private* iBase_Instance;
+  typedef struct iBase_EntityHandle_Private* iBase_EntityHandle;
+  typedef struct iBase_EntitySetHandle_Private* iBase_EntitySetHandle;
+  typedef struct iBase_TagHandle_Private* iBase_TagHandle;
      * ENTITYTYPE ENUMERATION
@@ -64,8 +64,6 @@
   enum iBase_ErrorActions {
     iBase_SILENT,
     iBase_WARN_ONLY,
-    iBase_ABORT_ON_ERROR,
-    iBase_PRINT_AND_THROW_ERROR,
     iBase_THROW_ERROR
Modified: cgm/trunk/itaps/iGeom.h
--- cgm/trunk/itaps/iGeom.h	2009-01-26 19:15:35 UTC (rev 2573)
+++ cgm/trunk/itaps/iGeom.h	2009-01-26 19:19:09 UTC (rev 2574)
@@ -71,19 +71,19 @@
      * Type used to store iGeom interface handle
-  typedef void* iGeom_Instance;
+  typedef struct iGeom_Instance_Private* iGeom_Instance;
     /**\brief  Type used to store an iterator returned by iGeom
      * Type used to store an iterator returned by iGeom
-  typedef void* iGeom_EntityIterator;
+  typedef struct iGeom_EntityIterator_Private* iGeom_EntityIterator;
     /**\brief  Type used to store an array iterator returned by iGeom
      * Type used to store an array iterator returned by iGeom
-  typedef void* iGeom_EntityArrIterator;
+  typedef struct iGeom_EntityArrIterator_Private* iGeom_EntityArrIterator;
     /**\brief  Get a description of the error returned from the last iGeom function
@@ -2299,7 +2299,7 @@
   void iGeom_addEntToSet(iGeom_Instance instance,
                          iBase_EntityHandle entity_handle,
-                         iBase_EntitySetHandle* entity_set,
+                         iBase_EntitySetHandle entity_set,
                          int *err);
     /**\brief  Remove an entity from a set
@@ -2313,7 +2313,7 @@
   void iGeom_rmvEntFromSet(iGeom_Instance instance,
                            int *err);
@@ -2329,7 +2329,7 @@
   void iGeom_addEntArrToSet(iGeom_Instance instance,
                             const iBase_EntityHandle* entity_handles,
                             int *err);
@@ -2345,7 +2345,7 @@
   void iGeom_rmvEntArrFromSet(iGeom_Instance instance,
                               int *err);
@@ -2358,8 +2358,8 @@
      * \param *err Pointer to error type returned from function
   void iGeom_addEntSet(iGeom_Instance instance,
-                       iBase_EntityHandle entity_set_to_add,
-                       iBase_EntitySetHandle* entity_set_handle,
+                       iBase_EntitySetHandle entity_set_to_add,
+                       iBase_EntitySetHandle entity_set_handle,
                        int *err);
@@ -2373,7 +2373,7 @@
   void iGeom_rmvEntSet(iGeom_Instance instance,
                        iBase_EntitySetHandle entity_set_to_remove,
                        int *err);
     /**\brief  Return whether an entity is contained in another set
@@ -2389,7 +2389,7 @@
   void iGeom_isEntContained(iGeom_Instance instance,
                             iBase_EntitySetHandle containing_entity_set,
-                            iBase_EntitySetHandle contained_entity,
+                            iBase_EntityHandle contained_entity,
                             int *is_contained,
                             int *err);
@@ -2420,8 +2420,8 @@
   void iGeom_addPrntChld(iGeom_Instance instance,
-                         iBase_EntitySetHandle* parent_entity_set,
-                         iBase_EntitySetHandle* child_entity_set,
+                         iBase_EntitySetHandle parent_entity_set,
+                         iBase_EntitySetHandle child_entity_set,
                          int *err);
     /**\brief  Remove parent/child links between two sets
@@ -2433,8 +2433,8 @@
   void iGeom_rmvPrntChld(iGeom_Instance instance,
                          int *err);
     /**\brief  Return whether two sets are related by parent/child links
More information about the cgma-dev mailing list
