[cgma-dev] r2573 - in cgm/trunk/itaps: . SIDL SIDL/gserver
kraftche at mcs.anl.gov
Mon Jan 26 13:15:36 CST 2009
Author: kraftche
Date: 2009-01-26 13:15:35 -0600 (Mon, 26 Jan 2009)
New Revision: 2573
Modified:
cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc
cgm/trunk/itaps/SIDL/iGeom.sidl
cgm/trunk/itaps/iGeom_CGMA.cc
cgm/trunk/itaps/testgeom.cc
Log:
update iGeom for iBase changes and fix babel parse errors in iGeom_SIDL_GeomSidl_Impl.cc
Modified: cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc
--- cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc 2009-01-26 18:18:56 UTC (rev 2572)
+++ cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc 2009-01-26 19:15:35 UTC (rev 2573)
@@ -2,16 +2,16 @@
// File: iGeom_SIDL_GeomSidl_Impl.cc
// Symbol: iGeom_SIDL.GeomSidl-v0.1
// Symbol Type: class
-// Babel Version: 0.10.12
-// sidl Created: 20070626 21:46:23 CDT
-// Generated: 20070626 21:46:35 CDT
+// Babel Version: 0.10.10
+// sidl Created: 20090126 13:13:24 CST
+// Generated: 20090126 13:13:26 CST
// Description: Server-side implementation for iGeom_SIDL.GeomSidl
// WARNING: Automatically generated; only changes within splicers preserved
-// babel-version = 0.10.12
+// babel-version = 0.10.10
// source-line = 5
-// source-url = file:/home/tautges/CGMnew/itaps/SIDL/iGeom_SIDL.sidl
+// source-url = file:/home/jason/meshkit/cgm/itaps/SIDL/iGeom_SIDL.sidl
#include "iGeom_SIDL_GeomSidl_Impl.hh"
@@ -952,7 +952,7 @@
void
iGeom_SIDL::GeomSidl_impl::addEntToSet (
/* in */ void* entity_handle,
- /* inout */ void*& entity_set )
+ /* in */ void* entity_set )
throw (
::iBase::Error
@@ -971,7 +971,7 @@
void
iGeom_SIDL::GeomSidl_impl::rmvEntFromSet (
throw (
::iBase::Error
@@ -991,7 +991,7 @@
iGeom_SIDL::GeomSidl_impl::addEntArrToSet (
/* in */ ::sidl::array<void*> entity_handles,
/* in */ int32_t entity_handles_size,
throw (
::iBase::Error
@@ -1014,7 +1014,7 @@
iGeom_SIDL::GeomSidl_impl::rmvEntArrFromSet (
throw (
::iBase::Error
@@ -1032,7 +1032,7 @@
void
iGeom_SIDL::GeomSidl_impl::addEntSet (
/* in */ void* entity_set_to_add,
- /* inout */ void*& entity_set_handle )
+ /* in */ void* entity_set_handle )
throw (
::iBase::Error
@@ -1050,7 +1050,7 @@
void
iGeom_SIDL::GeomSidl_impl::rmvEntSet (
/* in */ void* entity_set_to_remove,
throw (
::iBase::Error
@@ -1085,6 +1085,23 @@
+ * Method: isEntArrContained[]
+void
+iGeom_SIDL::GeomSidl_impl::isEntArrContained (
+ /* in */ void* containing_set,
+ /* in */ ::sidl::array<void*> entity_handles,
+ /* in */ int32_t entity_handles_size,
+ /* inout */ ::sidl::array<int32_t>& is_contained,
+ /* out */ int32_t& is_contained_size )
+throw ()
+ // DO-NOT-DELETE splicer.begin(iGeom_SIDL.GeomSidl.isEntArrContained)
+ // Insert-Code-Here {iGeom_SIDL.GeomSidl.isEntArrContained} (isEntArrContained method)
+ // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.isEntArrContained)
* Method: isEntSetContained[]
void
@@ -1110,8 +1127,8 @@
void
iGeom_SIDL::GeomSidl_impl::addPrntChld (
- /* inout */ void*& parent_entity_set,
- /* inout */ void*& child_entity_set )
+ /* in */ void* parent_entity_set,
+ /* in */ void* child_entity_set )
throw (
::iBase::Error
@@ -1127,8 +1144,8 @@
void
iGeom_SIDL::GeomSidl_impl::rmvPrntChld (
throw (
::iBase::Error
@@ -2629,34 +2646,6 @@
TEMP_ARRAY_INOUT(sense));
PROCESS_ERROR;
ASSIGN_ARRAY(sense);
- // DO-NOT-DELETE splicer.end(iGeom_CGM.CgmGeom.getEgVtxArrSense)
- * Return the arc length / area / volume of the entities
- * @param gentity_handles Entities for which measure is requested
- * @param gentity_handles_size Number of gentities
- * @param measures Arc length / area / volume of the entities
- * @param measures_length Number of entries in measures
-void
-iGeom_CGM::CgmGeom_impl::measure (
- /* in */ ::sidl::array<void*> gentity_handles,
- /* in */ int32_t gentity_handles_size,
- /* inout */ ::sidl::array<double>& measures,
- /* inout */ int32_t& measures_size )
-throw (
- ::iBase::Error
- // DO-NOT-DELETE splicer.begin(iGeom_CGM.CgmGeom.measure)
- CREATE_TEMP_ARRAY(double, measures);
- iGeom_measure(igeomInstance,
- TEMP_ARRAY_IN(gentity_handles),
- TEMP_ARRAY_INOUT(measures));
- PROCESS_ERROR;
- ASSIGN_ARRAY(measures);
// DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.getParametric)
@@ -2677,55 +2666,10 @@
iGeom_getFaceType(igeomInstance, gface_handle, &this_type);
if (NULL != this_type) face_type = this_type;
PROCESS_ERROR;
+ // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.isEntParametric)
-void
-throw (
- ::iBase::Error
- int32_t retval = iGeom_getParametric();
- PROCESS_ERROR;
- return retval;
- // DO-NOT-DELETE splicer.end(iGeom_CGM.CgmGeom.measure)
- * Return the type of surface as a string; if not a surface, an error is returned
- * @param face_handle Face for which the type is requested
- * @param face_type Type of face, returned as a string
-void
-iGeom_CGM::CgmGeom_impl::getFaceType (
- /* in */ void* gface_handle,
- /* inout */ ::std::string& face_type )
-throw (
- ::iBase::Error
- // DO-NOT-DELETE splicer.begin(iGeom_CGM.CgmGeom.getFaceType)
- const char *this_type = NULL;
- int32_t retval = iGeom_isEntParametric (igeomInstance,
- gentity_handle);
- PROCESS_ERROR;
- return retval;
- // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.isEntParametric)
* Method: isArrParametric[]
void
@@ -4232,7 +4176,7 @@
// Insert-Code-Here {iGeom_SIDL.GeomSidl._misc} (miscellaneous code)
// call this function when you want to throw an error
void
-iGeom_CGM::CgmGeom_impl::processError() throw(::iBase::Error)
+iGeom_SIDL::GeomSidl_impl::processError() throw(::iBase::Error)
static void *behavior_tag = NULL;
static ::iBase::ErrorActions action = ::iBase::ErrorActions_THROW_ERROR;
@@ -4265,3 +4209,24 @@
// DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl._misc)
+#error File has unused splicer blocks.
+ * ================= BEGIN UNREFERENCED METHOD(S) ================
+ * The following code segment(s) belong to unreferenced method(s).
+ * This can result from a method rename/removal in the sidl file.
+ * Move or remove the code in order to compile cleanly.
+ // DO-NOT-DELETE splicer.begin(iGeom_SIDL.GeomSidl_impl.getFaceType)
+ const char *this_type = NULL;
+ int32_t retval = iGeom_isEntParametric (igeomInstance,
+ gentity_handle);
+ PROCESS_ERROR;
+ return retval;
+ // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl_impl.getFaceType)
+ // DO-NOT-DELETE splicer.begin(iGeom_SIDL.GeomSidl_impl.measure)
+ CREATE_TEMP_ARRAY(double, measures);
+ int32_t retval = iGeom_getParametric();
+ PROCESS_ERROR;
+ return retval;
+ // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl_impl.measure)
+// ================== END UNREFERENCED METHOD(S) =================
Modified: cgm/trunk/itaps/SIDL/iGeom.sidl
--- cgm/trunk/itaps/SIDL/iGeom.sidl 2009-01-26 18:18:56 UTC (rev 2572)
+++ cgm/trunk/itaps/SIDL/iGeom.sidl 2009-01-26 19:15:35 UTC (rev 2573)
@@ -1,4 +1,4 @@
-import iBase version 0.7;
+import iBase version 0.8;
package iGeom version 0.6.99
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2009-01-26 18:18:56 UTC (rev 2572)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2009-01-26 19:15:35 UTC (rev 2573)
@@ -276,7 +276,7 @@
RETURN (iBase_FAILURE);
// return the tagmanager as the instance
- *instance_out = &CGMTagManager::instance();
+ *instance_out = reinterpret_cast<iGeom_Instance>(&CGMTagManager::instance());
RETURN(iBase_SUCCESS);
@@ -443,7 +443,9 @@
iGeom_EntityIterator *iterator,
int* err)
- iGeom_initEntArrIter( instance, entity_set_handle, dimension, 1, iterator, err );
+ iGeom_initEntArrIter( instance, entity_set_handle, dimension, 1,
+ reinterpret_cast<iGeom_EntityArrIterator*>(iterator),
+ err );
void
@@ -451,7 +453,7 @@
/*in*/ iBase_EntitySetHandle entity_set_handle,
/*in*/ int type,
/*in*/ int requested_array_size,
- /*out*/ iGeom_EntityIterator* entArr_iterator,
+ /*out*/ iGeom_EntityArrIterator* entArr_iterator,
int* err)
DLIList<RefEntity*> entities;
@@ -488,7 +490,7 @@
entities, CUBIT_FALSE);
CGMAIterator* iter = new CGMAIterator(entities, requested_array_size);
- *entArr_iterator = reinterpret_cast<iGeom_EntityIterator>(iter);
+ *entArr_iterator = reinterpret_cast<iGeom_EntityArrIterator>(iter);
@@ -517,7 +519,7 @@
void
iGeom_getNextEntArrIter(iGeom_Instance instance,
- /*in*/ iGeom_EntityIterator entArr_iterator,
+ /*in*/ iGeom_EntityArrIterator entArr_iterator,
/*inout*/ iBase_EntityHandle **entity_handles,
int *entity_handles_allocated,
int *entity_handles_size,
@@ -547,7 +549,7 @@
void
iGeom_resetEntArrIter(iGeom_Instance instance,
- /*in*/ iGeom_EntityIterator gentity_iterator,
+ /*in*/ iGeom_EntityArrIterator gentity_iterator,
int* err
@@ -572,7 +574,7 @@
void
iGeom_endEntArrIter (iGeom_Instance instance,
int* err)
CGMAIterator* iterator = reinterpret_cast<CGMAIterator*>(gentity_iterator);
@@ -629,10 +631,11 @@
std::vector<RefGroup*> group_ptrs;
const RefGroup *this_grp = SET_HANDLE(from_entity_set);
TM->get_pc_groups(const_cast<RefGroup*>(this_grp), 1, num_hops, group_ptrs);
- CHECK_SIZE(*entity_set_handles, iBase_EntityHandle,
+ CHECK_SIZE(*entity_set_handles, iBase_EntitySetHandle,
(int)group_ptrs.size());
- std::copy(group_ptrs.begin(), group_ptrs.end(), *entity_set_handles);
+ iBase_EntitySetHandle* ent_arr = reinterpret_cast<iBase_EntitySetHandle*>(&group_ptrs[0]);
+ std::copy( ent_arr, ent_arr + group_ptrs.size(), *entity_set_handles);
@@ -653,10 +656,11 @@
TM->get_pc_groups(const_cast<RefGroup*>(this_grp), 0, num_hops, group_ptrs);
@@ -707,16 +711,16 @@
void
iGeom_addPrntChld (iGeom_Instance instance,
- /*inout*/ iBase_EntitySetHandle *parent_entity_set,
- /*inout*/ iBase_EntitySetHandle *child_entity_set,
+ /*inout*/ iBase_EntitySetHandle parent_entity_set,
+ /*inout*/ iBase_EntitySetHandle child_entity_set,
int* err)
std::vector<RefGroup*> *my_parents =
- TM->pc_list(SET_HANDLE(*child_entity_set), 0, true);
+ TM->pc_list(SET_HANDLE(child_entity_set), 0, true);
std::vector<RefGroup*> *my_children =
- TM->pc_list(SET_HANDLE(*parent_entity_set), 1, true);
- RefGroup *par_group = SET_HANDLE(*parent_entity_set);
- RefGroup *child_group = SET_HANDLE(*child_entity_set);
+ TM->pc_list(SET_HANDLE(parent_entity_set), 1, true);
+ RefGroup *par_group = SET_HANDLE(parent_entity_set);
+ RefGroup *child_group = SET_HANDLE(child_entity_set);
my_parents->push_back(par_group);
my_children->push_back(child_group);
@@ -727,12 +731,12 @@
void
iGeom_rmvPrntChld (iGeom_Instance instance,
int* err)
- RefGroup *parent = reinterpret_cast<RefGroup *>(*parent_entity_set);
- RefGroup *child = reinterpret_cast<RefGroup *>(*child_entity_set);
+ RefGroup *parent = reinterpret_cast<RefGroup *>(parent_entity_set);
+ RefGroup *child = reinterpret_cast<RefGroup *>(child_entity_set);
std::vector<RefGroup*> *children = TM->pc_list(parent, 1, false),
*parents = TM->pc_list(child, 0, false);
if (NULL == children || NULL == parents) {
@@ -1252,7 +1256,7 @@
// make sure string is null-terminated
std::string tag_name_buf( tag_name, tag_name_len );
tag_name = tag_name_buf.c_str();
- *tag_handle = reinterpret_cast<void*>(static_cast<size_t>(TM->getTagHandle( tag_name )));
+ *tag_handle = reinterpret_cast<iBase_TagHandle>(static_cast<size_t>(TM->getTagHandle( tag_name )));
@@ -1369,7 +1373,7 @@
/*in*/ iBase_EntityHandle const *entity_handles,
int entity_handles_size,
/*in*/ iBase_TagHandle tag_handle,
- /*inout*/ void* **tag_value,
+ /*inout*/ iBase_EntityHandle **tag_value,
int *tag_value_allocated,
int *tag_value_size,
int* err)
@@ -1625,7 +1629,7 @@
void
iGeom_getEntSetIntData (iGeom_Instance instance,
- /*in*/ iBase_EntityHandle entity_set,
+ /*in*/ iBase_EntitySetHandle entity_set,
int* tag_ptr,
int* err )
@@ -1638,7 +1642,7 @@
void
iGeom_getEntSetDblData (iGeom_Instance instance,
double* tag_ptr,
int* err )
@@ -1650,7 +1654,7 @@
void
iGeom_getEntSetEHData (iGeom_Instance instance,
iBase_EntityHandle* tag_ptr,
int* err )
@@ -1682,7 +1686,7 @@
void
iGeom_setEntSetIntData (iGeom_Instance instance,
/*in*/ int tag_value,
int* err )
@@ -1695,7 +1699,7 @@
void
iGeom_setEntSetDblData (iGeom_Instance instance,
/*in*/ double tag_value,
int* err )
@@ -3483,7 +3487,8 @@
/*out*/ iBase_EntitySetHandle *entity_set,
int* err)
- *entity_set = RefEntityFactory::instance()->construct_RefGroup();
+ RefGroup* grp = RefEntityFactory::instance()->construct_RefGroup();
+ *entity_set = reinterpret_cast<iBase_EntitySetHandle>(grp);
// need to set a tag denoting multiset or not...
if (*entity_set == NULL) {
RETURN(iBase_FAILURE);
@@ -3541,10 +3546,10 @@
void
iGeom_addEntSet (iGeom_Instance instance,
/*in*/ iBase_EntitySetHandle entity_set_to_add,
- /*inout*/ iBase_EntitySetHandle *entity_set_handle,
+ /*inout*/ iBase_EntitySetHandle entity_set_handle,
int* err)
- iGeom_addEntToSet(instance, entity_set_to_add, entity_set_handle, err);
+ iGeom_addEntToSet(instance, reinterpret_cast<iBase_EntityHandle>(entity_set_to_add), entity_set_handle, err);
@@ -3558,10 +3563,10 @@
void
iGeom_rmvEntSet (iGeom_Instance instance,
/*in*/ iBase_EntitySetHandle entity_set_to_remove,
int* err)
- iGeom_rmvEntFromSet(instance, entity_set_to_remove, entity_set_handle, err);
+ iGeom_rmvEntFromSet(instance, reinterpret_cast<iBase_EntityHandle>(entity_set_to_remove), entity_set_handle, err);
@@ -3576,12 +3581,12 @@
void
iGeom_addEntToSet (iGeom_Instance instance,
/*in*/ iBase_EntityHandle entity_to_add,
int* err)
if (NULL == entity_to_add) RETURN(iBase_INVALID_ARGUMENT);
- CubitStatus status = SET_HANDLE(*entity_set_handle)->
+ CubitStatus status = SET_HANDLE(entity_set_handle)->
add_ref_entity(const_cast<RefEntity*>(ENTITY_HANDLE(entity_to_add)));
if (CUBIT_SUCCESS != status) {
@@ -3602,12 +3607,12 @@
void
iGeom_rmvEntFromSet (iGeom_Instance instance,
/*in*/ iBase_EntityHandle entity_to_remove,
int* err)
- if (NULL == *entity_set_handle) RETURN(iBase_INVALID_ARGUMENT);
+ if (NULL == entity_set_handle) RETURN(iBase_INVALID_ARGUMENT);
remove_ref_entity(const_cast<RefEntity*>(ENTITY_HANDLE(entity_to_remove)));
ERROR(iBase_FAILURE, "Problem removing entity from a set.");
@@ -3645,7 +3650,9 @@
int* is_contained,
int* err)
- iGeom_isEntContained( instance, containing_entity_set, contained_entity_set, is_contained, err);
+ iGeom_isEntContained( instance, containing_entity_set,
+ reinterpret_cast<iBase_EntityHandle>(contained_entity_set),
+ is_contained, err);
@@ -3660,12 +3667,12 @@
iGeom_addEntArrToSet (iGeom_Instance instance,
/*in*/ iBase_EntityHandle const* entity_handles,
- /*inout*/ iBase_EntitySetHandle *entity_set,
+ /*inout*/ iBase_EntitySetHandle entity_set,
int* err)
if (NULL == entity_set) RETURN(iBase_INVALID_ARGUMENT);
- RefGroup *this_set = SET_HANDLE(*entity_set);
+ RefGroup *this_set = SET_HANDLE(entity_set);
RefEntity **ent_array = (RefEntity**)(entity_handles);
CubitStatus status = CUBIT_SUCCESS, tmp_status;
for (int i = 0; i < entity_handles_size; i++) {
@@ -3689,12 +3696,12 @@
iGeom_rmvEntArrFromSet (iGeom_Instance instance,
int* err)
@@ -4987,7 +4994,7 @@
RefGroup *set3 = SET_HANDLE(*result_entity_set);
if (NULL == set3) {
set3 = RefEntityFactory::instance()->construct_RefGroup();
- *result_entity_set = set3;
+ *result_entity_set = reinterpret_cast<iBase_EntitySetHandle>(set3);
set3->subtract(const_cast<RefGroup*>(set2), const_cast<RefGroup*>(set1));
@@ -5011,7 +5018,7 @@
if (NULL == set3) {
set3->intersect(const_cast<RefGroup*>(set2), const_cast<RefGroup*>(set1));
@@ -5035,7 +5042,7 @@
if (NULL == set3) {
set3->unite(const_cast<RefGroup*>(set2), const_cast<RefGroup*>(set1));
@@ -5061,12 +5068,12 @@
RefEntity *temp_entity = gmt->copy_body(this_body);
- *geom_entity2 = temp_entity;
+ *geom_entity2 = reinterpret_cast<iBase_EntityHandle>(temp_entity);
else {
RefEntity *this_ent = ENTITY_HANDLE(geom_entity);
RefEntity *temp_entity = gmt->copy_refentity(this_ent);
if (NULL == *geom_entity2) {
@@ -5115,7 +5122,7 @@
// HACK to get last entity created, because cgm doesn't return
// body created by sweep
RefEntity *new_body = RefEntityFactory::instance()->get_last_body();
- *geom_entity2 = new_body;
+ *geom_entity2 = reinterpret_cast<iBase_EntityHandle>(new_body);
// now we know it's succeeded, delete original body
Body *this_body = dynamic_cast<TopologyEntity*>(this_ent)->body();
@@ -5175,7 +5182,7 @@
RefEntity* tmp_body = gmt->sphere( radius );
- *geom_entity = tmp_body;
+ *geom_entity = reinterpret_cast<iBase_EntityHandle>(tmp_body);
RETURN ((tmp_body ? iBase_SUCCESS : iBase_FAILURE));
@@ -5196,7 +5203,7 @@
RefEntity* tmp_body = gmt->prism( height, n_sides, major_rad, minor_rad );
RETURN ((tmp_body ? iBase_SUCCESS :iBase_FAILURE));
@@ -5223,7 +5230,7 @@
RefEntity *temp_body = gmt->brick(tmp_x, tmp_y, tmp_z);
- *geom_entity = temp_body;
+ *geom_entity = reinterpret_cast<iBase_EntityHandle>(temp_body);
if (NULL == *geom_entity) {
@@ -5243,7 +5250,7 @@
double tmp_minor = (0.0 == minor_rad ? major_rad : minor_rad);
gmt->cylinder(height, major_rad, tmp_minor, major_rad);
@@ -5265,7 +5272,7 @@
RefEntity *temp_body = gmt->torus(major_rad, minor_rad);
@@ -5492,7 +5499,7 @@
else {
- *geom_entity = dynamic_cast<RefEntity*>(new_bods.get());
+ *geom_entity = reinterpret_cast<iBase_EntityHandle>(dynamic_cast<RefEntity*>(new_bods.get()));
for (int i = orig_bods.size(); i > 0; i--)
gqt->delete_RefEntity(orig_bods.get_and_step());
@@ -5530,7 +5537,7 @@
else {
new_body = new_body_list.get();
- *geom_entity = new_body;
+ *geom_entity = reinterpret_cast<iBase_EntityHandle>(new_body);
gqt->delete_RefEntity(this_blank);
gqt->delete_RefEntity(this_tool);
@@ -5568,7 +5575,7 @@
else {
gqt->delete_RefEntity(this_ent2);
gqt->delete_RefEntity(this_ent1);
@@ -5631,7 +5638,7 @@
else {
// need to assign it to a RE* first so the void cast gets done right
RefEntity *new_body = new_body_list.get();
// also, delete the original body, now that the section worked
gqt->delete_RefEntity(this_body);
Modified: cgm/trunk/itaps/testgeom.cc
--- cgm/trunk/itaps/testgeom.cc 2009-01-26 18:18:56 UTC (rev 2572)
+++ cgm/trunk/itaps/testgeom.cc 2009-01-26 19:15:35 UTC (rev 2573)
@@ -269,7 +269,7 @@
iGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 );
CHECK( "ERROR : can not load a geometry" );
- iBase_EntityHandle root_set;
+ iBase_EntitySetHandle root_set;
iGeom_getRootSet( geom, &root_set, &err );
CHECK( "ERROR : getRootSet failed!" );
@@ -308,7 +308,7 @@
int err;
@@ -405,7 +405,7 @@
iGeom_createTag( geom, &tag_name[0], sizeof(int), iBase_BYTES, &this_tag, &err, tag_name.length() );
CHECK( "ERROR : can not create a tag for get_set test." );
@@ -471,7 +471,7 @@
int ent_type = iBase_VERTEX;
int err;
@@ -492,7 +492,7 @@
CHECK( "Failed to get gentities by type in gentityset_test." );
// add gentities into gentity set
- iGeom_addEntArrToSet( geom, ARRAY_IN( gentities ), &ges_array[ent_type], &err );
+ iGeom_addEntArrToSet( geom, ARRAY_IN( gentities ), ges_array[ent_type], &err );
CHECK( "Failed to add gentities in entityset_test." );
// Check to make sure entity set really has correct number of entities in it
@@ -519,7 +519,7 @@
CHECK( "Failed to create a super set in gentityset_test." );
for (int i = 0; i < num_type; i++) {
- iGeom_addEntSet( geom, ges_array[i], &super_set, &err );
+ iGeom_addEntSet( geom, ges_array[i], super_set, &err );
@@ -537,7 +537,7 @@
CHECK( "Failed to get gedge gentities in gentityset_test." );
// add EDGEs to ges1
- iGeom_addEntArrToSet( geom, ARRAY_IN(gedges), &temp_ges1, &err );
+ iGeom_addEntArrToSet( geom, ARRAY_IN(gedges), temp_ges1, &err );
CHECK( "Failed to add gedge gentities in gentityset_test." );
// get all FACE gentities
@@ -545,7 +545,7 @@
CHECK( "Failed to get gface gentities in gentityset_test." );
// add FACEs to es1
- iGeom_addEntArrToSet( geom, ARRAY_IN(gfaces), &temp_ges1, &err );
+ iGeom_addEntArrToSet( geom, ARRAY_IN(gfaces), temp_ges1, &err );
CHECK( "Failed to add gface gentities in gentityset_test." );
// subtract EDGEs
@@ -574,7 +574,7 @@
// clean out the temp_ges1
- iGeom_rmvEntArrFromSet( geom, ARRAY_IN(gfaces), &temp_ges1, &err );
+ iGeom_rmvEntArrFromSet( geom, ARRAY_IN(gfaces), temp_ges1, &err );
CHECK( "Failed to remove gface gentities in gentityset_test." );
// check if it is really cleaned out
@@ -587,11 +587,11 @@
// add EDGEs to temp ges1
// add FACEs to temp ges1
// intersect temp_ges1 with gedges set
@@ -622,7 +622,7 @@
CHECK( "Failed to get gregion gentities in gentityset_test." );
// add REGIONs to temp es2
- iGeom_addEntArrToSet( geom, ARRAY_IN(gregions), &temp_ges2, &err );
+ iGeom_addEntArrToSet( geom, ARRAY_IN(gregions), temp_ges2, &err );
CHECK( "Failed to add gregion gentities in gentityset_test." );
// unite temp_ges1 and temp_ges2
@@ -647,7 +647,7 @@
iGeom_createEntSet( geom, true, &parent_child, &err );
CHECK( "Problem creating gentityset in gentityset_test." );
- iGeom_addPrntChld( geom, &ges_array[iBase_VERTEX], &parent_child, &err );
+ iGeom_addPrntChld( geom, ges_array[iBase_VERTEX], parent_child, &err );
CHECK( "Problem add parent in gentityset_test." );
// check if parent is really added
@@ -668,17 +668,17 @@
//int num_temp_gedge_array;
//parent_child_array.set(0, parent_child);
//temp_gedge_array.set(0, ges_array[TSTTG::EntityType_EDGE]);
- iGeom_addPrntChld( geom, &ges_array[iBase_EDGE], &parent_child, &err );
+ iGeom_addPrntChld( geom, ges_array[iBase_EDGE], parent_child, &err );
CHECK( "Problem adding parent and child in gentityset_test." );
//sidl::array<void*> temp_gface_array = sidl::array<void*>::create1d(1);
//int num_temp_gface_array;
//temp_gface_array.set(0, ges_array[TSTTG::EntityType_FACE]);
- iGeom_addPrntChld( geom, &parent_child, &ges_array[iBase_FACE], &err );
+ iGeom_addPrntChld( geom, parent_child, ges_array[iBase_FACE], &err );
// add child
- iGeom_addPrntChld( geom, &parent_child, &ges_array[iBase_REGION], &err );
+ iGeom_addPrntChld( geom, parent_child, ges_array[iBase_REGION], &err );
CHECK( "Problem adding child in gentityset_test." );
// get the number of parent gentitysets
@@ -714,7 +714,7 @@
// remove children
- iGeom_rmvPrntChld( geom, &parent_child, &ges_array[iBase_FACE], &err );
+ iGeom_rmvPrntChld( geom, parent_child, ges_array[iBase_FACE], &err );
CHECK( "Problem removing parent child in gentityset_test." );
// get the number of child gentitysets
@@ -775,7 +775,7 @@
// get all entities in super set
- SimpleArray<iBase_EntityHandle> all_gentities;
+ SimpleArray<iBase_EntitySetHandle> all_gentities;
iGeom_getEntSets( geom, super_set, 1, ARRAY_INOUT( all_gentities ), &err );
CHECK( "Problem to get all gentities in super set." );
@@ -795,7 +795,7 @@
iBase_EntitySetHandle ges_k = ges_array1[k];
for (int a = 0; a < ges_array1.size(); a++) {
- iGeom_addEntSet( geom, ges_array1[a], &ges_k, &err );
+ iGeom_addEntSet( geom, ges_array1[a], ges_k, &err );
CHECK( "Problem to add entity set." );
@@ -805,7 +805,7 @@
//superset_array.set(0, super_set);
//int num_superset_array;
- iGeom_addEntSet( geom, super_set, &ges_k, &err );
+ iGeom_addEntSet( geom, super_set, ges_k, &err );
CHECK( "Problem to add super set to gentitysets." );
// add one gentity sets multiple times
@@ -816,7 +816,7 @@
//temp_array1.set(0, temp_ges1);
//for (int l = 0; l < 3; l++) {
- iGeom_addEntSet( geom, temp_ges1, &ges_k, &err );
+ iGeom_addEntSet( geom, temp_ges1, ges_k, &err );
CHECK( "Problem to add temp set to gentitysets." );
@@ -835,7 +835,7 @@
bool topology_adjacencies_test(iGeom_Instance geom)
int i, err;
More information about the cgma-dev
