[cgma-dev] r2526 - cgm/trunk/geom/OCC
    janehu at mcs.anl.gov
    Fri Jan  9 15:10:43 CST 2009
Author: janehu
Date: 2009-01-09 15:10:42 -0600 (Fri, 09 Jan 2009)
New Revision: 2526
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Changed to make a non-const body pointer point to the same thing as the const pointer does.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-01-09 20:51:43 UTC (rev 2525)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-01-09 21:10:42 UTC (rev 2526)
@@ -4512,9 +4512,7 @@
   //tool_body is a const pointer points to varible BodySM object
   //here trying to create a non-const pointer points to the same BodySM object.
-  BodySM *body, *body2;
-  body = brick(1,1,1);
-  body2 = body;
+  BodySM *body;
   *body = *tool_body;
   CubitStatus stat = intersect(body, webcut_body_list, results_list,
@@ -4532,8 +4530,6 @@
   stat = subtract(tool_bodies, webcut_body_list, results_list, imprint,
                   CUBIT_TRUE);
-  OCCQueryEngine::instance()->delete_solid_model_entities(body2);
   return stat;
More information about the cgma-dev
